    Printer paused by it self?
    246
    • Reineundefined
      Reine
      I just started a print and all of a sudden the printer paused. I was there so I saw the whole thing and even on the PanelDue.
      It was printing and then just stopped, beeped and moved to the pause position. On the display it looked just like I would have tapped pause (which I didn't, wasn't even near the display).
      What could have caused this?
      After I resumed most of the filament didn't stick to the bed, that has never happened on this printer before. Something really strange. I also noticed afterwards the tool heater was marked as "fault".
      T3P3Tonyundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • T3P3Tonyundefined
        T3P3Tony administrators @Reine
        @Reine if the heater was marked as fault then I expect it was a heater fault that triggered the pause.
        What version of firmware are you running?
        Was there anything else reported in the DWC console?
        www.duet3d.com
        Reineundefined 1 Reply Last reply Reply Quote 0
          Phaedrux Moderator @Reine
          @Reine said in Printer paused by it self?:
          If the heater faulted the temp would have dropped.
          • Reineundefined
            Reine @T3P3Tony
            @T3P3Tony I'm on 3.4.6. Nothing else reported and after a restart the same print came out fine also the four prints after that.
            • T3P3Tonyundefined
              @Reine If it happens again you need to investigate the heater fault.
              www.duet3d.com
              • Reineundefined
                Reine @T3P3Tony
                This just happened again and the heater was at 200c just like it should.
                This was in the console though, not sure what it means.
                • Reineundefined
                  Reine @Reine
                  Could it be the heater overshooting? It's supposed to be 200c but I notice it overshoots to 210c before dropping.
                  Could be due to the cooling fan is inactive and I pid tuned with it on..
                  If so it's strange it started happening now and not before.
                    I suggest you retune your heater as a tool so that it can take the cooling fan into account.
                    M303 T0 S220 for example
                    https://docs.duet3d.com/User_manual/Reference/Gcodes#m303-run-heater-tuning
