    Input Shaping plugin not collecting data using 3.5.0-beta.3
    Beta Firmware
    906
    • tasundefined
      tas @ctilley79
      @ctilley79 Thanks. I will give that a try now.
      • tasundefined
        tas @ctilley79
        @ctilley79 I went back to 3.4.5 and installed the external Input Shaping plugin.
        Everything worked as expected and I was able to gather data normally.
        I reupgraded to 3.5.0-beta.3 and I get "Data collection cancelled" again.
        • OwenDundefined
          OwenD
          Duet 2 WiFi 3.5.0-beta.3+
          Duet WiFi Server 2.1beta4
          Duet Web Control 3.5.0-beta.3
          I get the same thing.
          I deleted the external plugin. Cleared the cache and refreshed DWC
          What I do note is that the file is actually recorded, but it isn't visible in the plugin motion analysis
          See screen capture
          tasundefined 2 Replies Last reply Reply Quote 0
          • tasundefined
            tas @OwenD
            @OwenD Thanks. At least I am not going crazy.
            I did notice there are files being created but I am not sure if they are valid.
            I got the same thing with 3.5.0-beta.3 and 3.5.0-beta.3+.
            • tasundefined
              tas @OwenD
              @OwenD @chrishamm @dc42 I decided to look further into the files and you are absolutely correct @OwenD. The csv files are there and they appear to be valid, they just don't show up.
              I found a workaround. If you install DWC 3.4.5 then the external input shaping plugin, v3.4.1-b1 the input shaping works as expected and all of your files will be revealed. You can do more tests without errors.
              omniundefined 1 Reply Last reply Reply Quote 0
              • omniundefined
                omni @tas
                @tas I am having the same problem, and I uninstalled the external plugin. But I found a workaround without going back to the old external plugin - just click the refresh icon on the profiles list and they will appear. I too get a message that it was not recorded, but in fact it was, it's just a small bug probably.
                tasundefined 1 Reply Last reply Reply Quote 0
                • tasundefined
                  tas @omni
                  @omni Thanks for that you are correct. Much easier than going back to DWC 3.4.5.
                  Just refreshing the profiles in the Motion Analysis tab brings up the latest run.
                  However no matter what Input Shaper function or damping factor I apply the graphs are all pretty similar. I am not sure the data is valid. Also, in the Profile description it says 1 move but I asked for two. It always used to say 2 moves.
                  I agree it is probably a small bug and will go away in the next release.
                  • chrishammundefined
                    chrishamm administrators @tas
                    @tas There is another problem in v3.5-b3 affecting filename parsing of newer profiles, but that is about to be fixed in 3.5-b4. I've also added new code to auto-remove the old IS plugin if it is still installed.
                    Duet software engineer
                    tasundefined 1 Reply Last reply Reply Quote 2
                    • tasundefined
                      tas @chrishamm
                      @chrishamm Many thanks for that excellent support. I knew you would be on top of it.
                      • tasundefined tas referenced this topic
                      • alexjxundefined alexjx referenced this topic
                      • tasundefined
                        tas @tas
                        @tas This problem has now been solved by @chrishamm. Refer to this post by @alexjx
                        https://forum.duet3d.com/topic/32762/3-5b4-input-shaping-plugin-bug-data-collection-cancelled/13?_=1687311263398
                        Go down to the google drive link provided.
                        Thanks for the combined effort @chrishamm, @droftarts, and @jay_s_uk. Also thanks to @alexjx for zeroing in on the problem so it could be solved.
                        • droftartsundefined droftarts marked this topic as a question
                        • droftartsundefined droftarts has marked this topic as solved
