    BLtouch not retracting
    2.8k
    • iamthebest22undefined
      iamthebest22
      Hello all, I thought it was a defective BLtouch so I had it replaced, but then the same thing is still happening. Basically on startup, the BLtouch would extend the pin, but not able to retract it, and then give the alarm. I can turn off the alarm, and I am certain my wires are wired correctly. I did this at first without cutting the logic, then cutting the 3.3V logic on the BLtouch (newest smart version). However, when I connected the BLtouch to my TEVO tornado (which has another BLtouch) to check, it works perfectly and can extend and retract. I have checked my retractprobe.g file, and it is just the code as written in the wiki which is M280 P3 S90 I1. Here is my config.g file:
      ; Configuration file for Duet WiFi (firmware version 1.17)
      ; generated by RepRapFirmware Configuration Tool on Sun Oct 08 2017 12:13:50 GMT-0500 (Central Daylight Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M667 S1 ; Select CoreXY mode
      M208 X300 Y300 Z260 S0 ; Set axis maxima
      M574 Z0 S0 ; Define active low and unused microswitches
      M574 X1 Z0 Y1 S1 ; Define active high microswitches
      M558 P5 X0 Y0 Z1 H5 F100 T2000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
      G31 X27.25Y0 Z1.20 P25 ; Set Z probe trigger value, offset and trigger height
      M557 X15:285 Y15:285 S20 ; Define mesh grid
      M92 X80.84 Y80.84 Z400 E804 ; Set steps per mm
      M203 X18000 Y18000 Z180 E1200 ; Set maximum speeds (mm/min)
      M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X1500 Y1500 Z1200 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S280 ; Set maximum heater temperature to 280C
      M563 P0 D0 H1 ; Define tool 0
      M550 PHEVO (Hypercube Evolution) ; Set machine name
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M307 H3 A-1 C-1 D-1 ;
      T0
      I have also tried changing M558 P5 X0 Y0 Z1 H5 F100 T2000 to M558 P4 X0 Y0 Z1 H5 F100 T2000 and connected the white and black to the E0 Endstop but still the same thing. At an absolute loss now what to do. The coding and wiring all seem correct. I'm wondering if I have a defective Duet Wifi (it did have the reporting the 24V from PS as 29V issue before, so the Power SUpply is currently at 21V, but duet wifi reports as 24V)
      • number40fanundefined
        number40fan
        Just a quick glance over your config and I see a double up of the M574.
          iamthebest22
          Oh which one should I delete? or modify?
          EDIT: I deleted the z0 in the second M574 but still same thing, here is an update though on when I turn off the alarm and try the self test. it extends the pin and the z probe says 0, however, I push the pin to retract it, the z probe still says 0 instead of 1000 (meaning it's retracted). I then try the same thing but then run the gcode command to retract, the red light quickly flashes twice, then goes into alarm mode because it can't retract it.
          Another interesting to note is that if I set the BLtouch horizontally instead of vertically, it can then retract the pin but still gives alarm. However as I've mentioned before the BLtouch works perfectly fine on my TEVO Tornado.
          • Scachiundefined
            Scachi
            I followed this guide to get my BLTouch smart working:
            https://betrue3d.dk/bltouch-on-duet-wifi-duetreprapfirmware
            Maybe you are missing the 5v connection for powering your BLtouch and you are using 3.3v instead ?
              iamthebest22
              Hmm read through most of it and noticed some interesting things. Unfortunately it's almost midnight here, and I have work tomorrow so can't try it until I get back from home tomorrow but I will try some of the things mentioned in there and see how it goes and will then update.
              Btw I tried both the 5V and the 3.3V to the red on the BLtouch, same thing.
                Are you running with external power applied to the Duet and the internal 5V regulator enabled? If you are providing USB power only, there may be insufficient voltage or current on the 5V rail to power the Bltouch.
                  iamthebest22
                  No I'm using the 24V power supply (currently at 21V because of the weird problem of the Duet reporting 4V higher than it actually is while multimeter confirmed PS is supplying 24V). What is the internal 5V regulator and how do I check if it is enabled? xD. Not using the USB at all.
                  EDIT: Checked and the jumper is set to enable the internal 5V supply.
                    If the Duet is reporting 24V when VIN is only 21V, that suggests to me that your 3.3V rail is only at 2.9V which is out of tolerance. Have you measured it? Is the 3.3V regulator on the Duet getting hot? What external devices are you powering from 3.3V?
                      iamthebest22
                      Hi dc42 apologies for the long wait, was at work and my multimeter ran out of juice (I forgot to turn it off from something I was using). You are right, I think I may have a defective unit (would like your confirmation though). I mentioned the 5V AND 3.3V. The 5V was worst, my Multimeter says only 2.8-2.9V was coming out of them (all the 5V I can test on the board) and also for the 3,3V it's reporting only 2.7-2.8V. Where is the 3.3V regulator on the duet? I don't know where it is, but I touched all the chips on the board and with my laser temp sensor and none seem to be 40C. Right now since it's for my HEVO, just the usual 5 stepper motors, the heatbed, nozzle, fan, etc. and they aren't being used.
                        If the 5V is only reporting 2.7-2.8V that explains why the 3.3V rail is low, because the 3.3V rail is derived from the 5V rail. Please disconnect your BLtouch, also disconnect PanelDue if you have one connected, then power up and measure the 5V rail again. If it's still at 2.8-2.9V, ask for your Duet to be replaced.
                          iamthebest22
                          Thanks dc42. Just disconnected literally everything almost (except the stepper motors as I don't think they make that much of a difference especially when they aren't being used). Tested all the 5V again, this time it's pretty much the same, 2.85 V for the 5V and 2.76V for the 3.3V. I'll provide the pics as proof but since I bought it from spool3d, I'll contact them and supply the proof and they should offer me a replacement?
                          Man my luck with electronics…
                            I'm sorry, it does appear that you have received a faulty Duet. Spool3D, please replace it under warranty.
                              iamthebest22
                              Np np dc42 at least it's solved now, here is a link of the pics/vids that I took as proof. https://www.dropbox.com/sh/umybmf99e6ixpkr/AADDpfFzZDImk8G-eTygOleGa?dl=0 a lot so I put them in a folder, hope that's okay.
                              • peirofundefined
                                peirof
                                What's the problem? And how solved?
