    Filament monitoring while printing via USB
    Beta Firmware
    1.7k
    • benecitoundefined
      benecito @jay_s_uk
      @jay_s_uk But that's my point - even when connected to the mainboard sensors.filamentMonitors[0].status will stay at "ok" when I run out of filament
        jay_s_uk @benecito
        @benecito that may be a bug then. what firmware version are you running?
        benecitoundefined 1 Reply Last reply Reply Quote 0
        • benecitoundefined
          benecito @jay_s_uk
          @jay_s_uk 3.5.0 beta 3
          • Phaedruxundefined Phaedrux moved this topic from Firmware wishlist
          • timoschuettundefined
            timoschuett
            Hi, are there any updates on how to enable filament monitoring while printing via usb? Is there a new enable mode which needs to be used?
            Thanks, Timo
            jay_s_ukundefined T3P3Tonyundefined benecitoundefined 3 Replies Last reply Reply Quote 0
              jay_s_uk @timoschuett
              @timoschuett you use S2 in M591 https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m591-configure-filament-sensing
              only supported in 3.5RC1 and newer
              • T3P3Tonyundefined
                T3P3Tony administrators @timoschuett
                @timoschuett see the M591 documentation:
                The S2 parameter.
                www.duet3d.com
                • benecitoundefined
                  benecito @timoschuett
                  @timoschuett please be aware it does not really work yet.
                    jay_s_uk @benecito
                    @benecito have you reported any problems with it that you're having?
                    • benecitoundefined
                      benecito @jay_s_uk
                      @jay_s_uk we're in contact and diagnosing the issue yes
                        timoschuett
                        Thank you guys! I must been blind while reading the wiki earlier, have not found anything about it. Now i`ve found it 🙂
                        @benecito what exactly "does not really work yet" ?
                          dc42 administrators @timoschuett
                          @timoschuett we have one user (only one AFAIK) who has an intermittent issue with a filament monitor connected to a Duet 3 Mini. Apart from that, I believe all the outstanding issues have been addressed in the 3.5.0-rc.1+ firmware builds, which are available at https://www.dropbox.com/scl/fo/tjznycpk7bv7sj71p0ssl/h?rlkey=096p4nvgmigyrb20jj8olg3wu&dl=0.
                          timoschuettundefined 1 Reply Last reply Reply Quote 1
                            timoschuett @dc42
                            @dc42 Perfekt, sounds promising. I will give it a try on monday 🙂
