    Duet 6XD "halted" and show restart , why?
    • FBGundefined
      FBG
      i use duet 6XD some days and everything was ok, but now while i am printing or not, the board show me the message for restart...
      Emergency stop, attemping to reconnect...
      I don't know why, i dont have any input config that restart the board for any alarm or similar.
      This is the M122 that give me after restart.
      Any idea?
      M122
      RepRapFirmware for Duet 3 MB6XD version 3.4.5 (2022-11-30 19:41:59) running on Duet 3 MB6XD v1.0 or later (SBC mode)
      Used output buffers: 1 of 40 (12 max)
      Static ram: 151200
      Dynamic ram: 65076 of which 0 recycled
      Never used RAM 134396, free system stack 219 words
      Tasks: SBC(ready,0.5%,511) HEAT(notifyWait,0.0%,374) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,343) MAIN(running,96.9%,1232) IDLE(ready,2.6%,29), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:00:32 ago, cause: software
      Last software reset at 2023-05-04 14:57, reason: User, none spinning, available RAM 130916, slot 1
      Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      Step timer max interval 18465
      MCU temperature: min 36.8, current 37.0, max 47.2
      Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
      Events: 0 queued, 0 completed
      Driver 0: ok
      Driver 1: ok
      Driver 2: ok
      Driver 3: ok
      Driver 4: ok
      Driver 5: ok
      Date/time: 2023-05-04 14:58:31
      Slowest loop: 25.43ms; fastest: 0.04ms
      === Storage ===
      Free file entries: 10
      DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 165, received 0, lost 0, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 165/0/0
      Tx timeouts 0,0,164,0,0,0 last cancelled message type 30 dest 127
      === SBC interface ===
      Transfer state: 5, failed transfers: 0, checksum errors: 0
      RX/TX seq numbers: 1616/1616
      SPI underruns 0, overruns 0
      State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2b770
      Buffer RX/TX: 0/0-0, open files: 0
      === Duet Control Server ===
      Duet Control Server v3.4.5
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 13
      Full transfers per second: 51.67, max time between full transfers: 257.0ms, max pin wait times: 36.0ms/10.0ms
      Codes per second: 1.98
      Maximum length of RX/TX data transfers: 3008/844
      dc42undefined chrishammundefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @FBG
        @FBG that reset code indicates that the SBC commanded the Duet to reset. More info may be available in the DSF logs.
        FBGundefined 1 Reply Last reply Reply Quote 0
        • FBGundefined
          FBG @dc42
          @dc42 Where i can find DSF logs?
          • oliofundefined
            oliof @FBG
            @FBG
            1. log into your Single Board Computer
            2. run sudo journalctl -xe -u duetcontrolserver
            • chrishammundefined
              chrishamm administrators @FBG
              @FBG E-STOP from the SBC is only triggered if it is part of a macro file or when you hit E-STOP on the UI. There is no other mechanism that calls it. Also, E-STOP on DWC restarts the board as well, it doesn't leave the machine in the "Halted" state.
              Do you have any other triggers configured? A trigger can be set up to halt the machine as well, and if there is a dodgy connection to it, that could explain it.
              Duet software engineer
              • FBGundefined
                FBG
                Hello everybody,
                after send the code for the dsf log this said that trigger6 do the restart...
                I checked trigger6 and my config.g and is truth... i did a mistake in the config.g file...
                Sorry for that, i was desperate!!
                Thanks for your support!
                • jay_s_ukundefined jay_s_uk marked this topic as a question
                • jay_s_ukundefined jay_s_uk has marked this topic as solved
