What's the correct way to update? [SBC]
Firmware installation
351
  • undefined
    Reine
    Can someone post the correct way todo a firmware upgrade on a complete system?
    I always have to fiddle to get all my components (6HC, SBC, 1LC, Panel Due 7i) updated.
    Now with the 3.4.6-2 release I got from doing an apt update I haven't managed to get that installed, M122 still reports 3.4.6 with a compile date from July.
    After the apt update I issue the following commands:
    • M122 to confirm versions pre update
    • M997 S0 to update the 6HC
    • M997 S2 for the SBC
    • M997 B121 to finally update the 1LC
    • M122 to confirm that all components are updated
    Is this the "correct" way of doing it?
    undefined undefined 2 Replies Last reply 1 Sept 2023, 10:45 Reply Quote 0
    • undefined
      gloomyandy @Reine
      @Reine Is there a 3.4.6-2 release? I couldn't find any reference to it on the release page: https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#reprapfirmware-346
      My understanding is that for an SBC the "correct" way to do an update is using Linux tools: https://docs.duet3d.com/User_manual/Machine_configuration/SBC_setup#h-6-update-firmware
      I thought that as part of that process it offered the option to update the firmware on the board and toolboards? Is that not working for you? As to your manual approach that looks like it should work, my only question would be does M997 S2 actually update the SBC? The documentation does not say it will:
      2 - web server file system, filename DuetWebControl.bin (needed only when using RepRapFirmware 1.18 series and earlier for Duet 2 WiFi)
      But maybe it has been repurposed?
      undefined 1 Reply Last reply 2 Sept 2023, 16:04 Reply Quote 0
      • undefined
        T3P3Tony administrators @Reine
        @Reine said in What's the correct way to update? [SBC]:
        Thats the latest stable release.
        www.duet3d.com
        • undefined
          Reine @gloomyandy
          @gloomyandy I don't know if this means something else, but it sure looks like 3.4.6-2 too me.
          undefined undefined 2 Replies Last reply 2 Sept 2023, 16:09 Reply Quote 0
          • undefined
            gloomyandy @Reine
            @Reine Perhaps @chrishamm can explain. I'm not aware of any 3.4.6-2 release and it seems that what you have is the 3.4.6 release, perhaps this is some sort of packaging issue?
            • undefined
              chrishamm administrators @Reine
              @Reine Unfortunately RRF 3.4.5 made it into the first RRF 3.4.6-1 package, so I had to update the firmware binaries again. That's why it is 3.4.6-2 now. M997 can be used to update the firmware in SBC mode, too.
              The correct way to update in SBC mode is via apt update/apt upgrade as documented here.
              Duet software engineer
              undefined 1 Reply Last reply 3 Sept 2023, 08:57 Reply Quote 0
              • undefined
                Reine @chrishamm
                @chrishamm ahh ok, things happen. Are you saying a simple dist-upgrade should update firmwares on all devices?
                From my experience it only downloads the binaries, I have to manually issue M997 to update each device.
                If you could write the steps I should take to get everything updated in the correct way I would appreciate it.
                undefined 1 Reply Last reply 3 Sept 2023, 09:09 Reply Quote 0
                • undefined
                  @Reine The reprapfirmware package only holds firmware binaries for Duet boards. If you are using a third-party board, the upgrade prompt (where you see All boards are up-to-date!) does not show up. That means you will have to install firmware updates manually in SBC mode (also the reason why the Install Updates button is visible in Settings -> General then).
                  7 out of 8
