    Input Shaping Plugin Issue
    453
    • rmark1undefined
      rmark1
      I am having issues with the Input Shaping Plugin. It keeps telling me that my axis are not homed, yet they are.
      I am using:
      Board: Duet 2 Ethernet (2Ethernet)
      Board: Duex5
      Tool: Duet3D Accelerometer
      DWC: 3.4.6
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.6 (2023-07-21)
      Plugin: InputShaping-3.4.1-b1
      The ACC. is being recognised, but I cannot get past this constant request to home the axis. I have looked everywhere I can think of to make sure I have correctly setup the plugin and the Acc., but no joy.
      Anyone able to help??
      Many thanks,
      Richard.
      Input_Shaping.g
      zaptaundefined 1 Reply Last reply Reply Quote 0
      • zaptaundefined
        zapta @rmark1
        @rmark1 did you home all axis including z?
        rmark1undefined 1 Reply Last reply Reply Quote 0
        • rmark1undefined
          rmark1 @zapta
          Hi @zapta
          Yup, I even made sure all were at zero as well. If I click on the "Home All" button in the window they are all homed and the window remains with the same "Machine not homed" message. It really beats me as to what is wrong, unless the plugin is not working properly.
          Cheers,
          Richard.
          • rmark1undefined
            rmark1
            Just found the 3.4.6 version of the plugin, uninstalled old version and installed new one - no difference, sigh!
            Richard.
            • chrishammundefined
              chrishamm administrators @rmark1
              @rmark1 Please share your config.g.
              Duet software engineer
              • rmark1undefined
                rmark1 @chrishamm
                @chrishamm
                I have started to split it out into more manageable chunks so I have uploaded the various bits. I have previously uploaded the file I use to enable the accelerometer (input_shaping.g) but have included it below..
                Thanks,
                Richard
                config.g
                config-axes.g
                Input_Shaping.g
                tasundefined 1 Reply Last reply Reply Quote 0
                • tasundefined
                  tas @rmark1
                  @rmark1 You have created your accelerometer in input_shaping.g but you require one more step.
                  You need a second call to M955 so set the orientation of the sensor, sample rate and resolution.
                  For example:
                  M955 P0 C"spi.cs2+spi.cs1"
                  M955 P0 I25 S5000 R10 ; S5000 is 5000Hz sample rate. R10 is 10 bit resolution.
                  That may be your problem.
                  • rmark1undefined
                    rmark1 @tas
                    @tas
                    Ah, I thought that I only needed to leave it at the defaults. I will give it a try later today.
                    Many thanks,
                    Richard.
                      @rmark1 I guess the UV axes are not visible and not homed. That may be the culprit. I'll work out a fix.
                      • rmark1undefined
                        rmark1 @chrishamm
                        @chrishamm
                        Sorry, been busy of late, not been able to test anything yet.
                        Did you manage to work out a fix?
                        Thanks,
                        Richard.
                          @rmark1 Sorry, it's been a while before I could get back to this. I just released Input Shaping plugin v3.4.7 (to be used with DWC 3.4.X) which should fix the problem you faced.
