    nozzle dives almost 4 mm too deep into the bed
    Using Duet Controllers
    714
    • axiomundefined
      axiom
      Despite successful bedleveling, the nozzle dives almost 4 mm too deep into the bed. Could this be related to the slicer (Cura) ? Attached are the Cura printer settings, the g-code and the config-g
      7a2ea4d1-4087-4fae-8715-a473fdf57afa-grafik.png CCR10_Rahmen100_Duka.gcode
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.12 on Wed Aug 24 2022 12:56:11 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"DUKA1300" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P1 S1 ; physical drive 0 goes forwards
      M569 P3 S1 ; physical drive 3 goes forwards extruder1
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X0 Y1 Z2 E3:4 ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      ;M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm
      M92 X80.00 Y80.00 Z640.00 E320.20:320.51 ; set steps per mm
      M566 X900.00 Y900.00 Z100.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z300.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z40.00 E250.00:250.00 ; set accelerations (mm/s^2)
      M906 X1800 Y1800 Z1700 E1800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X650 Y770 Z1255 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      ;M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
      ;M574 Z2 S2 ; configure Z-probe endstop for high end on Z
      M558 P1 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P1000 X-10 Y95 Z4.869 ; set Z probe trigger value, offset and trigger height
      M557 X20:650 Y100:770 S50 ; define mesh grid
      ;M308 S0 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin e1temp
      ;M950 H0 C"e0heat" T1 ; create nozzle heater output on e1heat and map it to sensor 0
      ;M307 H0 R1.797 K0.742:0.000 D7.57 E1.35 S1.00 B0 V23.8 ; disable bang-bang mode for heater and set PWM limit
      ;M143 H0 S250 ; set temperature limit for heater 0 to 250C
      M308 S1 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e1heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 R1.797 K0.742:0.000 D7.57 E1.35 S1.00 B0 V23.8 ; disable bang-bang mode for heater and set PWM limit
      M143 H1 S250 ; set temperature limit for heater 1 to 250C
      M308 S2 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin bedtemp
      M950 H2 C"bedheat" T2 ; create bed heater output on bedheat and map it to sensor 2
      M307 H2 R0.283 K0.463:0.000 D7.17 E1.35 S1.00 B0 ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H2 ; map heated bed to heater 2
      M143 H2 S280 ; set temperature limit for heater 2 to 280C
      M950 F1 C"fan0" Q250 ; create fan 0 on pin fan0 and set its frequency
      ;M106 P0 S1 H0 T45 ; set fan 0 value. Thermostatic control is turned on
      ;M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency
      ;M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
      ;M563 P0 D0 H0 F0 ; define tool 0
      ;G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets
      ;G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 D1 H1 F0 ; define tool 1
      G10 P1 X45 Y45 Z0 ; set tool 1 axis offsets
      G10 P0 R0 S1 ; set initial tool 1 active and standby temperatures to 0C
      M591 D1 P1 C"e1-stop" S0 ;R40:120 E3.0 S1 ; Filament Sensor
      M568 P1 R160 S0
      M501
        Post your homing files please.
        axiomundefined 1 Reply Last reply Reply Quote 0
        • axiomundefined
          axiom @Phaedrux
          @Phaedrux
          For me, the bed moves on the Z-axis. Top point is 0
          Here are the home files:
          ; homez.g
          ; called to home the Z axis
          G91 ; relative positioning
          G1 H2 Z5 F800 ; lift Z relative to current position
          G90 ; absolute positioning
          G1 X35 Y25 F800 ; go to first probe point
          G1 Z5 F100 ; lift Z relative to current position
          ; homeall.g
          ; called to home all axes
          G1 H1 X-633 Y-845 F800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X10 Y10 F800 ; go back a few mm
          G1 H1 X-628 Y-845 F400 ; move slowly to X and Y axis endstops once more (second pass)
          ;G1 H1 Z-1100 F360 ; move Z up stopping at the endstop
          G90
          G1 X35 Y25 F800
          G30 ; absolute positioning
          ;G92 Z1100 ; set Z position to axis maximum (you may want to adjust this)
          ; homey.g
          ; called to home the Y axis
          G1 H1 Y-845 F800 ; move quickly to Y axis endstop and stop there (first pass)
          G1 H2 Y5 F800 ; go back a few mm
          G1 H1 Y-845 F400 ; move slowly to Y axis endstop once more (second pass)
          G1 H2 Z-5 F6000 ; lower Z again
          ; homex.g
          ; called to home the X axis
          G1 H1 X-633 F800 ; move quickly to X axis endstop and stop there (first pass)
          G1 H2 X5 F800 ; go back a few mm
          G1 H1 X-633 F400 ; move slowly to X axis endstop once more (second pass)
          G1 H2 Z-5 F800 ; lower Z again
            Phaedrux Moderator @axiom
            @axiom said in nozzle dives almost 4 mm too deep into the bed:
            What kind of probe is it? How did you measure the trigger height?
            https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
            • axiomundefined
              axiom @Phaedrux
              @Phaedrux it is a capacitive sensor. I made the trigger height according to the instructions and he also does a successful bed leveling with 190 measuring points...so it's probably not the sensor
                When it dives too deep, what Z position does it think it has?
                • axiomundefined
                  axiom @Phaedrux
                  @Phaedrux it may be that I have to specify the trigger height negatively, so instead of :
                  P1 C"!zprobe.in" H5 F120 T6000 ; Set Z-probe type to unmodulated and dive height + speeds
                  G31 P1000 X-61 Y-1 Z5.558
                  Z-5,558 ?
                    I think there is something wrong with your capacitive sensor, or it's not picking up your bed surface correctly.
                    A negative trigger height means just that, it triggers when the nozzle is bellow the surface of the bed, which for some nozzle contact probes is normal and usually a fraction of a mm. -5.5mm is not correct in your case.
                    So either the probe is completely wrong, or there is something somewhere in your gcode that is setting the nozzle position higher than it actually is.
                    Can you post your config-override.g?
                    How exactly did you measure the trigger height?
                    • axiomundefined
                      axiom @Phaedrux
                      @Phaedrux said in nozzle dives almost 4 mm too deep into the bed:
                      I test the trigger hight exactly according to the instructions you sent me: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
                      I don't have a config-override.g. Just a "config.g" and a "config.g.bak"... I attach both.
                      A true bed leveling works for me without any problems. When I start a job, the nozzle pushes its head up (moves into the bed). If I then adjust the Z-offset manually, it prints its job properly (the dimensions are correct)...however, that's certainly not good for the head if it goes into bed every time.
                      Here the config files:
                      M208 X640 Y760 Z1255 S0 ; set axis maxima
                      G31 P1000 X-61 Y-1 Z5.558 ; set Z probe trigger value, offset and trigger height
                      M557 X15:580 Y15:750 S50 ; define mesh grid
                      M568 P1 R160 S0
                      M501
                      M208 X640 Y774 Z1255 S0 ; set axis maxima
                      M568 P1 R160 S0
                      M501
                      • axiomundefined
                        axiom @axiom
                        @axiom
                        I discovered that you can create a config.overridge file using the M500 command. I did that but there is not much in it:
                        ; config-override.g file generated in response to M500 at 2023-04-15 08:54
                        ; Heater model parameters
                        ; Workplace coordinates
                        G10 L2 P1 X0.00 Y0.00 Z0.00
                        G10 L2 P2 X0.00 Y0.00 Z0.00
                        G10 L2 P3 X0.00 Y0.00 Z0.00
                        G10 L2 P4 X0.00 Y0.00 Z0.00
                        G10 L2 P5 X0.00 Y0.00 Z0.00
                        G10 L2 P6 X0.00 Y0.00 Z0.00
                        G10 L2 P7 X0.00 Y0.00 Z0.00
                        G10 L2 P8 X0.00 Y0.00 Z0.00
                        G10 L2 P9 X0.00 Y0.00 Z0.00
                          If you manually move the nozzle to touch the bed, then send G92 Z0, then jog to Z100, if you measure the distance is it actually 100mm?
                          If you home X and Y and then send G30 to probe the bed, does Z0 equate to the nozzle touching the bed?
                          • axiomundefined
                            axiom @Phaedrux
                            @Phaedrux I installed a new probe..that didn't change anything.
                            if I move the bed with G1 Z40 after executing the G92 Z0 command, the distance is correct. But when I run the G1 Z40 command after homing, the distance is about 5mm too small.
                              That would be because your trigger height is -5mm. You're telling it that the nozzle is 5mm below the surface of the bed when the probe triggers.
                              Can you try this? Set your probe type to M558 P0 for manual probe mode. Change to G31 X0 Y0 Z0 since there are no offsets. Then go through your normal homing and leveling routine. This will prompt you to jog the nozzle down to touch the bed whenever the probe would normally be called.
                              axiomundefined 2 Replies Last reply Reply Quote 0
                              • axiomundefined
                                axiom @Phaedrux
                                @Phaedrux said inDon't get me wrong: I change the M588 and the G31 command in config.g?
                                Does this mean I should manually check 190 points when leveling bed?
                                • axiomundefined
                                  axiom @Phaedrux
                                  @Phaedrux I rather have the impression that the value is not being transferred, I can never find the M500 command anywhere....I already sent the code...where should it be with the M500?
                                    Yes you need to change the M558 and G31 in config.g
                                    Since the manual probing is very slow, I would also recommend changing the mesh grid size to be much smaller. Maybe a 2x2 grid for now. 190 points would take a very very long time.
                                    I'm not sure what you mean. You don't need to use M500 at all for this. M500 is only used to save things that are calculated by the firmware, like heater PID tuning values, etc.
                                      jay_s_uk @axiom
                                      @axiom if you want the probe offset saved with M500, use M500 P31
                                      • axiomundefined
                                        axiom @Phaedrux
                                        @Phaedrux I think I was able to partially solve the riddle: I thought the M561 command would also delete the trigger values ​​in config.g. You have to manually set the trigger value G31 of Z to 0 before the trigger test. The second thing I did is physically decrease the distance of the sensor. The disadvantage of a capacitive sensor is that the heat from the bed will greatly reduce the life of the sensor. So I'll be looking for a new sensor system in the long term...I've started reading about the piezo technology, but I suspect that the one on my Volcano hotend is too big...but in any case, the printer is running reasonably well now... ..just to understand: Are the values ​​after the mesh bed compensation automatically taken into account during the job and are the unevenness compensated?
                                        Phaedruxundefined 1 Reply Last reply Reply Quote 1
                                          Yes, that's the point of the mesh.
                                          • axiomundefined
                                            axiom @Phaedrux
                                            @Phaedrux thanks for your patience ! Maybe you could set that with z=0 in the config.g for complete beginners like me in the documentation?
                                            • jp.douarvil 0undefined jp.douarvil 0 referenced this topic
