    SBC Not updating to 3.5 beta 4.
    • IndeX4Dundefined
      IndeX4D
      hello,
      I wanted to update via sbc like everytime. Now, updating has not finished.
      I have still 3.5 beta 3, which is a problem cause of the extruding bug.
      MY other printer with same setup had no problems....
      may somebody could give me a helpful advice.
      thanks
        Can you try swapping back to the stable branch
        https://docs.duet3d.com/en/User_manual/Machine_configuration/DSF_RPi#switch-to-stable-packages
        and then change to the test branch again?
        https://docs.duet3d.com/en/User_manual/Machine_configuration/DSF_RPi#switch-to-unstable-packages
        IndeX4Dundefined 1 Reply Last reply Reply Quote 0
        • IndeX4Dundefined
          IndeX4D @Phaedrux
          @Phaedrux
          yes, was working!!!
          thank you
