    Slow upload and then failure.
    Duet Web Control
    1.4k
    • infiniteloopundefined
      infiniteloop @TheBasedDoge
      @TheBasedDoge said in Slow upload and then failure.:
      Well, i could try that first. Did it work out well for you?
      Yep. I built my Duet into a modded Apple G4 casing - internally, that has a solid metal cage, but I re-used Apple's WiFi antennas: works flawlessly since 2019 😊
      Also yes I have tried another SD card.... no change.
      Sorry to hear that.
      TheBasedDogeundefined 1 Reply Last reply Reply Quote 0
      • TheBasedDogeundefined
        TheBasedDoge @infiniteloop
        @Phaedrux
        Good idea, i will try AP mode and see what happens before I try anything with the wifi card
        @infiniteloop
        Ok, I have to see a photo of the G4 Duet now lol. Also which trace did you cut? i could not tell from your photo.
        infiniteloopundefined 2 Replies Last reply Reply Quote 0
          @TheBasedDoge
          Promised. Will try to take some shots… if that works in the darkness over here.
          Back in 2019, I found this on the web: ESP mit externer WLAN Antenne. You don't need a translator to understand, just look at this image from that post:
            @TheBasedDoge
            TheBasedDogeundefined 1 Reply Last reply Reply Quote 1
              @infiniteloop
              Wow, that is awesome. I love those mac case mods.
              @Phaedrux
              Ok, so AP mode has the following result
              • With a computer 1ft away from the printer I was able to upload a file no problem, it maxed out 400kib/s. I only tried one time but it worked the first time.
              • With my desktop PC that I normally use in the next room over, it took several minutes to even bring up DWC. i started a transfer and it's going at like 30 kib/s at most, and finally failed. WifiInfoView shows me signal strength is -67db.
              So yeah... I guess it's just a crap antennae?
                I mean, -67db isn't that bad really. Not amazing, but not great.
                What did the computer right next to it get for signal strength?
                The fact it worked properly on the near computer at least lets us know the hardware is working and points to where the issue is.
                If you wanted to try the antenna mod, that's up to you, but would definitely void any warranty you may have remaining. (6 months from purchase)
                How is the Duet mounted? Is there any metal near the antenna?
                  TheBasedDoge @Phaedrux
                  @Phaedrux I bough this duet in 2017 .... so I guess any warranty is already gone.
                  The nearby PC is showing -29DB.
                  I guess -67 isn't that bad.. but then why wouldn't it be able to upload any files?
                  Duet is in a 3D printed case at the bottom of the printer (open frame design) There is no metal really near it at all.
                  Also its showing the AP mode hotspot as a wireless B device.... is that even right?
                    TheBasedDoge @TheBasedDoge
                    Well, I found necessary parts in my parts pile and did the antennae mod last night and it worked!
                    -52db, and most importantly the file is uploading and not failing. speed is also as high as I have ever seen with up to 1mb/s but average around 500-700ish.
                    Still strange why I had to do this because it worked fine before. the wifi access point is literally less than 25ft away with almost direct line of sight, so i don't really get it.
                    Well, one problem solved (for now). hopefully stays working.
                    infiniteloopundefined 1 Reply Last reply Reply Quote 3
                      Your soldering looks better than mine 😊 - Glad to hear that the mod worked for you👍
                      • T3P3Tonyundefined T3P3Tony marked this topic as a question
                      • T3P3Tonyundefined T3P3Tony has marked this topic as solved
