    Nozzle detach the part - Chiron Duet 2 wifi
    756
    • genioluiz7undefined
      genioluiz7
      Hi everyone,
      Some dates about the 3D printer:
      • 3D printer: Anycubic Chiron
      • Motherboard: Duet 2 WiFi
      • Firmware name: RepRapFirmware for Duet 2 WiFi/Ethernet
      • Firmware_version: 3.4.6
      You can find more details on the actual state in this other article of the forum.
      Dates:
      • Bed perfectly leveled
      • I'm printing PLA filament
      • temperature 205°C 1st layer 195°C for the others
      • The 1st layer is well attached to the bed
      • But after 2 or 3 layers the nozzle starts to make some mistakes
      • At the end the the nozzle detaches the part.
      What might be the problem?
      Following, you'll find some pictures about the problem.
      photo_5765045382521405589_y.jpg !
      As you can see the first 2 layers didn't have any problem.
      From this point forward some errors occured. Smudges expetially on the borders.
      the nozzle crashed into the model and detach the part
      You can se the precise point in the next picture
      Instead on the side attached to the bed the model is polished
      What do you think about it? Where is the problem?
        droftarts administrators @genioluiz7
        @genioluiz7 I'd guess that after the first layer, accelerations for all axes are set to normal (the first layer usually printing slower) and the Z axis can't move as fast as it is commanded, so is skipping steps. Could also be happening if you have Z-hop enabled. It's also possibly it is over-extrusion; hard to say as the two look similar.
        Post your config.g, the response to M115 in the console, and the gcode that causes the issue. Does this happen on all prints?
        genioluiz7undefined 3 Replies Last reply Reply Quote 0
          Either extremely over extruded or your z axis isn't moving the correct distance.
          To check the second one you can move to Z0, command Z up 50mm, and measure the distance with a ruler.
          genioluiz7undefined 1 Reply Last reply Reply Quote 0
          • A Former User?
            A Former User
            This post is deleted!
              genioluiz7 @droftarts
              @droftarts the following as requested:
              • config.g
                ; Configuration file for Duet WiFi (firmware version 3.3)
                ; generated by RepRapFirmware Configuration Tool v3.3.16 on Fri Aug 04 2023 19:59:42 GMT+0200 (Ora legale dell’Europa centrale)
              M550 P"Chiron" ; set printer name
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P0 S0 ; physical drive 0 goes backwards
              M569 P4 S0 ; physical drive 4 goes backwards
              M584 X0 Y1 Z2:4 E3 ; set drive mapping
              M92 X80.00 Y100.00 Z400.00 E420.00 ; set steps per mm
              M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
              M906 X1000 Y1000 Z1000 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S0 ; Disable motor idle current reduction
              M208 X-15 Y-15 Z0 S1 ; set axis minima
              M208 X400 Y400 Z440 S0 ; set axis maxima
              M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
              M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
              M574 Z1 S1 P"zstop+e1stop" ; configure active-high endstop for low end on Z via pin zstop and e1stop
              M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
              M557 X15:385 Y15:385 S60 ; define mesh grid
              M143 H1 S285 ; set temperature limit for heater 1 to 285C
              • M115
                FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.4.6 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2023-07-21 14:08:28
                @droftarts said in Nozzle detach the part - Chiron Duet 2 wifi:
                The over-extrusion is caused by the parameter "Initial Layer Flow" set to 110%
                With that parameter reset to 100% this is what happens
                Basically the same problem with the actual settings. I inform the now the bed level was set strait to the nozzle, between 0.09-0.05 mm. Instead when the bed level was set wider let's say between 0.13-0.09 mm the part comes off on its own, starting from the borders like the warping effect. But I don't know if this happened because the filament cannot cling to the surface or is always caused by the nozzle.
                  genioluiz7 @Phaedrux
                  @Phaedrux I do that check with the ruler and I'm pretty sure that the z-axis moves correctly.
                    genioluiz7 @A Former User
                    @Herve_Smith said in Nozzle detach the part - Chiron Duet 2 wifi:
                    era l'unica cosa che potevo trovare per risolvere il problema
                    based on what can I understand that the problem is caused by the motors?
                    A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
                      il gcode che causa il problema
                      https://we.tl/t-EAdg99NP5b
                      • A Former User?
                        A Former User @genioluiz7
                          @genioluiz7 It looks from your gcode file that you are printing 0.1mm layer height, and that the line width is 0.2mm. This sounds very small, and probably doesn't suit your nozzle; I think the Chiron comes with a 0.4mm nozzle. So I think there are some issues with the settings you have chosen in Cura. Can you post a picture of the settings you are using?
                          Looking at your config.g, I think your maximum instantaneous speed change (aka jerk) M566 Z value is too high for a Z leadscrew system. 60mm/min = 1mm/sec, and it may be that short Z moves don't complete properly due to inertia on the Z axis. Try reducing M566 Z to 10, by changing the following line in the '; Drives' section of your config.g:
                          M566 X900.00 Y900.00 Z10.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                          Maximum speed (M203) and Acceleration (M201) look about right to me.
                          If that doesn't help, check that the filament diameter is set correctly for the filament you are using, in Settings > Printer > Manage printers, then select your printer from the list and click 'Machine settings', then check the filament diameter on the 'Extruder 1' tab. Nozzle Settings > Compatible material diameter should match the filament diameter you are using.
                          Finally, have you calibrated the extruder? See https://docs.duet3d.com/en/How_to_guides/Calibration#h-3-calibrating-extruder-e-steps-per-mm
                            @droftarts you're completely right.
                            Do you want to see only the "quality" parameters? Or all the other too?
                            ![be9e55a0-b766-49be-9fc5-a4ab2800dd4d-image.png]
                            This is the nozzle I'm using. It's 0.4 mm, as you presaid.
                            I mesured the width of the extruded filament and is more or less 0.4 mm as you can see in the picture below
                            Have you calibrated the extruder? Unfortunately not yet. I start now. And I'll let you know the results.
                            genioluiz7undefined droftartsundefined 2 Replies Last reply Reply Quote 0
                              genioluiz7 @genioluiz7
                              I've just tried to print something easy and the resut was amazing. Really better compared to the last one. But I can see that the bottom of the part is widther compared to the rest of it. What do you think?
                                @genioluiz7 Did you change the M566 line? Did that help?
                                With the line width, you generally don't go thinner than your nozzle diameter. Check that your nozzle diameter is set to 0.4 in in Settings > Printer > Manage printers > Machine settings > Extruder 1tab > Nozzle Settings > Nozzle size
                                  @genioluiz7 It looks like the nozzle may be a bit low on the initial layer height, along with some extrusion issues (possibly retraction) and over-extrusion. It looks like there's something going on at the point where it changes from solid layers to infill layers.
                                  0.1mm layers are about as low as you can go, and causes other problems, especially with overhangs and bridging. It might be worth starting with a higher layer height (eg 0.2 or 0.3) to get things working well, before reducing the layer height.
                                      @genioluiz7 That looks okay. I think it's just tuning your Cura profile, and tuning the printer for speed, acceleration, retraction, pressure advance, etc etc... . Follow the Calibration section here https://docs.duet3d.com/en/How_to_guides/Calibration, or Teaching Techs more exhaustive guide here:https://teachingtechyt.github.io/calibration.html#intro
                                      genioluiz7undefined 1 Reply Last reply Reply Quote 1
                                        dc42 administrators @genioluiz7
                                        @genioluiz7 said in Nozzle detach the part - Chiron Duet 2 wifi:
                                        Does it have 2 Z motors? Is there a model number on them? Are they connected to the two Z motor outputs of the Duet 2?
                                        Duet 2 has the two Z motor connectors wired in series. That's generally the best arrangement if the Z motors are similar to the XY motors. However, after Duet 2 was released some printer manufacturers started using low current high inductance Z motors that they intended to be connected in parallel. If your machine has that type of motor, then the series connection will reduce the maximum Z speed that can safely be used.
                                          genioluiz7 @dc42
                                          @dc42 this is the actual configuration:
                                          The 2 calbes connected bottom right.
                                          Following the pictures of the z motor
                                          and of the x motor
                                          They seem the same.
                                          Let me know what you think?
                                            @genioluiz7 if you have a multimeter then you could unplug the X and Z motors from the Duet and measure the resistances of one phase of each.
