    Problem with escape characters for password for Wi-Fi card.
    835
    • Schickfusundefined
      Schickfus
      Hi
      I have been trying out the wifi card. But I have hard time configure it. Or getting to connect.
      I have a 6HC and 3.5beta2
      In a wifi that I can’t change there are a star character and an equal character.
      In a extra wifi.gcode file I do.
      M552 I1 S0 ; Turn off the wifi module
      M588 "" ; forget all current SSID networks
      M587 S"Surf" P"=U2raA44Ae*”
      M552 I1 S1 ; turn the wifi module back on
      But it won’t find the network
      I think it is a 5 GHz and not 2,4 GHz
      Can this be a problem.
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        Schickfus
        @T3P3TONY And @dc42 do you know what is the problem?
        • gloomyandyundefined
          gloomyandy @Schickfus
          @Schickfus The current WiFi modules can only support 2.4GHz, so if your network is 5GHz only that may be the problem (though most routers support both). Perhaps another option would be to run the printer in access point mode and connect directly to it?
          Schickfusundefined 1 Reply Last reply Reply Quote 0
            jay_s_uk @Schickfus
            @Schickfus also M588 "" isn't valid to forget all networks. It should be M588 S"*"
              Schickfus @jay_s_uk
              @jay_s_uk
              Ok the stars get filtered out in the chat.
              So I am connected via the serial tool on a Mac to the board.
              So I do
              M587
              Remembered networks: none
              ok
              Then I do
              M552 I1 S0
              ok
              M587 S"SGuest" P"Test"
              Don not get an ok
              M552 I1 S1
              Don't get an answer
              M587
              ok
              What is wrong?
                Schickfus @gloomyandy
                @gloomyandy
                Ok thanks. I have gone to a network with just a 2.4 GHz
                  jay_s_uk @Schickfus
                  @Schickfus i would suggest you shouldn't be using the I1.
                  Just use M552 S0
                  Edit: reading further, I should only be used when in SBC mode
                  • T3P3Tonyundefined
                    T3P3Tony administrators @Schickfus
                    @Schickfus have you installed the wifi firmware?
                    M997 S1
                    www.duet3d.com
                    Schickfusundefined 2 Replies Last reply Reply Quote 0
                      If you're having troubles sending these commands from the terminal program you can put the commands into a macro file and then execute that.
                        Schickfus @T3P3Tony
                        @T3P3Tony
                        Yes according to the two files to be added link.
                        Yes
                        Would it work other wise?
                          Schickfus @T3P3Tony
                          @T3P3Tony said in Problem with escape characters for password for Wi-Fi card.:
                          M997 S1
                          M587.1
                          Error: M587.1: failed to start scan: WiFi module is disabled
                          ok
                          M552 I1 S0
                          ok
                          MWiFi module started
                          Error: Bad command: M
                          ok
                          M587.1
                          ok
                          M587.2
                          Network Scan Results:
                          ssid=fSpace rssi=-47 phymode=n auth=Unknown
                          ssid=ceGuest rssi=3 phymode=b auth=Unknown
                          ok
                          But it is not whole ssid. It is shopped
                            Schickfus @Phaedrux
                            @Phaedrux
                            Yes I did. But this does not work.
                            It won't run the file
                              What did you have in the file exactly?
                              How did you try to run the file?
                              You need to use M98 P"macroname.g" to execute a macro.
                                Schickfus @Phaedrux
                                @Phaedrux
                                I used
                                M98 P"Gcodes/Wifimacro.g"
                                ; wifimacro.g
                                ; tell the Duet to connect to the wifi
                                ;M118 S"Wifimacro turn off Wifi"
                                M588 "*" ; forget all current SSID networks
                                M587 S"SurfSpaceGuest" P"Test"
                                ;M118 S"Wifimacro turn on Wifi"
                                  Phaedrux Moderator @Schickfus
                                  @Schickfus said in Problem with escape characters for password for Wi-Fi card.:
                                  Remove the I1 from your M552 commands. Are you using an SBC?
                                  You're missing the S in front of the "*". It must be M588 S"*"
                                    dc42 administrators @jay_s_uk
                                    @jay_s_uk said in Problem with escape characters for password for Wi-Fi card.:
                                    Just use M552 S0
                                    The I1 is a required parameter to M552 when using the optional WiFi interface on the MB6HC board, so select the wifi interface. The default is I0 which is the Ethernet interface.
                                    jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                                      dc42 administrators @Schickfus
                                      I recall reading in previous posts that Macs have a habit of substituting "smart quotes" for plain double quotes. Are you sure that hasn't happened?
                                        Schickfus @dc42
                                        No I have done some testing.
                                        M587.1
                                        M587.2
                                        And gett ssid string in the beginning chopped offed. Does this mater.
                                          That's a known issue in RRF 3.5beta2, fixed in the forthcoming beta3. It's only the reported SSID that gets truncated, not the stored SSID.
                                            Schickfus @dc42
                                            Is there a way to know that I have installed the right wifi code?
                                            The files:
                                            DuetWiFiServer_32S3.bin
                                            DuetWiFiServer.bin
