    To SSR or not to SSR
    447
    • Snippyundefined
      Snippy
      Building a new coreXY printter using the Duet 6HC.
      Im having a dilemma, ill be running two meanwell rsp 500 24, the first one will power the duet and the second one will power a 24v 410x410 heated bed.
      Heated bed is 340-360w.
      https://www.aliexpress.com/item/1005003056403054.html?spm=a2g0o.order_list.order_list_main.50.613118026jZegx
      Measures 1,8ohms
      The cheap 80A SSR
      https://www.aliexpress.com/item/10000011656519.html?spm=a2g0o.order_list.order_list_main.33.613118026jZegx
      Do is run the Out_0 power in from the PSU that runs the duet or the one powering the bed, when using an SSR? What about when not using an SSR?
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Snippy
        @Snippy 360w at 24v works out at 15A. here's a note from the docs
        1 Note that the board is rated to 18A on the '15A high current output'; however it is supplied with a 15A fuse fitted (18A are difficult to source). If you need 18A on the this output then you need to fit a 20A fuse and take further precautions against over-current.
        so you'd need to change the fuse to a higher rating, then you should be ok
        Snippyundefined 1 Reply Last reply Reply Quote 0
        • Snippyundefined
          Snippy @jay_s_uk
          @jay_s_uk
          Are they mini or micro2 fuses?
            jay_s_uk @Snippy
            @Snippy mini
            • Snippyundefined
              Snippy
              ''and take further precautions against over-current.'' any ideas on this?
              T3P3Tonyundefined Dad003undefined 2 Replies Last reply Reply Quote 0
              • T3P3Tonyundefined
                T3P3Tony administrators @Snippy
                @Snippy a thermal fuse and a current limiting supply for example. Given that I would use the SSR...
                www.duet3d.com
                • Snippyundefined
                  Snippy
                  This post is deleted!
                  • Dad003undefined
                    Dad003 @Snippy
                    @Snippy Be very careful with the cheap chinese SSR , quality is really random .
                    i use these here for my heat bed and hotend
                    https://www.auberins.com/index.php?main_page=product_info&cPath=2_30&products_id=674
                      dc42 administrators @Snippy
                      @Snippy personally I would use an AC mains bed heater controlled by a DC-AC SSR for a bed heater of that size. If you want to use a 24V heater then the 6HC can drive a 24V 360W heater directly (just) using the standard 15A fuse.
                      Avoid cheap DC-DC SSRs, they are usually fakes.
                      • hackinistratorundefined
                        hackinistrator
                        for low voltage high current dc powered bed you can also use external high power mosfet with a heatsink . usually will be cheaper then ssr .
