    3.5.0b1+ Wifi error - SPI timeout
    Beta Firmware
    8
    39
    1.7k
    • OwenDundefined
      OwenD @dc42
      Good question.
      It looks like I still have one I compiled from source a few days ago.
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.5beta1+ (2023-01-10)
      I haven't made any changes, so I presume it will have the fixes you mention.
      I can upload the last release if it will make it easier to track.
        dc42 administrators @OwenD
        @OwenD that depends on when you pulled the source files from github.
        OwenDundefined 1 Reply Last reply Reply Quote 0
        • OwenDundefined
          OwenD @dc42
          @dc42 said in 3.5.0b1+ Wifi error - SPI timeout:
          It would have been the same day, but I'll revert and run another print just to be sure.
          • OwenDundefined
            OwenD @OwenD
            @OwenD
            I've run several prints with no re-occurrence of this issue, so I'll mark this as solved.
            If it crops up again, I'll re-visit.
            OwenDundefined 1 Reply Last reply Reply Quote 1
            • OwenDundefined OwenD marked this topic as a question
            • OwenDundefined OwenD has marked this topic as solved
            • OwenDundefined
              OwenD @OwenD
              Came home from work today to find this had re-occurred.
              The printer has been idle for several days apart from some macro debugging last night.
              When it occurs the PanelDue is flooded with error messages at a very high rate.
              Connected by USB and got an M122 report.
              ror: failed to retrieve WiFi status message: SPI timeout
              Error: failed to retrieve WiFi status message: SPI timeout
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5beta1+ (2022-12-31 17:10:26) running on Duet WiFi 1.02 or later
              Board ID: 08DGM-917NK-F2MS4-7J1DA-3S86T-TZTWD
              Used output buffers: 1 of 26 (26 max)
              Static ram: 22148
              Dynamic ram: 79236 of which 216 recycled
              Never used RAM 4712, free system stack 192 words
              Tasks: NETWORK(notifyWait,37.1%,233) ACCEL(notifyWait,0.0%,348) HEAT(notifyWait,0.6%,330) Move(notifyWait,0.1%,362) MAIN(running,60.8%,331) IDLE(ready,1.6%,30), total 100.0%
              Owned mutexes: WiFi(NETWORK) USB(MAIN)
              Last reset 23:57:15 ago, cause: software
              Last software reset at 2023-01-19 19:22, reason: User, GCodes spinning, available RAM 8228, slot 2
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
              Error status: 0x00
              Aux0 errors 0,0,0
              Step timer max interval 0
              MCU temperature: min 27.3, current 29.4, max 34.3
              Supply voltage: min 0.4, current 0.5, max 0.5, under voltage events: 0, over voltage events: 0, power good: no
              Heap OK, handles allocated/used 297/195, heap memory allocated/used/recyclable 4096/3648/484, gc cycles 89
              Events: 0 queued, 0 completed
              Driver 0: ok, SG min n/a
              Driver 1: ok, SG min n/a
              Driver 2: ok, SG min n/a
              Driver 3: ok, SG min n/a
              Driver 4: ok, SG min n/a
              Driver 5:
              Driver 6:
              Driver 7:
              Driver 8:
              Driver 9:
              Driver 10:
              Driver 11:
              Date/time: 2023-01-20 19:19:46
              Slowest loop: 97.05ms; fastest: 0.07ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 4.8ms, write time 131.9ms, max retries 0
              DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
              no step interrupt scheduled
              === DDARing 0 ===
              Movement locks held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is ready with "M122" in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Q0 segments left 0
              Code queue 0 is empty
              === Filament sensors ===
              Extruder 0 sensor: ok
              === Network ===
              Slowest loop: 523.09ms; fastest: 0.00ms
              Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              HTTP sessions: 0 of 8
              = WiFi =
              Network state is active
              Failed messages: pending 0, notready 5, noresp 775826
              Failed to get WiFi status
              ok
              • OwenDundefined OwenD has marked this topic as unsolved
                jay_s_uk @OwenD
                @OwenD before you reset could you try activating wifi debugging over USB?
                M111 P14 S1
                • OwenDundefined
                  OwenD @jay_s_uk
                  @jay_s_uk
                  Will do.
                  Not sure how long it will take before it will occur again.
                  T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 1
                    T3P3Tony administrators @OwenD
                    @OwenD also it would be helpful to get a summary of how (in)frequently this occurs and confirmation of the firmware and wifi firmware versions running.
                    • jay_s_ukundefined jay_s_uk referenced this topic
                      @OwenD version 2.1beta2 of DuetWiFiSocketServer has been replaced by 2.1beta3 available at https://github.com/Duet3D/WiFiSocketServerRTOS/releases/tag/2.1beta3.
                      • OwenDundefined
                        OwenD @dc42
                        @dc42 @T3P3Tony
                        I'm afraid I haven't been able to reproduce this and I can't determine one factor that has "fixed" it.
                        I do have a few observations.
                        I used to get the occasional message on PanelDue that said that the WiFi had been successfully reconnected.
                        This is a modal message, so it could have happened at any time and I wouldn't see it until I went to the shed.
                        My wifi signal in the shed has always been around -51db, not horrible, but not great either.
                        After this issue arose, I went and got a wifi range extender.
                        This boosted the signal to around -41 to -44db
                        Note: That I hadn't had a re-occurrence BEFORE I put the extender on.
                        I don't know what signal I showed with 2.1beta2 as it didn't report it.
                        I just installed 2.1beta3
                        My first M122 showed a signal of -36db with the extender!
                        = WiFi =
                        WiFi firmware version 2.1beta3
                        WiFi MAC address bc:dd:c2:89:a0:bb
                        WiFi Vcc 3.38, reset reason Power up
                        WiFi flash size 2097152, free heap 39380
                        WiFi IP address 192.168.1.163
                        WiFi signal strength -36dBm, mode 802.11n, reconnections 0, sleep mode modem
                        Clock register 00002002
                        I then went back in versions and did reports on each, both with and without the extender.
                        No extender
                        = WiFi =
                        WiFi Vcc 3.38, reset reason Turned on by main processor
                        WiFi flash size 2097152, free heap 39440
                        WiFi signal strength -41dBm, mode 802.11n, reconnections 0, sleep mode modem
                        No extender
                        = WiFi =
                        WiFi firmware version 1.27
                        WiFi flash size 4194304, free heap 23776
                        WiFi signal strength -51dBm, mode 802.11n, reconnections 0, sleep mode modem
                        No extender
                        = WiFi =
                        WiFi flash size 2097152, free heap 40992
                        WiFi signal strength -44dBm, mode 802.11n, reconnections 0, sleep mode modem
                        With extender
                        = WiFi =
                        WiFi flash size 2097152, free heap 38844
                        WiFi signal strength -37dBm, mode 802.11n, reconnections 0, sleep mode modem
                        I'm not sure how the firmware version can increase the signal so dramatically?
                        I'm inclined to mark this as solved again simply because I can't repeat it reliably, so if nobody else is complaining it's not worth chasing.
                          @OwenD thanks for reporting this. Versions 1.x and 2.x of the WiFi firmware use different versions of the Expressif SDK. I guess either one of those SDK versions is mis-reporting RSSI, or they have changed the interface and we didn't pick that up. I will check the version 2.x code.
                          • OwenDundefined
                            OwenD
                            So for some reason this has reared it's head again a couple of times lately.
                            My system has a 5v power supply which powers the duet and switches a 24 volt power supply via the ATX pin as required.
                            Before resetting I ran M111 P14 S1, then M122
                            YAT seems to have dumped that report due to the volume of lines added, so I've only got the report immediately after restarting.
                            For some reason the MCU voltage shows a very low value until I run M80 and kick the 24v power supply into action. Not sure if that's related.
                            It does the same regardless of this wifi anomaly.
                            ResponseTimeout, pending=1
                            ESP reported status change
                            M111 P14 S1
                            Debugging enabled for modules: WiFi(14 - 0xffffffff)
                            Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Gcodes(3) Move(4) Heat(5) Dda(6) unused1(7) unused2(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) SbcInterface(16) Can(17)
                            M122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5beta2+ (2023-02-12 12:52:31) running on Duet WiFi 1.02 or later
                            Used output buffers: 1 of 26 (11 max)
                            Static ram: 22216
                            Dynamic ram: 79456 of which 12 recycled
                            Never used RAM 8284, free system stack 184 words
                            Tasks: NETWORK(ready,10.9%,377) ACCEL(notifyWait,0.0%,348) HEAT(notifyWait,0.0%,327) Move(notifyWait,0.0%,361) MAIN(running,87.9%,502) IDLE(ready,1.1%,30), total 100.0%
                            Last reset 00:01:21 ago, cause: power up
                            Last software reset at 2023-02-15 03:34, reason: StuckInSpinLoop, Platform spinning, available RAM 7040, slot 0
                            Software reset code 0x4080 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0040080f BFAR 0xe000ed38 SP 0x20003014 Task NETW Freestk 488 ok
                            Stack: 00414fdf 00459cc2 010f0000 e8000000 400985ff 41c475a6 3edb9368 3331bb4c 40000000 b5ddd8b0 388ab355 bb360b61 3e2aaaab 3f800000 3f800000 41d94ba3 4354c416 41200000 3f800000 80000010 00414fa5 b5ddd8b0 388ab355 20010fbc 3e2aaa01 3f800000 20011248
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            MCU temperature: min 29.3, current 33.6, max 33.8
                            Supply voltage: min 0.3, current 0.5, max 0.5, under voltage events: 0, over voltage events: 0, power good: no
                            Heap OK, handles allocated/used 99/15, heap memory allocated/used/recyclable 2048/384/116, gc cycles 0
                            Driver 5:
                            Driver 6:
                            Driver 7:
                            Driver 8:
                            Driver 9:
                            Driver 10:
                            Driver 11:
                            Cache data hit count 3368987419
                            Slowest loop: 7.82ms; fastest: 0.14ms
                            === Storage ===
                            SD card longest read time 1.0ms, write time 0.0ms, max retries 0
                            === DDARing 0 ===
                            Q0 segments left 0
                            === Network ===
                            Slowest loop: 7.76ms; fastest: 0.00ms
                            = WiFi =
                            WiFi Vcc 3.39, reset reason Power up
                            WiFi flash size 2097152, free heap 45652
                            WiFi signal strength -29dBm, mode 802.11n, reconnections 0, sleep mode modem
                            ok
                            WiFi: <ESC>[0mConns: 0:free, 1:free, 2:free, 3:free, 4:free, 5:free, 6:free, 7:free
                            • OwenDundefined
                              OwenD
                              Some more info this morning.
                              Normally I discover this problem either when I walk out to the garage to get a beer and see the PanelDue flashing ans SPI error, or I can't connect to DWC.
                              This morning I opened my phone (to a previously open tab) and DWC was frozen.
                              When I tried refreshing, it just said connecting and that the drive wasn't mounted.
                              Suspecting an SD card issue, I checked the PanelDue wasn't displaying any errors.
                              Sending M20 resulted in a normal listing, so the SD card has to be mounted.
                              Maybe this is a red herring?
                              DWC from my laptop just doesn't connect. "Can't find host"
                              M20
                              Begin file list
                              random-moves-test.g
                              Outer_Trays_0.2mm_PLA.gcode
                              freak_Pin_0.14mm_PA-CF.gcode
                              Inner_Trays_0.2mm_PLA.gcode
                              SKEW_100mm_0.2mm_PLA.gcode
                              cube_0.2mm_PLA.gcode
                              Freak body large skirt_0.2mm_PA-CF.gcode
                              YACS_0.2mm_PLA.gcode
                              calibration_0.2mm_PLA.gcode
                              monitor-pad-right_0.2mm_PLA.gcode
                              calibration piece _0.2mm_PLA.gcode
                              Box1_0.2mm_PLA.gcode
                              EspChunky_0.2mm_PA-CF.gcode
                              pump-filter_0.2mm_PA-CF.gcode
                              End file list
                              If I send M111 P14 S1, I immediately get a barrage of busy responses in YAT .
                              M111 P14 S1
                              ResponseBusy
                              ResponseBusy
                              ResponseBusy
                              ResponseBusy
                              ResponseBusy
                              ResponseBusy
                              ResponseBusy
                              ResponseBusy
                              ResponseBusy
                              ResponseBusy
                              ResponseBusy
                              ResponseBusy
                              ResponseBusy
                              ResponseBusy
                              ResponseBusy
                              M111 S0
                              ok
                              If I try to do a network scan I get this
                              M587.1
                              Error: M587.1: failed to start scan: another SPI transfer is pending
                                Can you try flashing back to 1.27 and seeing if this still happens? If so, I think it may be the module.
                                • OwenDundefined
                                  OwenD
                                  @Phaedrux
                                  Can't rule out a hardware issue I guess.
                                  Have reverted back to 1.27 and will monitor.
                                  I did an M122 before and after the change.
                                  This is the network section. Note the not ready number and lack of IP address.
                                  === Network ===
                                  Slowest loop: 29273.09ms; fastest: 100.43ms
                                  = WiFi =
                                  Failed messages: pending 0, notready 42217, noresp 1
                                  Socket states: 6 0 0 0 0 0 0 0
                                  After reverting and restart.
                                  = WiFi =
                                  Failed messages: pending 0, notready 0, noresp 2
                                  WiFi flash size 4194304, free heap 24848
                                  WiFi signal strength -35dBm, mode 802.11n, reconnections 0, sleep mode modem
                                  • StreetFurnitureAustraliaundefined
                                    Hi, I have also been getting instability issue with the wifi since going to 3.5.0b1.
                                    The duet will drop off from the network midprint or even not connect at all unless i power it down and then back up.
                                    • OwenDundefined
                                      OwenD @StreetFurnitureAustralia
                                      Are you getting the same SPI timeout messages noted in this thread?
                                      Can you connect via USB and grab the same reports as above?
                                      My error is quite random and very specific.
                                      It has not reappeared since rolling the wifi back to 1.27 but it only happened occasionally so I'm not ready to say it's definitely firmware yet.
                                      StreetFurnitureAustraliaundefined 2 Replies Last reply Reply Quote 0
                                        StreetFurnitureAustralia @OwenD
                                        @OwenD I can't replicate it but when it happens again then I can try and get it.
                                          @OwenD I'm not in the office but a colleague sent me thisreceived_6062637163802703.mp4
                                          As you can see its being spammed
                                          • OwenDundefined
                                            That's the same behaviour
                                            Can you try to get the reports as shown above and then roll the wifi back to 1.2.7
                                            I haven't had a repeat since rolling back but it's infrequent for me, so I can't be sure it's the firmware
                                            StreetFurnitureAustraliaundefined 1 Reply Last reply Reply Quote 0
