    I cannot print from the SD card on the Fytsec display
    • donpedroundefined
      donpedro
      Hello
      I configured Duet 3 mini 5+ wifi with Fysetc Mini12864 Panel V2.1
      Something is not working
      I can control the printer but I can't print from the SD card mounted in the Mini12864
      It does not appear on the display
      What can it be?
      these are the settings for the display
      M918 P2 E2 F2000000
      M150 X2 R255 U255 B255 S3
      M21
      M21 P1
      M23 filename.gco
      M24
      M25
      M26 S49315
      M32 filename.g
      M32 "filename.g"
        droftarts administrators @donpedro
        @donpedro Can you see files on, and run files from, the external SD card in DWC? Which menu system set are you using on the LCD (see https://docs.duet3d.com/User_manual/Connecting_hardware/Display_12864_menu#configuration)?
        Most likely, you need to change the menu system to @JadonM's Ultimate Duet Menu System, which, as far as I know, is the only one that works with external SD cards on the Mini12864 display itself.
        donpedroundefined 2 Replies Last reply Reply Quote 0
        • donpedroundefined
          donpedro @droftarts
          @droftarts I can see and use all the files, including the macro, but I can't print from the external sd card
          I use RRf 3.4 and I put this menu for mini 12864 https://github.com/tinkerlifeprojects/DUET3D_12864LCD_MenuFiles
          I think this is where the problem lies
          I will put the one recommended by you
          • donpedroundefined
            donpedro @droftarts
            @droftarts Solved, thank you
              @donpedro I've moved JadonM's menu system to the top of the list of menu systems here https://docs.duet3d.com/en/User_manual/Connecting_hardware/Display_12864_menu#configuration and added a note about it currently being the only one to support printing from the external SD card on the display.
              • droftartsundefined droftarts marked this topic as a question
              • droftartsundefined droftarts has marked this topic as solved
