    Voron 2.4 Bed leveling
    • wbrokow1undefined
      wbrokow1
      So, this is my first time around with reprap firmware and Duet 3 boards 6hc &3hc. I watched the whole @toms3dp live build and while it was good, there were a few critical details left out or skirted over real quick. For a newbie like me it stopped me in my tracks on my own build. So to the point: bed leveling. When I run g32 I get an error after the 4 probing points are completed. 'calibration not allowed on these kinematics '. Obviously something wasn't done properly in the setup sequence. So can anyone guide me how to solve to this issue. If there is a procedure for setting up bed leveling, please show me. Thanks
      pkosundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
      • pkosundefined
        pkos @wbrokow1
        @wbrokow1 it might be easier for you to ask such questions in the Voron discord in the duet_rrf channel (where you already got some help in the past). People there are great and very helpful.
        Also, check Voron's github for sample configs (including the UserMods) repo. You'll find a lot is already provided there and you just have to adapt the configs to your particular printer and needs.
        Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
          jay_s_uk @wbrokow1
          @wbrokow1 can you post your config.g and bed.g please?
          wbrokow1undefined 1 Reply Last reply Reply Quote 0
          • wbrokow1undefined
            wbrokow1 @jay_s_uk
            @jay_s_uk ; bed.g
            ; generated by RepRapFirmware Configuration Tool v3.3.15 on Thu Mar 09 2023 15:33:33 GMT-0500 (Eastern Standard Time)
            ;G29 ; probe the bed and enable compensation
            M671 S20
            G1 F6000 X20 Y10 Z10
            G30 P0 X20 Y35 Z-99999 ;PROBE NEAR A fl LEADSCREW
            G1 F60000 X20 Y235 Z10
            G30 P1 X20 Y260 Z-99999 ;PROBE NEAR A rl LEADSCREW
            G1 F60000 X280 Y235 Z10
            G30 P2 X280 Y260 Z-99999 ;PROBE rr corner
            G1 F60000 X280 Y10 Z10
            G30 P3 X280 Y35 Z-99999 S4 ;PROBE fr AND 4 MOTORS
            G1 F6000 X150 Y150 Z150
            ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
            M550 P"Voron" ; set printer name
            M669 K1 ; select CoreXY mode
            ; Wait a moment for the CAN expansion boards to start
            G4 S2
            M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0.4 S1 ; physical drive 0.4 goes forwards
            M569 P0.5 S0 ; physical drive 0.5 goes forwards
            M569 P0.0 S0 ; physical drive 0.0 goes forwards
            M569 P0.1 S1 ; physical drive 0.1 goes forwards
            M569 P0.2 S0 ; physical drive 0.2 goes forwards
            M569 P0.3 S1 ; physical drive 0.3 goes forwards
            M569 P1.1 S1 ; physical drive 1.0 goes forwards
            M584 X0.4 Y0.5 E1.1 ; set drive mapping
            M350 X64 Y64 Z16 E64 I1 ; configure microstepping with interpolation
            M92 X320.00 Y320.00 Z400.00 E1746.16 ; set steps per mm
            M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X60000.00 Y60000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
            M201 X6000.00 Y6000.00 Z4000.00 E250.00 ; set accelerations (mm/s^2)
            M906 X1700 Y1700 Z1500 E700 I20 ; set motor currents (mA) and motor idle factor in per cent
            M84 S10 ; Set idle timeout
            M208 X290 Y290 Z250 S0 ; set axis maxima
            M574 X2 S1 P"^io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin ^io1.in
            M574 Y2 S1 P"^io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ^io2.in
            M574 Z1 S2 ; configure Z-probe endstop for low end on Z
            M558 P5 C"^io3.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
            G31 P500 X0 Y25 Z2.93 ; set Z probe trigger value, offset and trigger height
            M557 X40:260 Y40:260 S20 ; define mesh grid
            M308 S0 P"temp1" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp1
            M308 S1 P"temp0" Y"thermistor" T100000 B4680 C6.455513e-8 ; configure sensor 1 as thermistor on pin temp0
            M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
            M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
            M106 P0 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
            M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
            M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
            M563 P0 S"Magnum+" D0 H1 F0:1 ; define tool 0
            ; Custom settings
            m584 z0.0:0.1:0.2:0.3
            M575 P1 S1 B57600
            M671 X-60:-60:357 Y-6:365:365:-6 ;panel due 4 wire
            T0 ; select first tool
            jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
              jay_s_uk @wbrokow1
              @wbrokow1 said in Voron 2.4 Bed leveling:
              you're missing a location on here for X
              you also don't need the G1 moves in bed
                Phaedrux Moderator @wbrokow1
                ; Custom settings
                The M584 command should come only much earlier in the config.g. In fact you have it twice. Modify the earlier command to include your Z axis mappings that come later.
                wbrokow1undefined 1 Reply Last reply Reply Quote 1
                • wbrokow1undefined
                  wbrokow1 @Phaedrux
                  @Phaedrux thanks!
