    Solved Configuring endstop location
    • SanderLPFRG
      SanderLPFRG last edited by
      From what I can find I can only configure endstops at high or low end of an axis. However, on my machine the Y endstop location is outside of the print area.
      Is it possible to set seperate endstop location? (FE Ymin=0 / Ymax=250 / Yendstop=270)
      Hope to hear from someone.
      Kind regards, Sander
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @SanderLPFRG last edited by
        @SanderLPFRG thats fine if its outside the print area, just lower the M208 minima. E.g. if you home off the bed by 20mm, set M208 Y-20 S1 and so on
        SanderLPFRG 1 Reply Last reply Reply Quote 0
        • SanderLPFRG
          SanderLPFRG @jay_s_uk last edited by
          @jay_s_uk Yeahh so mine axis maximum should be 270 instead of 250?
          jay_s_uk JoergS5 2 Replies Last reply Reply Quote 0
          • jay_s_uk
            @SanderLPFRG yep, you've got it
            • JoergS5
              JoergS5 @SanderLPFRG last edited by
              @SanderLPFRG after homing according to jay_s_uk, I would move the hotend to a printable area and set M208 to the original values. M208 is used to protect against printing at unprintable areas.
              • mrehorstdmd
                mrehorstdmd last edited by
                You might want to consider setting the origin at the center of the bed. That will make it a little easier to use different slicers. In that case you would set the Y endstop at Y=145, Y max = 125, and Ymin at -125. You'd set up the X axis in a similar way.
                In Prusa Slicer you specify the bed is 250 x 250 and the X and Y offsets are 125 and 125.
                Cura defaults to center origin, so you wouldn't have to change anything.
                Using a center origin would also allow some portability of the gcode from one printer to another, assuming the print doesn't exceed the bed or Z size on either printer, and several other factors are the same (nozzle diameter, etc.).
                • Topic has been marked as solved  SanderLPFRG SanderLPFRG
