    Rotating magnet filament sensor with "external" print
    • benecitoundefined
      benecito
      We're just trying to upgrade our simple out of filament sensor to something more advanced and obviously first looked at the duet option.
      As we are using RepetierServer for printing it's not a print from SD card and from my initial test and the documentation kind of sounds like it's simply not possible even though the A1 option in the M591 command kind of sounds like it could be possible.
      On my first try it worked when printing from SD but not from externally.
      Can someone please clarify if it's possible or in case if it's possible to change that behavior for a future release?
      All we need is filament-error.g to be called and we can take it from there.
        jay_s_uk @benecito
        @benecito see this thread. it hasn't been implemented yet https://forum.duet3d.com/topic/31221/filament-monitoring-while-printing-via-usb?_=1685740576518
        benecitoundefined 1 Reply Last reply Reply Quote 0
        • benecitoundefined
          benecito @jay_s_uk
          @jay_s_uk Thanks! Any update on when it will / might be available?
            jay_s_uk @benecito
            @benecito no idea. it wasn't in the github issues log either so i've just created one for it. https://github.com/Duet3D/RepRapFirmware/issues/862
            jaysuk created this issue in Duet3D/RepRapFirmware
            closed [FeatureRequest]: M591 filament monitoring option for USB control #862
            benecitoundefined 1 Reply Last reply Reply Quote 1
            • benecitoundefined
              benecito @jay_s_uk
              @jay_s_uk fair enough and thanks - please also make sure it does not only work on USB as we are using the DSF socket in SBC mode for communication.
