    M671 like function for Delta printer
    Gcode meta commands
    1.2k
    • OwenDundefined
      OwenD @tecno
      @tecno
      I'm going to have to eat my words on this one.
      There does indeed seem to be some sort of issue with saving echo commands that are not sent from the DWC channel.
      I tried putting M118 in the macro as well with no joy.
      Your only option at this point is to use echo to write to the file directly from the macro.
      echo >"0:/sys/savedData.txt"
      G30 S-1 ; do probe at current point
      echo >>"Stopped at height " ^ move.axes[2].machinePosition ^ "mm"
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @OwenD
        @OwenD
        Trying this
        M562                    ; clear any bed transform from mesh leveling
        G1 Z50 F4000
        G1 X0 Y0				; 1 point
        G30 S-1
        echo >>"Stopped at height" ^ move.axes[2].machinePosition ^ "mm"
        And get this error:
        M98 P"0:/macros/test"
        Stopped at height 0.758 mm
        Error: in file macro line 7 column 28: meta command: expected an expression
        Above creates 2 empty files
        OwenDundefined dc42undefined 2 Replies Last reply Reply Quote 0
        • OwenDundefined
          OwenD @tecno
          @tecno
          Apologies.
          Should have had the filename in both echo commands.
          echo >>"0:/sys/savedData.txt" "Stopped at height " ^ move.axes[2].machinePosition ^ "mm"
          • tecnoundefined
            tecno @OwenD
            @OwenD
            No reason to apoligise, I am thankful for all help I can get.
            Now I get these values in txtfile, they also show up in console but nothing can be done there.
            How to save the file so it can be exported as CSV directly from console.
            OwenDundefined 1 Reply Last reply Reply Quote 0
            • OwenDundefined
              OwenD @tecno
              @tecno
              I'm not sure I understand what you are looking for.
              The use of the echo command is detailed here
              https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands#echo-command
              If you want each probe point on a single line then use three > symbols
              echo >"0:\sys\testFile.csv" "Test1,Test2,Test3,Test4,Test5,"
              while iterations < 5
                 G30 S-1
                 echo >>>"0:\sys\testFile.csv" move.axes[2].machinePosition  ^ ","
              The resulting file will be something like
              1.388,1.595,1.595,2.015,2.213,
              • tecnoundefined
                tecno @OwenD
                @OwenD
                Error: in file macro line 8 column 8: meta command: expected string expression
                achrnundefined 1 Reply Last reply Reply Quote 0
                • achrnundefined
                  achrn @tecno
                  @tecno said in M671 like function for Delta printer:
                  @OwenD
                  None of the macro extracts you've posted in teh thread recently even have an eighth line. What does line 8 of the macro file say?
                  • tecnoundefined
                    tecno @achrn
                    @achrn
                    echo >>>"0:\sys\testFile.csv" ^ move.axes[2].machinePosition ^ ","
                    • achrnundefined
                      achrn @tecno
                      @tecno https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands#echo-command says >>> is only supported in firmware 3.5beta2 and later, what are you running?
                      • tecnoundefined
                        tecno @achrn
                        @achrn
                        3.4.5 and nobody has said this before.
                        It runs now but still I need to get correct syntax for the csv file for all results on same line.
                        echo >>"0:\sys\testFile.csv" {move.axes[2].machinePosition} ,","
                        point1,point2,point3,point4
                        0.858 ,
                        0.824 ,
                        1.322 ,
                        0.821 ,
                        • achrnundefined
                          achrn @tecno
                          @achrn
                          Well, it's been in the docs a while, I think.
                          I don't think you can, working it in a loop like that. you could dump the loop and do five separate probes storing in single variables then write to file with a single line, I think. e.g.
                              G30 S-1  ; probe
                              set var.z1 = move.axes[2].machinePosition ; memorise probe position
                              G30 S-1
                              set var.z2 = move.axes[2].machinePosition
                              G30 S-1
                              set var.z3 = move.axes[2].machinePosition
                              G30 S-1
                              set var.z4 = move.axes[2].machinePosition
                              G30 S-1
                              set var.z5 = move.axes[2].machinePosition
                             echo >>"0:\sys\testFile.csv" "whatever", var.z1,  var.z2, var.z3, var.z4, var.z5
                          • tecnoundefined
                            tecno @achrn
                            @achrn
                            OK, will play with your suggestion and see the results.
                            • tecnoundefined
                              tecno @tecno
                              M98 P"0:/macros/test var.g"
                              Stopped at height 0.708 mm
                              Error: in file macro line 7 column 13: meta command: unknown variable 'z1'
                              G28
                              G1 Z50 F4000
                              G1 X0 Y0				; 1 point
                              G30 S-1
                              G1 Z50 F4000
                              G1 X-154 Y-164 F4000    ; 2 point
                              G30 S-1
                              G1 Z50 F4000
                              G1 X-63 Y214 F4000      ; 3 point
                              G30 S-1
                              G1 Z50 F4000
                              G1 X217 Y-52 F4000      ; 4 point
                              G30 S-1
                              G1 Z50 F4000
                              G28
                              • achrnundefined
                                achrn @tecno
                                Well yes, you need to initialise the variables.
                                var z1 = 0
                                var z2 = 0
                                var z3 = 0
                                var z4 = 0
                                var z5 = 0
                                before you first refer to any of them.
                                • tecnoundefined
                                  tecno @achrn
                                  @achrn said in M671 like function for Delta printer:
                                  var z1 = 0
                                  var z2 = 0
                                  var z3 = 0
                                  var z4 = 0
                                  var z5 = 0
                                  Works like a charm now!
                                  Is there a way to replace "whatever" with date + time?
                                    dc42 administrators @tecno
                                    Should be:
                                    echo >>"0:/sys/savedData.txt" "Stopped at height" ^ move.axes[2].machinePosition ^ "mm"
                                    i.e. you need to specify the filename again.
                                    Instead of using move.axes[2].machinePosition I suggest you use sensors.probes[0].lastStopHeight as I suggested earlier.
                                    tecnoundefined 1 Reply Last reply Reply Quote 1
                                    • tecnoundefined
                                      tecno @dc42
                                      This is what works now, only missing part is date/time stamp.
                                      ; test var.g macro
                                      datetime 0.758 1.074 1.122 0.821
                                      datetime 0.708 1.074 1.022 0.771
                                      G28
                                      var z1 = 0
                                      var z2 = 0
                                      var z3 = 0
                                      var z4 = 0
                                      G1 Z50 F4000
                                      G1 X0 Y0				; 1 point
                                      G30 S-1
                                      set var.z1 =  sensors.probes[0].lastStopHeight
                                      G1 Z50 F4000
                                      G30 S-1
                                      set var.z2 = sensors.probes[0].lastStopHeight
                                      G1 Z50 F4000
                                      G30 S-1
                                      set var.z3 = sensors.probes[0].lastStopHeight
                                      G1 Z50 F4000
                                      G30 S-1
                                      set var.z4 = sensors.probes[0].lastStopHeight
                                      G1 Z50 F4000
                                      echo >>"testFile.csv" "datetime", var.z1, var.z2, var.z3, var.z4
                                      G28
                                      • achrnundefined
                                        achrn @tecno
                                        echo >>"testFile.csv" state.time, var.z1, var.z2, var.z3, var.z4
                                        • tecnoundefined
                                          tecno @achrn
                                          @achrn
                                          Is there a way to format output to 0,000 and not 0.000 as this is a language problem?
                                            @tecno if the format is CSV then you must use '.' as the decimal separator character, because ',' is used to separate one field from the next. The program you use to import the .csv file should recognise '.' as the decimal separator.
