Never Printing Flat
Hi All,
I was just wondering if anyone would be able to help me.
I can never seem to get a nice flat initial printing layer, I have EZABL and have calibrated it as the guide says.
I have been going at this for around a month now and I cannot seem to get a good first layer, one side of my print is too close to bed and the other is too far away,
I then had the idea to do some Z probes around the bed to see what the variation was. Please see my attached readouts from both left and right-hand sides. Does anyone know what is causing this, and if so, how would I fix it and ensure that my probing figures are correct all around my plate?
Thank you.
That's a pretty big difference in trigger height. That may indicate the probe is tilting as it moves in XY.
What kind of printer is this? Can you give some more details? How is the Z axis arranged? How do you home? Are you doing manual leveling as well?
How is the probe mounted?
Please share your config.g, homing files, and bed.g
Please send M122 and M98 P"config.g" and copy and paste the results here.
@Phaedrux Hi there,
Yes, I thought the same!! This is my own built 3D printer and the layout of the Z axis is a triangular shape using 3 lead screws at each point in a symmetrical triangle. I don't think it's the probe as the probe cable is fixed locally to it ensuring it is static. I home XY at end of travel and Z in the centre of the bed. The probe is mounted using its standard hole mount with 2 nuts.
Would ABL solve this? or even true bed levelling?
Home all code:
G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-555 Y-415 F1800 ; move quickly to X or Y endstop and stop there (first pass) G1 H1 X-555 ; home X axis G1 H1 Y-415 ; home Y axis G1 X5 Y5 F6000 ; go back a few mm G1 H1 X-555 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Y-415 ; then move slowly to Y axis endstop G90 ; absolute positioning G1 X270 Y180 F6000 ; go to first bed probe point and home Z ;G1 X-20 Y10 F6000 ; go to first bed probe point and home Z G30 ; home Z by probing the bed
config.g
G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Printer" ; set printer name M669 K1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M569 P4 S0 ; physical drive 4 goes forwards - E1 M584 X0 Y1 Z2:5:4 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z1066.67 E446.8 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X1500 Y1500 Z1500 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X550 Y410 Z500 S0 ; set axis maxima ; Endstops M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M558 P1 C"!zprobe.in" H10 F240 T6000 ; set Z probe type to unmodulated and the dive height + speeds G31 P500 X35 Y0 Z5.7 ; set Z probe trigger value, offset and trigger height M557 X15:525 Y10:400 S50 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 R0.310 K0.291:0.000 D1.41 E1.35 S1.00 B0 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S300 ; set temperature limit for heater 1 to 300C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 S"MATERIAL 1" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 S"MATERIAL 2" D0 H1 F0 ; define tool 1 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
bed.g
G28 ; home G30 P0 X50 Y410 Z-99999 ; probe near a leadscrew, half way along Y axis G30 P1 X550 Y410 Z-99999 ; probe near a leadscrew and calibrate G30 P2 X275 Y3 Z-99999
M122:
=== Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.4 (2022-10-20 16:17:41) running on Duet WiFi 1.02 or later Board ID: 08DGM-917NK-F23T0-6JKDJ-3SD6N-TDBJF Used output buffers: 1 of 26 (13 max) === RTOS === Static ram: 23860 Dynamic ram: 75216 of which 0 recycled Never used RAM 12932, free system stack 116 words Tasks: NETWORK(notifyWait,14.0%,237) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,294) MAIN(running,85.9%,458) IDLE(ready,0.1%,30), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:37:27 ago, cause: software Last software reset at 2023-01-30 21:01, reason: User, GCodes spinning, available RAM 12932, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Step timer max interval 0 MCU temperature: min 33.0, current 34.6, max 37.3 Supply voltage: min 23.9, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0 Driver 1: standstill, SG min 0 Driver 2: standstill, SG min 0 Driver 3: standstill, SG min n/a Driver 4: standstill, SG min 0 Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 2023-01-30 21:39:08 Cache data hit count 4294967295 Slowest loop: 34.57ms; fastest: 0.18ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 7.7ms, write time 1.1ms, max retries 0 === Move === DMs created 83, segments created 3, maxWait 418264ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 250, completed 250, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Network === Slowest loop: 97.08ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.27 WiFi MAC address b4:e6:2d:53:0c:f9 WiFi Vcc 3.37, reset reason Turned on by main processor WiFi flash size 4194304, free heap 24528 WiFi IP address 192.168.1.247 WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
M98 Returns an error?
M98 Error: M98: No P or R parameter
Thank you for your help, any help in getting to the bottom of this would be greatly appreciated.
Kind Regards,
Adam -
@Phaedrux said in Never Printing Flat:
M98 P"config.g"
Have you tried setting up automatic leveling?
https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_auto_levelling
@Phaedrux oooh, what does M98 do?
Is automatic levelling different to ABL? Like the one seen in my bed.g file?
@Adam_Sw3 said in Never Printing Flat:
what does M98 do?
It calls a macro to run. M98 P"config.g" will call config.g to run as it does on startup, but since the system is already running it can catch syntax errors that might otherwise get missed at startup.
No its the same thing but your bed.g appears to be missing the S parameter on the last probe point to do the calculation, but maybe that's just a copy and paste error?
This post is deleted! -
@Phaedrux Thank you for this! I will read through the documentation! Hopefully this should solve it!
@Phaedrux Hi There, I have just had a crack at this tonight and I am getting an error "Some computed corrections exceed configured limit of 0.50mm: -0.487 5.186 -8.188" I understand that this is out of the tolerance for the machine to avoid it damaging itself.
I am thinking that the way I have wired it up may be the issue, 2 Z's are connected to both Z drivers. and the other "Z driver" is connected to E0. I, therefore, believe the 2 Z's arent independent. Is this the case or are they individually addressable?
Thank you.
You can adjust the tolerance in the M671 S parameter.
@Phaedrux to like +-10mm?! Are the dual Z's independent?
to like +-10mm?!
Well you'll have to determine what a safe amount of movement is to prevent damage. However, the whole point of the feature is to reduce the difference between the points, so it should be bringing things closer to spec.
I would suggest trying 2 or 3mm and manually leveling the sides to begin with. Then there shouldn't be much of a difference between the sides and only a small amount of correct would be needed.
I'm not exactly sure I follow. Which motors are wired where? The Z driver on the Duet 2 board is a single driver. The two ports for that driver are wired in series. So to use independent control each motor must have it's own driver.
From your config.g I see your driver mapping is a little wrong.
There are only 5 drivers on the Duet, but you have 6 mapped. There is no driver 5, only 0,1,2,3,4.
So you can't actually do 3 motor leveling (and still have an extruder) on a duet 2 without either a Duex or external driver expansion.
@Phaedrux Ohhhhh!! I am misunderstood sorry about that. Yes it is massively better now thank you and watching it in action is extremely awesome!
Yes my fault, I don't know why I stuck 5 in there!! I have since removed that now. Thanks for your help!
Cheers!
Well how many Z motors do you have?
