    H1 command for an endstop switch (microswitch)
    Using Duet Controllers
    515
    • axiomundefined
      axiom
      Can I use the H1 command for an endstop switch (microswitch) even though I already have a first endstop (capacitive sensor)....how does the software know which switch is meant?
        jay_s_uk @axiom
        @axiom you would have to remap the endstop. You can only have 1 at a time for each axis
        axiomundefined 1 Reply Last reply Reply Quote 0
        • axiomundefined
          axiom @jay_s_uk
          @jay_s_uk Ungefähr 18.000.000 Ergebnisse (0,30 Sekunden)
          Deutsch
          Englisch
          Apparently it recognizes both, see the screenshot...I made different "K" assignments in config.g and both react. I only want to use the microswitch for the auto z-offset...since the puck is 15mm high, do I have to set the z-offset to -15? (see config.g but commented out)...so I thought I'd let the printhead go to a certain position, set the microswitch/puck darunger : G1 x300 y300 z30 and do the H1 command, and set the Z to 0 (G92 z0) then I run the capacitive sensor over the puck and read the offset via G30 S-1. Is this the right way or will I crash my bed?2e8e82c6-ff92-4381-bec2-b6b445c0b384-grafik.png
          ; Z-Probe two of them
          M558 K0 P1 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
          M558 K1 P8 A2 S0.2 C"zstop" H5 F80 T3000
          G31 P1000 X-1 Y-61 Z2.9 ; set Z probe trigger value, offset and trigger height
          ;G31 P1000 X50 Y50 Z-15 ; Second Z-offset
          M557 X0:740 Y-27:611 S35 ; define mesh grid
          jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @axiom
            @axiom so you mean probes and not endstops. That's different, you can have more than one. Just make sure you use the correct K value when using G30 and you'll be fine
              dc42 administrators @axiom
              @axiom it sounds to me that your "endstops" are actually configured as Z probes. You can indeed have more than one Z probe.
              The usual way of homing using a Z probe is to use the G30 command, and you can provide a K parameter with this command to tell it which Z probe to use.
              If the microswitch triggers when the nozzle if 15mm higher than the bed then you should set the G31 Z parameter for that probe to 15. For historical reasons the Z parameter isn't the offset, it's the trigger height (the negative of the offset). Again, use the K parameter of the G31 command to specify which probe that command refers to.
              • axiomundefined
                axiom @dc42
                @dc42 I have now made the following entry in cofig.g:
                G31 P1000 K0 X-1 Y-61 Z2.3 ; set Z probe trigger value, offset and trigger height
                G31 P1000 K1 X0 Y0 Z15 ; Second Z offset
                M557 X0:740 Y-27:602 S35 ; define mesh grid
                When I first go to z=50 (G1 z50= and enter G30 K1 via the console, I get the message: "Error: Probe already triggered at start of probing move"
                  @axiom are you using the normally-open or normally-closed microswitch contacts?
                  Your DWC screen shot indicates that Z probe K1 is registered as triggered (the value is 1000). Was that correct?
                  • axiomundefined
                    axiom @dc42
                    @dc42 I don't quite understand that...how do I recognize that?...if I bring the contacts of the microswitch (puck) together (bring them into contact...i.e. nozzle and puck) the display for the probe goes to zero.. .that's actually correct, isn't it?
                      P1000 means triggered
                      P0 means not triggered
                      • axiomundefined
                        axiom @Phaedrux
                        @Phaedrux got it... just had to say "!" put in front of the name of the connection. G30 K1 works. But I would like to read the value and set this value minus the 15mm (height of the puck) as Z=0.
                          Phaedrux Moderator @axiom
                          @axiom said in H1 command for an endstop switch (microswitch):
                          I don't understand what you mean exactly.
                          axiomundefined 2 Replies Last reply Reply Quote 0
                          • axiomundefined
                            axiom @Phaedrux
                            @Phaedrux I would like to use it to automatically measure the z-offset...so I no longer have to put paper underneath it
                            • axiomundefined
                              axiom @Phaedrux
                              @Phaedrux so I need to be able to set the trigger value as z=0.
                                What is the puck you mention? Can you show a photo of your setup?
                                • axiomundefined
                                  axiom @Phaedrux
                                  The part with the blue cap is the capacitive sensor, the part on the glass plate on the heatbed is the "puck/microswitch". Contact with the printhead triggers it...that works
