    pinout of TEMP_DB on Maestro
    317
    • Fireflyundefined
      Firefly
      I am connecting an accelerometer to a Maestro following this guide
      https://docs.duet3d.com/User_manual/Connecting_hardware/Sensors_Accelerometer
      the guide tells us what wire # to connect to what on accelerometer but the pins# not shown on the board or Duet Maestro Connections diagram.
      I don't trust the image because some # start from right to left and others starts from left
      which pin# is 1 and which is pin#2
      I am not using a flat ribbon cable, I know red stripe is pin 1 but I do not know if that goes to top or bottom.
        dc42 administrators @Firefly
        @Firefly if you can see the underside of the board then the pins should be labelled there.
        Fireflyundefined 1 Reply Last reply Reply Quote 0
        • Fireflyundefined
          Firefly @dc42
          @dc42 I really don't want to remove the board from the printer.
          • Fireflyundefined
            Firefly
            anyone had a Maestro out that can take a picture of the back?
            DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
            • Fireflyundefined
              Firefly
              found this picture, it does not appear to be marked on backside.
              • DIY-O-Sphereundefined
                DIY-O-Sphere @Firefly
                @Firefly
                Unfortunately no labels can by seen
                (UTC+1)
                • Fireflyundefined
                  Firefly @DIY-O-Sphere
                  @DIY-O-Sphere thank you for the picture.
                  • Fireflyundefined
                    Firefly
                    ok, I was able to confirm with the multimeter, with power off and using continuity to find where GND and 3.3v is and can figure it out from there.
                    and just noticed, looking at the solder joint, the one is square is indicating pin 1.
                    Fireflyundefined 1 Reply Last reply Reply Quote 1
                    • Fireflyundefined
                      Firefly @Firefly
                      @Firefly well my attempt to get accelerometer to be recognized failed and now I fear I damaged something.
                      as when I reinstalled the thermocouple daughterboard, I am not getting a temperature reading anymore, then I realized I forgot to stop or remove the input shaping plugin. but still reading 2000C.
                      not sure where to go from here, steps on troubleshooting.
                      • Fireflyundefined
                        Firefly
                        dunno how or why, but I decided to try moving the thermocouple to second port (from left to right) and its working I didn't even update the code. I never removed the wire I just had the daughterboard unplugged.
