Change Wifi of Duet2 Wifi from one to another without using YAT
@dc42 @phaedrux
  • undefined
    R006
    Hii,
    As end user, I want to change Wifi of Duet2 from older to new one is there any way to do that without using YAT terminal.
    if i am write macro, and rum that or if i run the G-Codes on panel-due so it's possible to change wifi from older to new?
    Any suggestions for that?
    undefined 1 Reply Last reply 17 Mar 2023, 13:05 Reply Quote 0
    • undefined
      droftarts administrators @R006
      @R006 Yes, you can use a macro, and yes, you can run the Gcodes on the PanelDue in the console.
      If you run a macro, send the commands with a pause of a couple of seconds between each command, using G4 S2, to give the WiFi controller time to change state. You can also name the macro 'runonce.g' and put it in the /sys folder. File runonce.g is supported from RRF3.1.0 and later. If this file is present at startup, it is run after running config.g and activating the network, and then deleted. Make sure you have a copy of the macro! An example runonce.g macro to change the SSID might be:
      M552 S-1 ; turn off wifi
      G4 S2 ; wait for wifi state to change
      M552 S0 ; turn on wifi in idle mode
      M588 S"*" ; if necessary, delete all existing saved SSIDs
      M587 S"your-network-ssid" P"your-network-password" ; add new SSID
      M552 S1 ; enable networking
      That will take about 10 seconds to run.
      • undefined
        R006
        @droftarts Thanks😊 Yesterday i am trying using paneldue but missed M588 s"*" so it's not working. Thank you once again.
        • undefined T3P3Tony marked this topic as a question 21 Mar 2023, 11:57
        • undefined T3P3Tony has marked this topic as solved 21 Mar 2023, 11:57
        2 out of 3
