Help with hotend not showing in DWC
@Phaedrux no problem.
; Configuration file for Duet 3 MB 6HC (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Sat May 13 2023 19:27:15 GMT-0400 (Eastern Daylight Time) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Duet 3" ; set printer name M669 K1 ; select CoreXY mode , ----+---- , | 2 | 3 | , |---+---| , | 1 | 4 | , ----+---- , FRONT ; Drives M569 P1.0 S0 ; physical drive 1.1 goes forwards Y DRIVE M569 P1.1 S0 ; physical drive 1.0 goes forwards X DRIVE M569 P0.1 S0 ; physical drive 0.1 goes forwards FL Z DRIVE M569 P0.2 S1 ; physical drive 0.2 goes forwards RL Z DRIVE M569 P0.3 S0 ; physical drive 0.3 goes forwards RR Z DRIVE M569 P0.4 S1 ; physical drive 0.4 goes forwards RF Z DRIVE M569 P0.0 S0 ; physical drive 0.0 goes forwards EXTRUDER DRIVE M584 X1.1 Y1.0 Z0.1:0.2:0.3:0.4 E0.0 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X25 Y25 Z30 S1 ; set axis minima M208 X300 Y300 Z200 S0 ; set axis maxima ; Endstops M574 X2 S3 ; configure sensorless endstop for high end on X M574 Y2 S3 ; configure sensorless endstop for high end on Y M574 Z1 S1 P"!121.io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin !121.io2.in ; Z-Probe M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X40:215 Y40:195 S20 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"BedTemp" ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp1" Y"thermistor" T100000 B4725 A"NozzleTemp" ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Fans M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined -
@frnknstn518 I figured it out. Just not the -273 temp
; Configuration file for Duet 3 MB 6HC (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Sat May 13 2023 19:27:15 GMT-0400 (Eastern Daylight Time) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Duet 3" ; set printer name M669 K1 ; select CoreXY mode , ----+---- , | 2 | 3 | , |---+---| , | 1 | 4 | , ----+---- , FRONT ; Drives M569 P1.0 S0 ; physical drive 1.1 goes forwards Y DRIVE M569 P1.1 S0 ; physical drive 1.0 goes forwards X DRIVE M569 P0.1 S1 ; physical drive 0.1 goes forwards FL Z DRIVE M569 P0.2 S0 ; physical drive 0.2 goes forwards RL Z DRIVE M569 P0.3 S1 ; physical drive 0.3 goes forwards RR Z DRIVE M569 P0.4 S0 ; physical drive 0.4 goes forwards RF Z DRIVE M569 P0.0 S0 ; physical drive 0.0 goes forwards EXTRUDER DRIVE M584 X1.1 Y1.0 Z0.1:0.2:0.3:0.4 E0.0 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X25 Y25 Z30 S1 ; set axis minima M208 X300 Y300 Z200 S0 ; set axis maxima ; Endstops M574 X2 S3 ; configure sensorless endstop for high end on X M574 Y2 S3 ; configure sensorless endstop for high end on Y M574 Z1 S1 P"!121.io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin !121.io2.in ; Z-Probe M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X40:215 Y40:195 S20 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"BedTemp" ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 Q10 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 A"NozzleTemp" ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Fans M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined -
@frnknstn518
Most likely a bad connection on the thermistor
https://docs.duet3d.com/User_manual/Troubleshooting/FAQ -
@OwenD i checked wiring. i also put a new one in to see if that was it. It still says -273
@frnknstn518 this is going to the out0 on the 1lc toolboard. is this correct?
@frnknstn518 That's the default value that DWC shows when a heater is "off". It should read ambient once you select a tool. You can do that automatically by adding "T0" to the end of your config.g file (without the quotes).
@deckingman I feel like i dont have my heater settings correct.
could someone look at this.; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"BedTemp" ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out1" T0 Q10 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 A"NozzleTemp" ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C I have bed heater on out1, the temp sensor on temp0
the nozzle is on 1LC board 121 0ut0 and that temp sensor is on 121 temp0. just not sure what im missing -
@frnknstn518 ok so the bed heats up properly...just figuring out the nozzle heater
@frnknstn518 said in Help with hotend not showing in DWC:
How far have you got and what have you tried? From your config.g I can see that you have used G10 to set the initial active and standby temperatures to zero. So if you select that tool by sending T0, the active and standby temperature readings should change to zero. Then if you alter the active temperature, it should heat.
@deckingman figured it out. you were correct. I bought a brand new E3D RapidChange Revo Voron Hotend. Its broke before even using it. swapped out for the phateus dragon setup i had and it all works now.
