    WIFI Antenna Mounting
    391
    • SonnyD1undefined
      SonnyD1
      Does the external wifi antennal for a Duet2 wifi have to be grounded? What I mean to say is, is it ok being mounted to a plastic part vs the frame of the printer? I'm having some wifi module issues that I'm attempting to isolate. TYIA!
        I don't think so. What issues are you having?
        SonnyD1undefined 2 Replies Last reply Reply Quote 0
        • SonnyD1undefined
          SonnyD1 @Phaedrux
          @Phaedrux My wifi Module only seems to start up when it feels like it. I've updated the Wifi Module itself, the paneldue as well as the board. Its inconsistent so I'm trying to figure out what could be contributing to the issue. And I have the M552 in the config too.
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S1 ; enable FTP
          M586 P2 S0 ; disable Telnet
          M575 P1 B57600 S1 ; enable support for PanelDue
            Please share the results of M122 when you are connected.
            SonnyD1undefined 1 Reply Last reply Reply Quote 0
            • SonnyD1undefined
              SonnyD1 @Phaedrux
              @Phaedrux I just discovered the weirdest thing. What would my U endstop have to do with my WIFI and wether the other axis home? Do I have a short somewhere? Everything works as long as my U axis endstop is triggered. Nothing works if it isnt. That includes homing and my wifi module.
              • SonnyD1undefined
                SonnyD1 @Phaedrux
                @Phaedrux
                Send code...
                2/23/2023, 4:20:40 PM M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later + DueX5v0.11
                Board ID: 0JD0M-9P6B2-NJ4S4-6JKFJ-3SJ6Q-T82AK
                Used output buffers: 1 of 26 (24 max)
                Static ram: 23836
                Dynamic ram: 76448 of which 0 recycled
                Never used RAM 11796, free system stack 174 words
                Tasks: NETWORK(ready,13.5%,242) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) DUEX(notifyWait,0.0%,24) MAIN(running,86.1%,438) IDLE(ready,0.3%,30), total 100.0%
                Owned mutexes: WiFi(NETWORK)
                Last reset 00:03:54 ago, cause: power up
                Last software reset at 2023-02-23 16:02, reason: User, GCodes spinning, available RAM 11796, slot 1
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                Error status: 0x00
                Aux0 errors 0,0,0
                Step timer max interval 0
                MCU temperature: min 35.2, current 39.8, max 40.1
                Supply voltage: min 23.9, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                Events: 0 queued, 0 completed
                Driver 0: standstill, SG min n/a
                Driver 1: standstill, SG min n/a
                Driver 2: standstill, SG min n/a
                Driver 3: standstill, SG min n/a
                Driver 4: standstill, SG min n/a
                Driver 5: standstill, SG min n/a
                Driver 6: standstill, SG min n/a
                Driver 7: standstill, SG min n/a
                Driver 8: standstill, SG min n/a
                Driver 9: standstill, SG min n/a
                Driver 10:
                Driver 11:
                Date/time: 2023-02-23 16:20:37
                Slowest loop: 11.39ms; fastest: 0.18ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 3.2ms, write time 0.0ms, max retries 0
                DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                === MainDDARing ===
                === AuxDDARing ===
                Heater 1 is on, I-accum = 0.0
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                Daemon is idle in state(s) 0
                Code queue is empty
                === DueX ===
                Read count 1, 0.26 reads/min
                === Network ===
                Slowest loop: 41.63ms; fastest: 0.00ms
                Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                HTTP sessions: 1 of 8
                = WiFi =
                Network state is active
                WiFi firmware version 1.26
                WiFi MAC address f4:cf:a2:68:3b:2f
                WiFi Vcc 3.38, reset reason Power up
                WiFi flash size 2097152, free heap 18872
                WiFi IP address 192.168.1.243
                WiFi signal strength -41dBm, mode 802.11n, reconnections 0, sleep mode modem
                Clock register 00002002
                  Phaedrux Moderator @SonnyD1
                  @SonnyD1 said in WIFI Antenna Mounting:
                  Seems that way.
                  Post your config.g and the results of M98 P"config.g" as well please.
                    I think you're one version out of date. Please upload this zip file to the system tab in DWC.
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
                    • SonnyD1undefined
                      SonnyD1 @Phaedrux
                      @Phaedrux ; Configuration file for Duet WiFi (firmware version 3.3)
                      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Feb 19 2023 17:01:06 GMT-0500 (Eastern Standard Time)
                      G21 ; work in milimeters
                      M550 P"IDEX" ; set printer name
                      M111 S0 ; debug off
                      M569 P0 S1 ; physical drive 0 goes forwards - X stepper
                      M569 P1 S1 ; physical drive 1 goes forwards - Z stepper (left)
                      M569 P2 S1 ; physical drive 2 goes forwards - Z stepper (right)
                      M569 P3 S1 ; physical drive 3 goes forwards - E0 stepper
                      M569 P6 S1 ; physical drive 6 goes forwards - Y stepper (left)
                      M569 P7 S0 ; physical drive 7 goes backwards - Y stepper (right)
                      M569 P8 S1 ; physical drive 8 gows forwards - U stepper
                      M569 P9 S1 ; physical drive 9 goes forwards - E1 stepper
                      M584 X0 Y6:7 Z1:2 U8 E3:9 ; set drive mapping
                      M350 X16 Y16 Z16 U16 E16:16 I1 ; configure microstepping with interpolation
                      M92 X80.00 Y80.00 Z800.00 U80.00 E400.00:400.00 ; set steps per mm
                      M566 X900.00 Y900.00 Z60.00 U900.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min) - jerk
                      M203 X6000.00 Y6000.00 Z180.00 U6000.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
                      M201 X500.00 Y500.00 Z20.00 U500.00 E250.00:250.00 ; set accelerations (mm/s^2)
                      M906 X2300 Y2300 Z2300 U2300 E600:600 I30 ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      M208 X-26 Y0 U10 Z0 S1 ; set axis minima
                      M208 X290 Y300 U330 Z300 S0 ; set axis maxima
                      M574 X1 S1 P"e1stop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin e1stop
                      M574 U1 S1 P"exp.e6stop" ; configure switch-type (e.g. microswitch) endstop for high end on U via pin exp.e6stop
                      M574 Y1 S1 P"exp.e5stop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin exp.e5stop
                      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                      ; M591 D0 P1 C"xstop" S1 ; configure filament monitor for E0
                      ; M591 D1 P1 C"exp.e4stop" S1 ; configure filament monitor for E1
                      ; BLTouch
                      M950 S0 C"duex.pwm1" ; create servo pin 0 for BLTouch
                      M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch, connected to zprobe.in and the dive height + speeds
                      G31 P500 X-31 Y-14.5 Z2.5 ; set Z probe trigger value, offset and trigger height
                      M557 X20:270 Y20:280 S50 ; define mesh grid
                      M308 S0 P"duex.e4temp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin duex.e4temp
                      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                      M143 H1 S300 ; set temperature limit for heater 1 to 300C
                      M308 S2 P"duex.e3temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin duex.e3temp
                      M950 H2 C"duex.e6heat" T2 ; create nozzle heater output on duex.e6heat and map it to sensor 2
                      M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                      M143 H2 S300 ; set temperature limit for heater 2 to 300C
                      M950 F2 C"duex.fan3" Q500 ; create fan 2 on pin duex.fan3 and set its frequency
                      M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off
                      M950 F3 C"duex.fan4" Q500 ; create fan 3 on pin duex.fan4 and set its frequency
                      M106 P3 S1 H2 T45 ; set fan 3 value. Thermostatic control is turned on
                      M563 P0 D0 H1 F0 ; define tool 0 that used low end X carriage
                      G10 P0 X-26 Y0 Z0 ; set tool 0 axis offsets
                      M563 P1 D1 H2 F2 ; define tool 1 that used high end U carriage
                      G10 P1 X359 Y0 Z0 ; set tool 1 axis offsets
                      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
                      • SonnyD1undefined
                        SonnyD1 @Phaedrux
                        @Phaedrux said in WIFI Antenna Mounting:
                        M98 P"config.g"
                        2/23/2023, 4:25:34 PM M98 P"config.g"
                        HTTP is enabled on port 80
                        FTP is enabled on port 21
                        TELNET is disabled
                        • SonnyD1undefined
                          SonnyD1 @Phaedrux
                          DONE!
                            Your endstops are on the duex5 correct, not just the bare expansion header?
                            Instead of exp.e6stop use duex.e6stop for example.
                            https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#pin-names
                            • SonnyD1undefined
                              SonnyD1 @Phaedrux
                              Thank you...Thats done. I think we've managed to get off topic trying to fix this thing. We can call this solved and I can start another thread if you'd like. I think we've established that it was not the wifi antenna mounting causing my issues.
                                Did you identify the short?
                                • SonnyD1undefined
                                  SonnyD1 @Phaedrux
                                  @Phaedrux Yes I found it. I had two wires swapped on the U axis endstop. Thank you very much. I'm still not up and running but its progress. WIFI Module fires right up now.
                                  • SonnyD1undefined SonnyD1 has marked this topic as solved
