    Firmware update failed
    Firmware installation
    431
    • patterson6undefined
      patterson6
      I tried updating firmware to 3.4.4 from 3.2.0 and it failed i believe. I uploaded Duet2and3Firmware-3.4.4.zip on the system page to upload system files. It uploaded all files then it says Reset firmware? and over that it says Please wait while updates are being installed. I waited for a half hour and nothing happened. I cant click on anything. So I opened up another web browser to the ip and that wont connect. I restarted the power to my printer and same result.
      Tried connecting via usb but does not recognize properly like it used to so I tried to update the firmware with windows drive file and that didn't work.
      So I was going to do fallback procedure #1 but even that seems confusing with step 2,3,4.
      Where do I start and why did this update fail. Really disappointed.
        At this point it sounds like you'll need to update the board firmware over USB using Bossa software.
        https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-2
        Which board do you have?
        patterson6undefined 1 Reply Last reply Reply Quote 0
          patterson6 @Phaedrux
          @Phaedrux
          duet 3 main board 6xd
            Alright, follow the steps to reset the firmware on the board, and then use bossa https://github.com/Duet3D/BOSSA/releases/tag/1.9.1a-duet3d to flash this firmware file.
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet3Firmware_MB6XD.bin
              @Phaedrux
              In device manager under universal serial bus controllers I get the usb to show thier but it says Unknown USB device(device descriptor request failed).
              How do I know if the bossa port is listed?
                Did you do the erase firmware steps?
                https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#all-other-duet-boards
                  @Phaedrux
                  before any of that I found another usb cord and got it to read in yat.
                  m552 s1
                  ok<LF>
                  m115
                  FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.4 ELECTRONICS: Duet 3 MB6HC v1.01 FIRMWARE_DATE: 2022-10-20 16:19:01<LF>ok<LF>
                    patterson6 @patterson6
                    @patterson6
                    M552 gave me the new iP so let me try that
                      even better
                        @Phaedrux
                        I believe I'm back in business... Thanks
