    48V Duet3(4?) to complement future Duet Motors?
    Hardware dev
    8
    22
    2.0k
    • TLASundefined
      TLAS
      If it isn’t in the plan, just wanted to plant the seed - it’d be great to have a 48V mainboard to compliment the upcoming duet motors! Running off of a single power supply would be nice, although I can see the point if not having compatible hot end heaters and whatnot.
      dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @TLAS
        @TLAS it already exists: Duet 3 MB6HC version 1.02.
        • T3P3Tonyundefined
          T3P3Tony administrators @TLAS
          @TLAS as @dc42 says v1.02 6HC is 48V as are the latest 3HC. The 1HCL and the larger closed loop motors will also be 48V.
          www.duet3d.com
          juliannundefined 1 Reply Last reply Reply Quote 1
          • jens55undefined
            jens55
            When making the Duet 48V capable, what was the anticipated use case? Was it just for CNC purposes?
            I can see how 48V would be nice for motors but what do you do for hot end heater cartridges. in 3D printers? I have only seen those in 12V and 24V. Do people end up generating 24V externally just for the heaters?
            Are there plans for a 48V 1LC tool board?
            T3P3Tonyundefined o_lampeundefined dc42undefined 3 Replies Last reply Reply Quote 0
            • T3P3Tonyundefined
              T3P3Tony administrators @jens55
              @jens55 for people who want to run motors at higher speeds, they benefit from the higher voltage. I believe there are already 48V heating cartridges available from a few suppliers and we support using 12V fans from the onboard 12V power supply.
              At this point we don't expect a large demand for tool boards in their current formfactor to need to run at 48V.
              Larger machines (the normal use case for 48V) often need multiple power supplies anyway so i expect some configurations for both 24V and 48V in that case
              www.duet3d.com
              • juliannundefined
                juliann @T3P3Tony
                @T3P3Tony When this new Duet motors will be available?
                Thanks!
                • T3P3Tonyundefined
                  T3P3Tony administrators @juliann
                  @juliann we are aiming for Q2 for the first of the range.
                  www.duet3d.com
                  juliannundefined 1 Reply Last reply Reply Quote 0
                  • juliannundefined
                    juliann @T3P3Tony
                    @T3P3Tony Thanks, that's great, where can I get more information about them? is a brochure available?
                    • T3P3Tonyundefined
                      @juliann I will announce more on the forum when its available.
                      www.duet3d.com
                      • o_lampeundefined
                        o_lampe @jens55
                        @jens55 said in 48V Duet3(4?) to complement future Duet Motors?:
                        In config.g you can reduce the power for a 24V heater cartridge to 0.5. That's what was done in early FDM days, when the 24V controller boards where new and 12V cartridges were the only available ones.
                          jay_s_uk @o_lampe
                          @o_lampe but thats definitely NOT recommended as you're still feeding 48v to the cartridge!!!!
                          o_lampeundefined 1 Reply Last reply Reply Quote 1
                          • o_lampeundefined
                            o_lampe @jay_s_uk
                            @jay_s_uk The heater is just a resistor with a max. power value.
                            It doesn't care about voltage so much when the duty cycle is limited to 50%.
                            Maybe PID tuning is difficult?
                            • oliofundefined
                              oliof @o_lampe
                              @o_lampe Ohm's Law tells me you'd need to go to PWM 0.25 at a maximum, and I am still with @jay_s_uk that it bears considerable risk.
                              o_lampeundefined 1 Reply Last reply Reply Quote 3
                                dc42 administrators @jens55
                                @jens55 it's possible to buy 48V cartridges to fit hot ends that use cartridges.
                                oliofundefined 1 Reply Last reply Reply Quote 1
                                • oliofundefined
                                  oliof @dc42
                                  @dc42 I would still suggest to get more current on the 12V rail in a future revision, BTT boards like the Octopus allow 4 / 8 A on 12V.
                                  dc42undefined 1 Reply Last reply Reply Quote 2
                                    dc42 administrators @oliof
                                    @oliof we'd like to do that but it's expensive to generate 12V from 48V and also difficult to meet FCC and CE EMC regulations. I don't think any other boards support 48V input without requiring a separate 24V input to power the lower voltage components.
                                      jay_s_uk @dc42
                                      @dc42 thats correct. all the other boards require a 24v input to generate the lower voltages with 48v only used to drive the motors
                                      • o_lampeundefined
                                        o_lampe @oliof
                                        @oliof I agree about ohm's law telling us to use only 25% duty cycle. My mistake!
                                        I've use a 12V bed heater at 24V without problems using this method, but overpowering a cartridge might be a different story.
                                        Just wanted to point out, that a resistor doesn't have a voltage limit per se.
                                        oliofundefined 1 Reply Last reply Reply Quote 2
                                        • o_lampeundefined
                                          o_lampe @jay_s_uk
                                          @jay_s_uk
                                          What about using a big 24V PSU and feed the motors from a DC-DC boost converter?
                                          I'm using a few different boost converters for several tasks and they never failed me so far. ( 100W - 600W are cheaper than a second PSU)
                                            jay_s_uk @o_lampe
                                            @o_lampe that may work assuming the boost converter and PSU can handle it.
                                            For my voron 2.4 i went with a separate 48v PSU. The LRS-200-48 aren't very expensive https://www.printyplease.uk/LRS20048?search=48v
