    Temperature control for Heating Bed
    1.1k
      jay_s_uk @deckingman
      @deckingman the else is part of the job layer check, not the temperature check so it will only be turned off when the job is equal to or above 20 layers
      • bernardomattiucciundefined
        bernardomattiucci @deckingman
        @deckingman As @jay_s_uk said, That M140 S0 is related to layer control and is activated from layer 20 and up. This is because, after 3 hours of printing, the bed temperature is stable at 30°C and is more than enough to maintain the part. So there is no need, at the moment, to have the bed heater on (in winter we will see...).
        • deckingmanundefined
          deckingman @bernardomattiucci
          @bernardomattiucci said in Temperature control for Heating Bed:
          Ahh - apologies for missing that "else" being related to the layer value. So, yes, I'd have thought your proposal should work.
            bernardomattiucci
            I modified the code slightly to keep the heater on at the set temperature of 50° for the first 5 layers.
            if {state.status} = "processing"
            	if {heat.heaters[1].active} > 0
            		if {job.layer} > 5
            			if {job.layer} < 20
            				if {heat.heaters[0].current} < 40
            					M140 S50
            				if {heat.heaters[0].current} > 50
            					M140 S40
            			else
            				M140 S0
            		else
            			M140 S50
            the problem is that, at the beginning of printing, I get the following error:
            Error: in file macro line 3 column 27: meta command: cannot convert operands to same type
            The error occurs when I manually activate the heaters (hotend and bed) and then run the press
              bernardomattiucci
              I fixed the errors in the code.
              if job.build != null
              	if job.layer != null && job.layer <= 5
              		M140 S50
              	elif job.layer != null && job.layer > 5
              		if job.layer < 20
              			if heat.heaters[0].current < 40
              				M140 S50
              			if heat.heaters[0].current > 50
              				M140 S40
              		else
              			M140 S0
                bernardomattiucci
                I would like to make a change to the code, but I don't know how to do it.
                if job.layer < 20
                I would like to consider 20% and not layer number 20.
                How should I modify the code?
                  jay_s_uk @bernardomattiucci
                  @bernardomattiucci you would have to calculate what 20% of job.file.numLayers is
                    bernardomattiucci
                    		M140 S50
                    		if ((job.file.numLayers*20)/100) < 20
                    				M140 S50
                    				M140 S40
                    		else
                    			M140 S0
                    seems to be working
                      bernardomattiucci
                      More update
                      	if job.layer != null && job.layer < 5
                      		M140 S50
                      	if job.layer != null && job.layer >= 5 && job.layer < (job.file.numLayers*20)/100
                      			M140 S50
                      			M140 S40
                      	if job.layer != null && job.layer > (job.file.numLayers*20)/100
                      		M140 S0
