dwc 3.4 upgrade hotend gone
Hi hope someone can help with this. I upgraded to 3.4 from 3 and now the hotend has gone. Before the upgrade I printed a benchy which was fine. I did nothing to the hardware and now the hotend is gone the heated bed is still showing but dwc says no extruder. The gonfig.g file hasn't changed and I cant figure it out. Got to be something simple I'm missing. Sorry if the txt file is the wrong way to show config.g file I'm new to forums.
@markyd can you run
M98 P"config.g"
and post the output -
Is this OK
M98 p"config.g"
Warning: M854: Command is not supported
Error: in file macro line 31 column 19: M350: array too long, max length = 0
Error: in file macro line 32 column 19: M92: array too long, max length = 0
Error: in file macro line 33 column 30: M566: array too long, max length = 0
Error: in file macro line 34 column 36: M203: array too long, max length = 0
Error: in file macro line 35 column 33: M201: array too long, max length = 0
Error: in file macro line 36 column 25: M906: array too long, max length = 0
Error: bad drive number
Error: in file macro line 77: G10: Invalid tool number
Error: in file macro line 78: G10: Invalid tool number
Warning: Heater 1 predicted maximum temperature at full power is 500°C -
M854 E3
Looks like a typo here, should be
M584 E3
Make that change, and then run
M98 P"config.g"
again. -
Thanks
Thought it was something simple. All ok now. I will have to remember m98. Wonder how that changed?Thank you for your help much appreciated.
@markyd its in the release nots but after 3.3 theres not a default extruder specified and it needs adding
