    WiFi to LAN/ETH
    • tecnoundefined
      tecno
      I would like to connect my NUC with Debian and WiFi to Mini5 ETH board.
      How is this done the easiest way to get my Mini5 on same network 192.168.1 etc ?
        Do you mean a direct ethernet connection between the PC and the Duet? Manually configure IP addresses for both.
        This should get you started, though obviously would be different for Debian. https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking#wired-direct-connection
        If you wanted to reach the Duet from WIFI you would need to look into bridging the wifi and ethernet connections.
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • terabyteundefined
          terabyte
          Use a wifi router is probably the easiest way. Connect nuc to wifi connect Duet to Eth.
          • tecnoundefined
            tecno @terabyte
            @terabyte
            Yes that is the way I run before I moved the printer, want to avoid looooooooooong cable.
            terabyteundefined 1 Reply Last reply Reply Quote 0
            • tecnoundefined
              tecno @Phaedrux
              @Phaedrux
              Bridging is a PITA
              • terabyteundefined
                terabyte @tecno
                @tecno get an access point or a second router to act as an access point which will connect the Duet to WiFi.
