    Auto Z offset calibration
    Using Duet Controllers
    1.6k
    • axiomundefined
      axiom
      I found a promotional video and I would like to know how to do it: hardware and macro...can anyone help me?: https://www.youtube.com/watch?v=yJo_1Op2g4Y
      T3P3Tonyundefined 1 Reply Last reply Reply Quote 1
      • Proschi3Dundefined
        Proschi3D
        I would also be interested in the macro.
        I plan to do the same with a piezo
        Love my Duet 3 Mini.
        https://www.instagram.com/proschi3d
        https://youtube.com/@proschi3d
        https://www.proschi3d.de
        • T3P3Tonyundefined
          T3P3Tony administrators @axiom
          @axiom this is an example using using a touch of switch of a known height above the bed to set the Z offset. You can use a simple switch or one that uses an electrical connection, although an electrical connection one relies on the nozzle being clean.
          www.duet3d.com
          Proschi3Dundefined 1 Reply Last reply Reply Quote 0
            Proschi3D @T3P3Tony
            @T3P3Tony I plan to do it with a piezo.
            The question is what the macro should look like in order to measure the nozzle on the piezo and then use the ir sensor to measure the height of the sample and then save it automatically.
            • T3P3Tonyundefined
              T3P3Tony administrators @Proschi3D
              @Proschi78 there are some examples in the CNC forum as people use this for setting tool offsets. for example:
              https://forum.duet3d.com/topic/29771/fusion-360-cnc-and-laser-post-processors-with-tool-workflow/2?=1679327030257
              https://forum.duet3d.com/topic/19698/rrf3-2-request-to-enable-g43-g44-tool-height-offset/10?
              =1679400956475
              www.duet3d.com
              Proschi3Dundefined 1 Reply Last reply Reply Quote 1
                Proschi3D @T3P3Tony
                @T3P3Tony thank you very much, I'll take a look around
                  Proschi3D @Proschi3D
                  How do I connect a z offset plate to a duet mini as a limit switch
                      If it's a simple microswitch with positive and negative wires you should be able to connect it as such to an endstop input.
                        Proschi3D @Phaedrux
                        @Phaedrux OK thanks. So red at signal input and black gnd?
                          Typically. And if it's a simple switch it shouldn't really matter.
                            Do you have any info on it?
                              Proschi3D @Phaedrux
                              @Phaedrux No it came without any information. then just test it thank you
                                it works fine now.
                                here is the gcode if anyone is interested
                                var errorfix = 0.000  		; constant offset
                                G31 Z0						; set Z-offset to Z=0
                                echo >"0:/sys/config_probe.g" "G31 Z0"
                                M291 S3 R"Heating up nozzle" P"Wait for the nozzle to reach printing temperatures"
                                M568 P0 S210				; set tool 0 (primary hotend) temperature to 210c
                                T0							; select tool 0 (primary hotend)
                                M116 P0 H5					; wait for temperature to reach within 5c of set temperature
                                M300 S666 P666 				; beep
                                M291 S3 R"Automatic Z Offset Calibration" P"Press OK to continue, or CANCEL to abort"
                                M291 S3 R"Homing axes" P"Remove the puck. The printer will home the X, Y, and Z axises without the puck"
                                M98 P"config_probe.g"												; Load BLTouch probe settings
                                M280 P0 S60 I1														; clear any probe errors
                                G29 S2                      										; cancel mesh bed compensation
                                G91                    												; relative positioning
                                M913 X50 															; X axis 50% power
                                G1 H2 Z5 F200          												; lift Z relative to current position
                                G28 X0 U0 Y0  		; Home X,U and Y axis      												; go back a few mm
                                M913 X100 															; X axis 100% power
                                G90                    												; absolute positioning
                                G1 X{move.axes[0].min+175} Y{move.axes[1].min+110} F6000 				; move to center
                                G1 F600																; reduce speed
                                G30                    												; home Z by probing the bed
                                M564 H1 S0             		; Negative movements are allowed
                                G1 Z35						; raise Z to 35mm
                                M83							; relative extruder moves
                                G1 E-5 F300 				; retract 5mm of filament
                                G4 P0						; wait for the moves to finish
                                M291 S3 R"Clean the nozzle" P"The nozzle has been pre-heated. Clean it from any plastic debris"
                                G1 X100 Y200 F6000			; go to X100, Y200
                                G4 P0						; wait for movements to have stopped
                                M291 S3 P"Place the offset tool below the nozzle and press OK to perform the macro, or CANCEL to abort"
                                G4 P200 					; wait 200ms
                                G91							; relative moves
                                G1 H1 Z-19 F50				; move 19mm down, stop when hitting the offset tool (but don't risk crashing the bed)
                                G92 Z0 						; set current position as Z=0
                                G1 Z11 F200					; move up 11mm
                                G1 X{sensors.probes[0].offsets[0] * -1} Y{sensors.probes[0].offsets[1] * -1} F1500 ; move nozzle so that BLTouch is in it's position
                                G90							; absolute moves
                                G30 S-3 					; probes Z and adjusts the probe trigger height to match the actual stop height.
                                G91							; relative movement
                                M568 P0 S0					; set tool 0 temperatures to 0
                                var Z_auto_offset = {sensors.probes[0].triggerHeight+var.errorfix} ; math to calculate the BLTouch offset
                                	if var.Z_auto_offset < 0.01
                                		M291 S2 R"The nozzle has not touched the puck." P"Please check the guide for troubleshooting"
                                		echo "The nozzle has not touched the puck. Please check the guide for troubleshooting"
                                		echo >"0:/sys/config_probe.g" "G31 Z-3"
                                	elif var.Z_auto_offset >= 0.01 & var.Z_auto_offset < 3.5
                                		echo >"0:/sys/config_probe.g" "G31 Z"^{var.Z_auto_offset}
                                		M291 S2 R"Z-offset has been stored" P"the Z-offset has been stored in the config_probe.g file. Verify the value stored with the value displayed in the console"
                                		echo "the Z-offset has been stored in the config_probe.g file. The Z-offset is", var.Z_auto_offset, "mm. Remove the offset tool and place it back in the box"
                                	elif var.Z_auto_offset >= 3.5
                                		M291 S2 R"Z-Offset is too high" P"Please verify the probe height using the probe-calibration"
                                		echo "Z-Offset is too high. Please verify the probe height using the probe-calibration"
                                M564 S1 H1      			; Negative movements are forbidden
                                G1 Z5						; lift nozzle up 5mm
                                T-1							; deselect all tools
                                M18							; release steppers
                                stuartofmtundefined 1 Reply Last reply Reply Quote 1
                                • stuartofmtundefined
                                  stuartofmt @Proschi3D
                                  @Proschi78
                                  Very interesting - I will likely try something similar. Do you have a sense at the accuracy / effectiveness?
                                  Specifically, it seems that there likely would be some mechanical hysteresis in the switch (i.e. measured zero will be a bit lower than the nominal top of the puck). Then the BLT comes along and triggers, perhaps moving the top of the puck, perhaps not.
                                  In other words, it seems there would be some offset between the two trigger points and that could vary from puck-to-puck or in similar solutions that use a microswitch.
                                  What I'm thinking is (maybe) set up the nozzle itself as one side of the "switch" (gnd) and using a puck with a fixed plate as the other side(+ve). That would eliminate the variation that could occur due to a microswitch.
                                  Of course, it may be prudent to have a little "give" in the puck to guard against over zealous probing by the nozzle but stiff enough to (effectively) not move during the probes.
                                  Thoughts?
                                    Proschi3D @stuartofmt
                                    @stuartofmt This puck works with gnd and + on the nozzle. Of course there is a small - value, but this is very consistent and can be compensated with var errorfix = 0.000.
                                    stuartofmtundefined 1 Reply Last reply Reply Quote 0
                                      @Proschi78 said in Auto Z offset calibration:
                                      Many thanks for the input and also the gcodes. I'll print up a puck and give it a whirl. Never did like the sliding paper thing 🙂
                                        I would like to automatically measure the z offset of the left and right extruder.
                                        How can I retrieve the current z height with a meta code and then display it?
                                        would like to go to the puk with the left extruder and save the z height as a variable.
                                        then go to the puk with the right extruder and subtract the variable from this position and display it
                                          @Proschi78
                                          Use global variables to capture the results ? Then use M291 or M117 to display ?
                                            @stuartofmt
                                            I tried that, but something is still wrong
                                            ; Idex Auto Nozzle Offset Tool 1
                                            M291 S3 R"Automatic Idex Offset Calibration" P"Press OK to continue, or CANCEL to abort"
                                            M291 S3 R"Homing axes" P"Remove the puck. The printer will home the X, Y, and Z axes without the puck"
                                            G28
                                            T0
                                            G1 X175 Y110 Z5 F3000
                                            M568 P0 S200 ;T0 200c
                                            M568 P1 S200 ;T1 200c
                                            M116 P0 H5 ;Wait for Temp +-5c
                                            G1 Z50 F800
                                            G1 Z25 F800
                                            G4 P0
                                            G29 S2
                                            {global.tool0 = move.axes[2].machinePosition} ; Store the current Z position in tool0
                                            G1 Z25 F3000
                                            G28 X0
                                            T1
                                            G1 U175 Y110 Z25 F3000
                                            G1 H1 Z-20 F50 ; Move Z-axis down 20 mm
                                            {global.tool1 = move.axes[2].machinePosition - global.tool0} ; Calculate the difference between current Z position and tool0 and store in tool1
                                            {echo "The difference between the two nozzle heights is: " + str(round(global.tool1, 3)) + " mm."} ; Output the difference to the console
                                            G4 S15
                                            G1 Z25 F500
                                            G28 U0
                                            stuartofmtundefined OwenDundefined 2 Replies Last reply Reply Quote 0
