Solved Creating a general purpose input and checking it
I'm trying out a simple filament switch i'm working on, and I just found out that i've never created a general purpose input in RRF before lol. And i'm having a hard time getting a reading from the switch.
The switch is a "AH3364Q-P-B" hall sensor which i've connected to IO-0 on a 1LC v1.2.
I've configured it like this
M950 J1 C"121.io0.in"
, but no matter what i do it still responds as "Active: true" when i sendM950 J1
Do i need to deploy more or different codes to make that type of hall sensor talk nice with RRF, or should it work with this config (and the hall sensor is dead)?
This post is deleted! -
@Herve_Smith
Yeah i'm aware of that. But i'm not deploying it as a filament sensor yet, now to start off i want to check that it functions correctly and logg how it works. Hence why i want to configure it as a GPIO switch first. -
@Herve_Smith
Oh your one of those, bye.....
EDIT 17/8:
Found the issue, the issue was that I had managed to use a 304SS washer to actuate the sensor, and a steel screw to hold down the sensor.
Swaped for a steel washer for actuation and a 304ss screw to fasten the sensor, now it's working
