    duet3mini tmc2209 rsense value
    • apakundefined
      apak
      Please can somebody comfirm me the right value for the rsense on duet3mini tmc2209 drivers?
      Thanks
        dc42 administrators @apak
        @apak the schematics are at https://github.com/Duet3D/Duet3-Mini5plus.
        apakundefined 1 Reply Last reply Reply Quote 0
        • apakundefined
          apak @dc42
          @dc42 not good at that, but seems 0.056ohm, right?
          gloomyandyundefined apakundefined 2 Replies Last reply Reply Quote 1
          • gloomyandyundefined
            gloomyandy @apak
            @apak It might help if you explain what you need it for. You may need to adjust in some situations to allow for the pcb traces.
            • apakundefined
              apak @apak
              @GLOOMYANDY I know klipper is not suported on the forum, but I am trying to set up my predator with duet3 mini and smarteffector and I recall reading somewhere that the rsense was 220 but on klipper specs says 560.
              In the way of doing it the minisherpa stepper died and I didn´t know if had the correct rsense on that config
                gloomyandy @apak
                @apak Well this is the value that RRF uses for the sense resistor: https://github.com/Duet3D/RepRapFirmware/blob/3.5-dev/src/Config/Pins_Duet3Mini.h#L171
                • apakundefined
                  apak @gloomyandy
                  @gloomyandy thanks
