    CoreXY 1HCL issues 3.5b3
    Beta Firmware
    543
    • supertb1undefined
      supertb1
      Greetings all (T3P3Toney, DC42, Phaedrux) and any other dev that might be able to help. I am having problems getting my new system to go into closed loop. I have new 1HCL boards (for X/Y), (4) Z axis motors, and an extruder. I am running 3.5.0-B3 on MB6HC and 3.5.0-B3 closed loop plug in. I am running Stepperonline 17E1K-05 100cpr motors (XY) link text My config as follows:
      =; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Tue Mar 07 2023 13:06:17 GMT-0600 (Central Standard Time)
      M575 P1 S1 B57600                            ; enable support for PanelDue
      G90                                          ; send absolute coordinates...
      M83                                          ; ...but relative extruder moves
      M550 P"TRON XY4Z"                            ; set printer name
      M669 K1                                      ; select CoreXY mode
      ; Wait a moment for the CAN expansion boards to start
      G4 S2
      M552 P192.168.1.59 S1                             ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                   ; enable HTTP
      M586 P1 S0                                   ; disable FTP
      M586 P2 S0                                   ; disable Telnet
      G4 S1                                        ; Wait for expansion boards to start
      M569.1 P50.0 R40 I3000 D0.05 T2 C1000 H80 S200        ; Drive 0 | Y stepper 1000PPR
      M569.1 P51.0 R40 I3000 D0.05 T2 C939.2 H80 S200         ; Drive 1 | X Stepper 1000PPR.
      M569 P50.0 D4 S1                             ; physical drive 121.0 goes forwards Configure the motor on the 1HCL at can address 50 as being in closed-loop drive mode (D4), Open loop (D2) Not reversed (S1)
      M569 P51.0 D4 S1                             ; physical drive 122.0 goes forwards Configure the motor on the 1HCL at can address 50 as being in closed-loop drive mode (D4), Open loop (D2) Not reversed (S1)
      M569 P0.0 S1                                 ; physical drive Z axis 0.0 goes forwards
      M569 P0.4 S1                                 ; physical drive Extruder 0.4 goes forwards
      M584 X51.0 Y50.0 Z0.0:0.1:0.2:0.3 E0.4       ; set drive mapping
      M671 X-108:476:-108:476 Y15:15:333:333 S10 ;screw 1 (stepper 0) closest to XY home (X-114.3,Y15.875) Screw 2 (stepper 1) near Y switch (X476.25,Y15.875) Screw 3 (stepper2) same side of frame as screw 1 (X-114.3,Y333.375) Screw 4 (stepper3) farthest from XY home (X476.25,Y333.375)
      M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
      M92 X82.5 Y82.5 Z402.50 E415.00            ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00      ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00          ; set accelerations (mm/s^2)
      M906 X1800 Y1800 Z800 E800 I30                 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                      ; Set idle timeout
      M917 X15 Y15                                 ; Set the closed loop axes to have holding current of zero
      M208 X0 Y0 Z0 S1                             ; set axis minima
      M208 X359 Y354 Z360 S0                       ; set axis maxima
      M574 X1 S1 P"!io1.in"                       ; configure active-high endstop for low end on X via pin !^io1.in
      M574 Y1 S1 P"!io2.in"                       ; configure active-high endstop for low end on Y via pin !^io2.in
      M591 D0 P1 C"!io3.in" S1                      ; simple sensor (high signal when filament present) connected to IO_3 for drive 0, enabled
      M574 Z1 S2                                   ; configure Z-probe endstop for low end on Z
      M950 S0 C"io7.out"                           ; create servo pin 0 for BLTouch
      M558 P9 C"io7.in" H5 F120 T6000              ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y25 Z3.2                         ; set Z probe trigger value, offset and trigger height
      M557 X50:320 Y50:320 S50                     ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out1" T0                           ; create bed heater output on out1 and map it to sensor 0
      M307 H0 B1 S15.00                             ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                      ; map heated bed to heater 0
      M143 H0 S120                                 ; set temperature limit for heater 0 to 120C
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out2" T1                           ; create nozzle heater output on out2 and map it to sensor 1
      M307 H1 R3.125 K0419:0.162 D4.00 E1.35 S1.00 B0 V24.0                             ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                 ; set temperature limit for heater 1 to 280C
      M950 F0 C"out8" Q500                         ; create fan 0 on pin out8 and set its frequency
      M106 P0 C"Tool Fan" S0 H-1                   ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"out7" Q500                         ; create fan 1 on pin out7 and set its frequency
      M106 P1 C"Extruder" S1 H1 T45                ; set fan 1 name and value. Thermostatic control is turned on
      M563 P0 S"Micro-Swiss" D0 H1 F0              ; define tool 0
      G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
      G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
      ;Miscellaneous
      M575 P1 S1 B57600
      My X/Y homing sequence:
      ; homex.g
      ; called to home the X axis
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Mar 08 2021 08:53:31 GMT-0600 (Central Standard Time)
      M569 P50.0 D0           ; Turn off closed loop
      G1 H2 Z5 F6000          ; lift Z relative to current position
      G1 H1 X-610 F3000       ; move quickly to X axis endstop and stop there (first pass)
      G1 H2 X5 F6000          ; go back a few mm
      G1 H1 X-610 F240        ; move slowly to X axis endstop once more (second pass)
      G1 X10 F3000            ; Move to a known-safe position
      M400                    ; Wait for the move to complete
      G4 P500                 ; Wait for the motor to settle
      M569 P51.0 D4           ; Turn closed loop back on
      M569.6 P51.0 V1        ; Perform the tuning manoeuvres for a quadrature encoder
      G1 X10 F100
      M122 B50 shows:
      4/23/2023, 7:32:24 AM	m122 b50
      Diagnostics for board 50:
      Duet EXP1HCL firmware version 3.5.0-beta.3 (2023-04-14 13:08:48)
      Bootloader ID: SAME5x bootloader version 2.4 (2021-12-10)
      All averaging filters OK
      Never used RAM 53412, free system stack 182 words
      Tasks: Move(nWait,0.0%,104) HEAT(nWait,0.0%,82) CanAsync(nWait,0.0%,63) CanRecv(nWait,0.0%,43) CanClock(nWait,0.0%,68) TMC(nWait,45.0%,344) CLSend(nWait,0.0%,152) MAIN(running,52.9%,417) IDLE(ready,0.0%,29) AIN(nWait,2.0%,267), total 100.0%
      Last reset 00:40:24 ago, cause: software
      Last software reset data not available
      Closed loop enabled: yes, pre-error threshold: 2.00, error threshold: 4.00, encoder type rotaryQuadrature, position -274
      Encoder reverse polarity: no, raw count 65262
      Tuning mode: 0, tuning error: 0, collecting data: no
      Control loop runtime (us): min=6, max=38, frequency (Hz): min=10135, max=16667
      Driver 0: pos 15673, 82.5 steps/mm,ok, SG min 0, mspos 808, reads 712, writes 52753 timeouts 0, steps req 7 done 6079
      Moves scheduled 13, completed 13, in progress 0, hiccups 0, step errors 0, maxPrep 62, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
      Peak sync jitter -6/7, peak Rx sync delay 209, resyncs 0/0, next timer interrupt due in 23 ticks, enabled, next step interrupt due in 2500122050 ticks, disabled
      VIN voltage: min 24.4, current 24.4, max 24.4
      V12 voltage: min 12.2, current 12.2, max 12.2
      MCU temperature: min 24.2C, current 24.4C, max 24.6C
      Last sensors broadcast 0x00000000 found 0 77 ticks ago, 0 ordering errs, loop time 0
      CAN messages queued 19454, send timeouts 0, received 21864, lost 0, free buffers 37, min 37, error reg 0
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 316, adv 36955/37189
      Accelerometer: none
      I2C bus errors 12, naks 0, other errors 0
      M122 B51 shows:
      4/23/2023, 7:33:51 AM	m122 b51
      Diagnostics for board 51:
      Never used RAM 53476, free system stack 180 words
      Tasks: Move(nWait,0.0%,110) HEAT(nWait,0.0%,82) CanAsync(nWait,0.0%,63) CanRecv(nWait,0.0%,43) CanClock(nWait,0.0%,70) TMC(nWait,40.3%,344) CLSend(nWait,0.0%,152) MAIN(running,57.8%,407) IDLE(ready,0.0%,29) AIN(nWait,1.8%,267), total 100.0%
      Last reset 00:41:52 ago, cause: software
      Closed loop enabled: no, pre-error threshold: 2.00, error threshold: 4.00, encoder type rotaryQuadrature, position 190
      Encoder reverse polarity: yes, raw count 65346
      Driver 0: pos -113434, 82.5 steps/mm,standstill, SG min 0, mspos 904, reads 16668, writes 2491 timeouts 0, steps req 4 done 8410
      Moves scheduled 12, completed 12, in progress 0, hiccups 0, step errors 0, maxPrep 54, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
      Peak sync jitter -7/6, peak Rx sync delay 198, resyncs 0/0, next timer interrupt due in 13 ticks, enabled, next step interrupt due in 2456048963 ticks, disabled
      VIN voltage: min 24.1, current 24.1, max 24.2
      V12 voltage: min 12.0, current 12.0, max 12.1
      MCU temperature: min 25.2C, current 25.6C, max 25.6C
      Last sensors broadcast 0x00000000 found 0 47 ticks ago, 0 ordering errs, loop time 0
      CAN messages queued 20139, send timeouts 0, received 22639, lost 0, free buffers 37, min 37, error reg 0
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 307, adv 36688/37174
      Accelerometer: none
      I2C bus errors 8, naks 0, other errors 0
      any help would be great
      supertb1undefined 1 Reply Last reply Reply Quote 0
      • supertb1undefined
        supertb1 @supertb1
        @supertb1 I seen the reverse polarity on P51 so I changed the A+/B+ wires around and now it complains of not being able to calibrate but it shows information on the step maneuver:
        51_2023-04-23_04.37.55.csv
        • supertb1undefined
          supertb1 @supertb1
          • A Former User?
            A Former User
            This post is deleted!
            • supertb1undefined
              supertb1 @A Former User
              @Herve_Smith thanks... apparently I did that wrong on the first line
              • supertb1undefined supertb1 referenced this topic
              • supertb1undefined
                supertb1 @supertb1
                @supertb1 @T3P3Tony @dc42 @Phaedrux Another development that I have now noticed. Why would homing in closed loop on a core XY kick the second axis out of closed loop?
                4/25/2023, 9:42:56 AM	M122 b50
                Never used RAM 53412, free system stack 180 words
                Tasks: Move(nWait,0.0%,110) HEAT(nWait,0.0%,82) CanAsync(nWait,0.0%,63) CanRecv(nWait,0.0%,43) CanClock(nWait,0.0%,70) TMC(nWait,42.9%,344) CLSend(nWait,0.0%,152) MAIN(running,55.2%,407) IDLE(ready,0.0%,29) AIN(nWait,1.9%,267), total 100.0%
                Last reset 00:01:39 ago, cause: software
                Closed loop enabled: no, pre-error threshold: 2.00, error threshold: 4.00, encoder type rotaryQuadrature, position 10
                Encoder reverse polarity: yes, raw count 65526
                Driver 0: pos -116735, 82.5 steps/mm,standstill, SG min 0, mspos 632, reads 57493, writes 42675 timeouts 0, steps req 3 done 1643
                Moves scheduled 13, completed 13, in progress 0, hiccups 0, step errors 0, maxPrep 15, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                Peak sync jitter -5/5, peak Rx sync delay 205, resyncs 0/0, next timer interrupt due in 6 ticks, enabled, next step interrupt due in 4282244676 ticks, disabled
                MCU temperature: min 24.2C, current 24.6C, max 24.9C
                Last sensors broadcast 0x00000000 found 0 162 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 368, send timeouts 0, received 394, lost 0, free buffers 37, min 37, error reg 0
                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 288, adv 37175/37190
                Accelerometer: none
                I2C bus errors 0, naks 0, other errors 0
                4/25/2023, 9:42:41 AM	G28 X
                Driver 51.0 basic tuning succeeded, measured backlash 0.091 step
                4/25/2023, 9:42:23 AM	M122 b51
                Never used RAM 53412, free system stack 190 words
                Tasks: Move(nWait,0.0%,104) HEAT(nWait,0.0%,82) CanAsync(nWait,0.0%,63) CanRecv(nWait,0.0%,43) CanClock(nWait,0.0%,68) TMC(nWait,42.0%,344) CLSend(nWait,0.0%,152) MAIN(running,56.0%,407) IDLE(ready,0.0%,29) AIN(nWait,1.9%,267), total 100.0%
                Last reset 00:01:06 ago, cause: software
                Closed loop enabled: no, pre-error threshold: 2.00, error threshold: 4.00, encoder type rotaryQuadrature, position 2
                Encoder reverse polarity: yes, raw count 65534
                Driver 0: pos -81260, 82.5 steps/mm,standstill, SG min 0, mspos 24, reads 12053, writes 29607 timeouts 0, steps req 1 done 4129
                Moves scheduled 8, completed 8, in progress 0, hiccups 0, step errors 0, maxPrep 16, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                Peak sync jitter -6/3, peak Rx sync delay 206, resyncs 0/0, next timer interrupt due in 16 ticks, enabled, next step interrupt due in 4285859782 ticks, disabled
                VIN voltage: min 24.1, current 24.1, max 24.1
                MCU temperature: min 25.4C, current 25.8C, max 25.8C
                Last sensors broadcast 0x00000000 found 0 79 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 332, send timeouts 0, received 351, lost 0, free buffers 37, min 37, error reg 0
                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 290, adv 36887/36909
                Accelerometer: none
                4/25/2023, 9:42:13 AM	M122 b50
                Tasks: Move(nWait,0.0%,110) HEAT(nWait,0.0%,82) CanAsync(nWait,0.0%,63) CanRecv(nWait,0.0%,43) CanClock(nWait,0.0%,70) TMC(nWait,40.4%,344) CLSend(nWait,0.0%,152) MAIN(running,56.5%,415) IDLE(ready,1.2%,29) AIN(nWait,1.8%,267), total 100.0%
                Last reset 00:00:57 ago, cause: software
                Closed loop enabled: yes, pre-error threshold: 2.00, error threshold: 4.00, encoder type rotaryQuadrature, position -1
                Encoder reverse polarity: yes, raw count 1
                Control loop runtime (us): min=6, max=21, frequency (Hz): min=10563, max=16667
                Driver 0: pos -16912, 82.5 steps/mm,ok, SG min 0, mspos 840, reads 48087, writes 36536 timeouts 0, steps req 4 done 5352
                Moves scheduled 8, completed 8, in progress 0, hiccups 0, step errors 0, maxPrep 62, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                Peak sync jitter -6/5, peak Rx sync delay 204, resyncs 0/0, next timer interrupt due in 13 ticks, enabled, next step interrupt due in 4284715151 ticks, disabled
                MCU temperature: min 24.2C, current 24.6C, max 24.6C
                Last sensors broadcast 0x00000000 found 0 141 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 502, send timeouts 0, received 538, lost 0, free buffers 37, min 37, error reg 0
                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 309, adv 36965/37193
                Accelerometer: none
                4/25/2023, 9:42:02 AM	G28 Y
                Driver 50.0 basic tuning succeeded, measured backlash 0.128 step
                4/25/2023, 9:41:45 AM	M122 b51
                Never used RAM 53412, free system stack 194 words
                Tasks: Move(nWait,0.0%,104) HEAT(nWait,0.0%,86) CanAsync(nWait,0.0%,63) CanRecv(nWait,0.0%,43) CanClock(nWait,0.0%,68) TMC(nWait,39.1%,356) CLSend(nWait,0.0%,152) MAIN(running,55.2%,417) IDLE(ready,3.8%,29) AIN(nWait,1.9%,267), total 100.0%
                Last reset 00:00:29 ago, cause: software
                Closed loop enabled: yes, pre-error threshold: 2.00, error threshold: 4.00, encoder type rotaryQuadrature, position 4
                Encoder reverse polarity: yes, raw count 65532
                Control loop runtime (us): min=6, max=21, frequency (Hz): min=11538, max=16667
                Driver 0: pos -49086, 82.5 steps/mm,ok, SG min n/a, mspos 8, reads 38729, writes 64036 timeouts 0, steps req 2 done 0
                Moves scheduled 4, completed 4, in progress 0, hiccups 0, step errors 0, maxPrep 56, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                Peak sync jitter -7/3, peak Rx sync delay 202, resyncs 0/0, next timer interrupt due in 8 ticks, enabled, next step interrupt due in 4273061101 ticks, disabled
                MCU temperature: min 25.4C, current 25.6C, max 25.8C
                Last sensors broadcast 0x00000000 found 0 91 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 273, send timeouts 0, received 278, lost 0, free buffers 37, min 37, error reg 0
                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 306, adv 36670/37183
                Accelerometer: none
                4/25/2023, 9:41:37 AM	G28 X
                Driver 51.0 basic tuning succeeded, measured backlash 0.100 step
                • Phaedruxundefined Phaedrux moved this topic from Duet Hardware and wiring
                  dc42 administrators @supertb1
                  @supertb1 I can see two things that you need to change:
                  1. Both motors should use C1000 in their M569.1 command. Currently you have one set to 1000 and the other set to a little less.
                  2. As your machine is a CoreXY, before homing either X or Y you should set both motors to open loop. Then use M569.6 to calibrate both of them.
                  supertb1undefined 3 Replies Last reply Reply Quote 0
                  • supertb1undefined
                    supertb1 @dc42
                    @dc42 I put the count back to 1000 the one drive.. it was the firmware that gave that feedback in an error as to the read counts.
                    on the Home sequence instead of M569 P50.0/P51.0 "D0" it should read M569 P50.0/51.0 "D2"? What should the closed loop homing sequence look like with the 3.5.0-B3?
                    • supertb1undefined
                      supertb1 @dc42
                      @dc42 I'm not sure what changes need to be made to my homing sequence as listed above, the first line of the sequece shows "M569 P51.0 D0" that should take it out of closed loop and then the axis homes 2 times, then moves to a safe spot and then turns the closed loop feature back on the axis "M569 P51.0 D4" and then performs the polarity detection and zeroing move "M569.6 P51.0 V1" ... as I am typing this I realized that I have the wrong 1HCL listed at the beginning of the sequence...lol... I can't wait for the online configurator to make this stupid proof...lol.
                      • supertb1undefined
                        supertb1 @dc42
                        @dc42, @Phaedrux, @T3P3Tony Any idea why I get this error on start up?
                        4/27/2023, 9:21:26 PM 	m122
                        RepRapFirmware for Duet 3 MB6HC version 3.5.0-beta.3 (2023-04-14 11:28:15) running on Duet 3 MB6HC v1.02 or later (standalone mode)
                        Board ID: 08DJM-956BA-NA3TJ-6J1F8-3S06R-1U82S
                        Used output buffers: 1 of 40 (40 max)
                        Error in macro line 1 while starting up: Bad command: =
                        Static ram: 154728
                        Dynamic ram: 118912 of which 200 recycled
                        Never used RAM 69224, free system stack 135 words
                        Tasks: NETWORK(ready,72.2%,207) ETHERNET(nWait,0.0%,401) HEAT(nWait,0.0%,324) Move(nWait,0.0%,243) CanReceiv(nWait,0.0%,772) CanSender(nWait,0.0%,334) CanClock(delaying,0.0%,341) TMC(nWait,16.0%,59) MAIN(running,11.7%,137) IDLE(ready,0.0%,30), total 100.0%
                        Owned mutexes:
                        Last reset 02:58:10 ago, cause: software
                        Last software reset at 2023-04-27 18:21, reason: User, Gcodes spinning, available RAM 69224, slot 0
                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                        Error status: 0x04
                        Aux0 errors 0,0,0
                        MCU temperature: min 32.1, current 34.7, max 35.4
                        Supply voltage: min 23.6, current 23.7, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                        12V rail voltage: min 11.7, current 12.1, max 12.5, under voltage events: 0
                        Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/28/0, gc cycles 0
                        Events: 0 queued, 0 completed
                        Driver 0: standstill, SG min 0, mspos 680, reads 35246, writes 19 timeouts 0
                        Driver 1: standstill, SG min 0, mspos 680, reads 35246, writes 19 timeouts 0
                        Driver 2: standstill, SG min 0, mspos 680, reads 35246, writes 19 timeouts 0
                        Driver 3: standstill, SG min 0, mspos 680, reads 35247, writes 19 timeouts 0
                        Driver 4: standstill, SG min n/a, mspos 8, reads 35252, writes 14 timeouts 0
                        Driver 5: standstill, SG min n/a, mspos 8, reads 35255, writes 11 timeouts 0
                        Date/time: 2023-04-27 21:19:28
                        Slowest loop: 27.39ms; fastest: 0.06ms
                        === Storage ===
                        Free file entries: 20
                        SD card 0 detected, interface speed: 25.0MBytes/sec
                        SD card longest read time 2.5ms, write time 0.0ms, max retries 0
                        DMs created 125, segments created 3, maxWait 60276ms, bed compensation in use: none, comp offset 0.000
                        no step interrupt scheduled
                        === DDARing 0 ===
                        Scheduled moves 20, completed 20, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                        === DDARing 1 ===
                        Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                        Heater 0 is on, I-accum = 0.0
                        HTTP is idle in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        SBC is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Aux2 is idle in state(s) 0
                        File2 is idle in state(s) 0
                        Queue2 is idle in state(s) 0
                        Q0 segments left 0, axes/extruders owned 0x0000005
                        Code queue 0 is empty
                        Code queue 1 is empty
                        === Filament sensors ===
                        Extruder 0 sensor: ok
                        === CAN ===
                        Messages queued 96343, received 171224, lost 0, boc 0
                        Longest wait 13ms for reply type 6018, peak Tx sync delay 63438, free buffers 50 (min 46), ts 53452/53450/0
                        Tx timeouts 0,0,1,0,0,0 last cancelled message type 30 dest 127
                        === Network ===
                        Slowest loop: 46.76ms; fastest: 0.03ms
                        Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                        HTTP sessions: 1 of 8
                        = Ethernet =
                        State: active
                        Error counts: 0 0 0 1 0 0
                        Socket states: 5 2 2 2 2 0 0 0
                        = WiFi =
                        Network state is disabled
                        Module is disabled
                        === Multicast handler ===
                        Responder is inactive, messages received 0, responses 0
                        4/27/2023, 9:17:08 PM 	Error in start-up file macro line 1: Bad command: =
                          Phaedrux Moderator @supertb1
                          @supertb1 said in CoreXY 1HCL issues 3.5b3:
                          Is this what you mean?
                          • supertb1undefined
                            supertb1 @Phaedrux
                            @Phaedrux yes
                            OwenDundefined 1 Reply Last reply Reply Quote 0
                            • OwenDundefined
                              OwenD @supertb1
                              @supertb1
                              You have an = sign before the comment ; on line 1 of your config
                              supertb1undefined 1 Reply Last reply Reply Quote 1
                              • supertb1undefined
                                supertb1 @OwenD
                                @OwenD thank you
                                • supertb1undefined
                                  supertb1 @supertb1
                                  @supertb1 @Phaedrux, please go ahead and mark this issuer as solved. Thanks for every one help.
