WIFI CONECTION
  • undefined
    Polo
    Hi all
    I recently change my router and had to reconnect my board duet3 mini WIFI. But I see I'm loosing connection. it goes back in forth. I didn't have this problem until I changer my router. Any ideas why ??
    undefined 1 Reply Last reply 1 Jul 2023, 11:16 Reply Quote 0
    • undefined
      droftarts administrators @Polo
      @Polo what is your make and model of your router? Please post a full M122 output from your Duet board. Also see https://docs.duet3d.com/en/User_manual/Troubleshooting/WiFi_troubleshooting
      undefined 1 Reply Last reply 2 Jul 2023, 21:02 Reply Quote 0
      • undefined
        Polo @droftarts
        @droftarts
        Hi
        here is the model of my modem !!!
        BGW320-505
        Thanks
        code_text
        ```7/2/2023, 3:25:15 AM Connection established
        7/2/2023, 3:25:15 AM Connection interrupted, attempting to reconnect...
        Network error
        7/2/2023, 3:23:31 AM Connection established
        7/2/2023, 3:23:31 AM Connection interrupted, attempting to reconnect...
        Network error
        7/2/2023, 3:23:23 AM Connection established
        7/2/2023, 3:23:23 AM Connection interrupted, attempting to reconnect...
        Network error
        7/2/2023, 3:21:23 AM m122
        RepRapFirmware for Duet 3 Mini 5+ version 3.4.5 (2022-11-30 19:41:16) running on Duet 3 Mini5plus WiFi (standalone mode)
        Board ID: 5PQ93-S296U-D65J0-40KMG-1A03Z-7DGLP
        Used output buffers: 1 of 40 (33 max)
        Static ram: 103652
        Dynamic ram: 110472 of which 60 recycled
        Never used RAM 23808, free system stack 118 words
        Tasks: NETWORK(notifyWait,15.1%,197) HEAT(notifyWait,0.0%,320) Move(notifyWait,0.4%,265) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,326) CanClock(delaying,0.0%,333) TMC(notifyWait,1.2%,72) MAIN(running,82.1%,417) IDLE(ready,0.2%,30) AIN(delaying,0.9%,263), total 100.0%
        Owned mutexes:
        Last reset 10:21:58 ago, cause: power up
        Last software reset at 2023-07-01 05:38, reason: User, GCodes spinning, available RAM 27360, slot 0
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
        Error status: 0x00
        MCU revision 3, ADC conversions started 37320849, completed 37320848, timed out 0, errs 0
        Step timer max interval 1479
        MCU temperature: min 44.2, current 50.1, max 50.6
        Supply voltage: min 26.9, current 27.1, max 27.1, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/496/496, gc cycles 0
        Events: 0 queued, 0 completed
        Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 36, reads 40096, writes 5, timeouts 0, DMA errors 0, CC errors 0
        Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 36, reads 40096, writes 5, timeouts 0, DMA errors 0, CC errors 0
        Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 36, reads 40097, writes 5, timeouts 0, DMA errors 0, CC errors 0
        Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 30, reads 40099, writes 2, timeouts 0, DMA errors 0, CC errors 0
        Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 30, reads 40099, writes 2, timeouts 0, DMA errors 0, CC errors 0
        Driver 5: standstill, SG min 0, read errors 0, write errors 0, ifcnt 22, reads 40099, writes 2, timeouts 0, DMA errors 0, CC errors 0
        Driver 6: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 40101, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Date/time: 2023-07-02 03:21:22
        Slowest loop: 787.14ms; fastest: 0.08ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 5.8ms, write time 111.0ms, max retries 0
        DMs created 83, segments created 36, maxWait 202027ms, bed compensation in use: none, comp offset 0.000
        === MainDDARing ===
        Scheduled moves 567, completed 567, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 9], CDDA state -1
        === AuxDDARing ===
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty
        === CAN ===
        Messages queued 3971, received 0, lost 0, boc 0
        Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 2206/0/0
        Tx timeouts 0,0,2206,0,0,1765 last cancelled message type 4514 dest 127
        === Network ===
        Slowest loop: 532.25ms; fastest: 0.06ms
        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        HTTP sessions: 1 of 8
        = WiFi =
        Network state is active
        Failed messages: pending 0, notready 0, noresp 4
        WiFi firmware version 1.27
        WiFi MAC address d8:bf:c0:14:e8:37
        WiFi Vcc 3.38, reset reason Power up
        WiFi flash size 2097152, free heap 23424
        WiFi IP address 192.168.1.118
        WiFi signal strength -41dBm, mode 802.11n, reconnections 0, sleep mode modem
        Clock register 00002002
        7/2/2023, 3:21:09 AM M0
        Cancelled printing file 0:/gcodes/First layer calibration_0.3mm_PLA_3m.gcode, print time was 0h 2m
        7/2/2023, 3:21:08 AM M25
        Resume state saved
        Warning: Macro file pause.g not found
        Printing paused at X28.3 Y42.0 Z0.2
        1 out of 3
