Hooked up a 4028 fan but can't control it?
I'm having some issues with my Delta FFB0412UHN-SM36 fan (4028 4-wire).
I've wired it to a buck converter for 12v and the two other wires to a 1LC, but I can't get it to work properly.The fan has 4-wires, red, black, yellow and blue.
I've tried to follow this guide: https://os.ratrig.com/docs/guides/4028/
(even though it's meant for Klipper users)Full blast - no control
out1.tach: yellow
out1: blue
Didn't turn on - no control
(recommendation by other user)
GND: yellow
out1.tach: blue
This is how I have it configured:
M950 F0 C"!121.out1+out1.tach" Q25000 M106 P0 S0 H-1 C"Layer Fan" Is there any obvious configuration errors on my part?
@Reine I can't find that particular fan on the Delta website, closest is this one: https://www.delta-fan.com/FFB0412UHN-SP4Z.html
For your specific fan, one of the few links is this one: https://www.e-gizmo.net/oc/index.php?route=product/product&product_id=49535Both show the wire colour as (from SP4Z fan's specification pdf):
Duet fan documentation: https://docs.duet3d.com/User_manual/Connecting_hardware/Fans_connecting#connecting-fans-to-duet-fan-pinsIt looks like Delta use the Yellow wire for PWM and Blue for tacho. so wire it with Blue to out1.tach and Yellow to out1.
@droftarts just updated the wiring like you suggested and now it turned back on again, fullblast and no control. I tried removing the ! to not invert, but still fullblast.
EDIT: Noticed that RPM in DWC dashboard is 0, I guess it would be Fan0 or do I have to select that somewhere?
Have I missed some other config for it? Or can’t it be controlled from a 1LC?
@Reine Not all 4-wire fans are equal. In iMacs from the last decade, Apple used similar fans made by Delta and AVC - these are controlled by some kind of quasi-analog voltage which in turn is fine-tuned by the tacho signal. To get the idea, have a look at the schematics:
If you happen to own a fan of this kind, your best option is to replace it with a conventional PWM type.
@infiniteloop This one comes from RatRig, they sell printer kits in quantities and this fan has been what they've shipped for a while and is working for other people both using Klipper and RRF so I think the problem is on my end
With blue/yellow connecter to either of the out1/tach pins the fan runs, but is not controllable. I tried different Q number but no change, I also tried removing the tach signal which worked but then DWC complained there were no fan 0?
I also tried writing out the full name of the pin, like this
M950 F0 C"!121.out1+121.out1.tach" Q25000
But it didn't seam to like that either.Not sure what else I could try at this point?
@Reine For M950, see https://docs.duet3d.com/en/User_manual/Reference/Gcodes#notes-146
When using M950 to create a fan, the port name string may be either a single port, or two ports separated by the '+' sign. The second port is used to read the fan tacho. Any CAN address at the start of the port name string applies to both port names.
So this should be correct (the specs also mention to use 25k Hz fan PWM):
Next question; are your toolboard and mainboard on the same firmware version?
@Reine 6HC on 3.4.5 and 1LC on 3.4.4.
@Reine Okay. I noticed on the Ratrig site that the wire colour order is the other way around too: https://ratrig.com/hardware2/electronics/delta-fan-4028-axial-ffb0412uhn-sm36.html
Wire Termination:
Black - 0V
Red - 12V
Blue - PWM (Control)
Yellow - Sensor (Speed-Tachometer)One other thing I noticed in the spec sheet for the SP4Z version is:
So when the PWM wire is unconnected, it will run full blast, and when grounded it won't run at all. To determine which lead is the PWM control, leave both disconnected, then ground one, then the other. The one that turns off the fan is the PWM lead, the other is tacho. The fan should work with 3.3V PWM signalling, as far as I can tell.Can you take a picture of how the fan is wired to the toolboard?
@droftarts this is how I have it wired right now, first attempt had bluw/yellow swapped.
@Reine If you have done the test I suggested to determine the correct wire for PWM, the next test is to check the PWM output of the pin. Set the frequency (Q parameter in M950) to 1Hz, then set PWM to 50%. If you have a good multimeter, you may just be able to see it switching between 0V and 3.3V. Also test at 0% and 100%.
@droftarts I have gotten it to work, turned out the initial wiring I had was correct, but I had to lower the Q value for it to work. I'm now at Q10600 which gives me around 2500 rpm minimum.
Now I'm trying to figure out how to fix the flat spot I have in the % range, 1-10 is completely flat at 2500, not until 11% it starts climbing.
I've played around with M106 Lxx but that only increases minimum rpm and have no affect on the flat spot. -
@Reine said in Hooked up a 4028 fan but can't control it?:
I suspect that's how the fan is designed to work. The cheap motors in brushless fans can't operate at very low speed because then the motor windings don't provide enough back EMF for the rotor position to be sensed. The Intel PWM fan specification says they only need to run down to 30%, and any PWM value below that may either spin at 30% or stop the fan. Your fan seems somewhat better than the minimum specification because you can control it down to 10%.
@dc42 makes sense, thank you for explaining that. Is there a way in RRF to define the usable range? Or can I only change the minimum/maximum speed it ranges between?
Yes, you can set the L parameter to 0.1 i.e. 10%. If any nonzero value lower than 10% is requested, RRF will set it to 10%.
@dc42 wired, I fiddled a lot with it yesterday and didn't get it to work. I'll revisit it tomorrow.
Regarding the range, the documentation refers to two ranges, 0-255 and 0-1, what's that about and how can it be used?
0-255 and 0-1
It's all in how you want to use it, or if you need more fine grain.
0 to 1 is a decimal value. 0.1, 0.2, 0.3, etc and equates to a percentage.
I suggest trying an external pullup on the PWM line. It won't resolve the running at minimum PWM issue (as noted by others - that might be how it is designed), it might improve the response when it is running.
I've seen a couple of fans recently that don't seem to have adequate pullup on their own. See https://forum.duet3d.com/post/306593 for my posting about one example. That was a reasonably reputable fan bought from digikey. (Full disclosure: I've also got some questionable fans from aliexpress that an external pullup didn't help.)
Note that I found that both too weak a pullup and too strong a pullup worked less well than the value I eventually settled on (4k).
