    Delta bedlevelling
    856
    • tecnoundefined
      tecno
      Question:
      Can the meshlevelling handle this or not?
      tecnoundefined 2 Replies Last reply Reply Quote 0
      • tecnoundefined
        tecno @tecno
        After many hours of testing different settings I have made following observation.
        My large printbed shows in below image that I have issues with the effector is that it bows far out of pattern points.
        I think it is the way extruder is mounted on effector makes it unstable.
        Have to rethink how to get the extruder mounted to minimize the total effector weight.
        Any ideas you guys have to share is welcome.
        weed2allundefined 1 Reply Last reply Reply Quote 0
        • tklnundefined
          tkln
          Did you run a Auto calibration?
          G32
          Did you tune those two things?
          M665  L### R### H### B### X### Y### Z###
          M666 S### X### Y### Z###
          tecnoundefined 1 Reply Last reply Reply Quote 0
          • tecnoundefined
            tecno @tkln
            @tkln
            G32 Yes several times saved M500
            M665/M666 Tune? (Aint the tune done with G32 with saved values in config-override?)
            • tecnoundefined
              tecno @tecno
              @tecno said in Delta bedlevelling:
              Question:
              Still hoping to get answers to this question
              What + - range can be done?
              • weed2allundefined
                weed2all @tecno
                @tecno your orbiter mounting is not good...I already told you on the other thread you asked...the orbiter mounting can't be in contact with the strain gauge of the smart effector because will not work properly, it only need to be connected with the 3 point mount holes and not the entire surface!
                https://www.thingiverse.com/weed2all/designs
                • tecnoundefined
                  tecno @weed2all
                  @weed2all
                  It has only 3 contact points + the E3DV6 style thread
                  • tecnoundefined
                    tecno @tecno
                    Seems to be a hot potatoe as nobody cares to answer the range of functional mesh compensation.
                      droftarts administrators @tecno
                      @tecno The mesh compensation can probably account for the bed deviation (from memory there isn't any practical limit), but what is the reason the bed is deformed? Most likely is effector tilt. Have a look at http://boim.com/DeltaUtil/CalDoc/Calibration.html and see if any of those examples match your bed shape. I assume you have been through this page too: https://docs.duet3d.com/en/User_manual/Tuning/Delta_calibration
                      Any reason you're using a square mesh, rather than a round one? If you have a round bed (and you may have a square one) your M557 should have an R parameter rather than X and Y, eg M557 R130 S20
                      See https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_mesh_bed#define-the-mesh-size-and-spacing
                      • tecnoundefined
                        tecno @droftarts
                        @droftarts
                        1. M557 R240 S80 and it gives the result as seen in pictures
                        droftartsundefined 2 Replies Last reply Reply Quote 0
                          @tecno Can you post your config.g? And M115 response.
                          • tecnoundefined
                            tecno @droftarts
                            @droftarts
                            M115
                            FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.4.5 ELECTRONICS: Duet 3 Mini5plus Ethernet FIRMWARE_DATE: 2022-11-30 19:41:16
                            4f0dead3-6363-4140-b2fe-e93db7c36ceb-config.g
                            1930649a-c3ad-4e83-8a70-1498e7f0b954-config-override.g
                              Actually, it's the probe spacing S80 (ie 80mm) that is causing it to be square. It can't get into the edges with that value.
                              • tecnoundefined
                                tecno @droftarts
                                @droftarts
                                M557 R240 S30
                                  @tecno There definitely seems to be a lot of variation in the measurements. Your current probe setup is:
                                  M558 P8 R0.4 C"io3.in+io4.out" H50 F1200
                                  See M558 in the Gcode dictionary. I'd say reduce the probe feed speed (F) down to something slower (my delta probes at 120, but it isn't a smart effector) (see following post). You can always have a fast travel speed (T, which is missing from yours). Reduce the dive height (H) to speed up probing, doesn't need to lift 50mm each time. And you can probe multiple times (A) to improve accuracy based on tolerance (S). I'd try something like:
                                  M558 P8 R0.4 C"io3.in+io4.out" H10 F1200 T6000 A5
                                  Use that and see if you get a smoother mesh. It's difficult to tell what else is going on otherwise.
                                    @tecno Sorry, the docs say to use F1200, so keep that for now. If the bed mesh doesn't improve with the other settings, try varying this speed, as it is possible the weight of the extruder makes a difference.
                                    • tecnoundefined
                                      tecno @droftarts
                                      @droftarts
                                      I can not run A in M558 errors out in
                                      M140 P0 S0
                                      Error: Z probe readings not consistent
                                      Sensitivity is set like this after a lot of testing.
                                      m672 s105:039:216
                                      So I think that no extruder is working directly on the effector
                                      • tecnoundefined
                                        tecno @tecno
                                        I have now tried to get the Smart Effector to work properly but no.
                                        M672 is now set to 10:245 and still I do not get all points probed.
                                        Only my Phaetus Dragon water cooled is mounted on the board.
                                        So I want to get this board replaced.
                                          dc42 administrators @tecno
                                          @tecno when and where did you purchase it?
                                          • tecnoundefined
                                            tecno @dc42
                                            Trying to PM you
                                            WAC-UYIQAQU look tru all details!
