    Max file count error
    • Ethelredundefined
      Ethelred
      I'm getting a "max open file count" error message displays on PanelDue upon system bootup. Supposedly V3.5.0-b4 permits 20 open files. I have only 13 macros total with no nesting. I see no ill effects - printing perfectly. Duet-2 board.
        jay_s_uk @Ethelred
        @Ethelred can you post your config.g and any other called macros as well as daemon.g
        Ethelredundefined 1 Reply Last reply Reply Quote 0
        • Ethelredundefined
          Ethelred @jay_s_uk
          @jay_s_uk No daemon.g present - config.g below.
          Perhaps interesting is that the error message appears on PanelDue only but not on the DWC console window.
          config.g
            What version is your paneldue firmware?
            Do you get the error again if you send M98 P"config.g"?
            • Ethelredundefined
              Ethelred @Phaedrux
              @Phaedrux said in Max file count error:
              M98 P"config.g"
              PanelDue 1.22.1 (28b1)
              M98 P - error flash on both PanelDue and on DWC console screen
              • Ethelredundefined
                Ethelred @Ethelred
                @Ethelred
                Flashed an updated PanelDue binary and all is well - gadzooks, the previous version was pre-historic.
                Thanks to all for the help.
                • dc42undefined dc42 marked this topic as a question
