Switch Shorts on 1LC Toolboard
I have a strange issue. I run an IDEX printer, and on my 2nd print head i have a Y feeder to accept 2 filaments. I manage which filament is loaded with a simple 5V switch connected to IO0 on toolboard 21 (1LC).
This setup has been working for months. I took a 1 month break from printing and now when i go to use this print head the switch does not respond. When clicking the switch the toolboard reboots, so it seems the switch shorts the pin with each button press. Perhaps i changed something and dont remember, but to my knowledge everything should be in a working state.
Any advice how to troubleshoot this? also i have multiple spare switches to use and when i swap one in they all short the board, so unlikely to be faulty switch.
below are my settings:
config.g (line 205 is the switch in question)
config(1).gConsole Outputs
10/3/2023, 7:10:47 AM Warning: Board 21 does not have input handle 10c0 Error: bad model parameters Accelerometer 20:0 type LIS3DH with orientation 14 samples at 1344Hz with 10-bit resolution Warning: Board 21 does not have input handle 2000 Warning: the height map was loaded when the current Z=0 datum was not determined by probing. This may result in a height offset. Warning: Macro file config-override.g not found Error: in file macro line 232 column 20: meta command: variable 'daemonLoop' already exists 10/3/2023, 7:10:45 AM M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled 10/3/2023, 7:05:38 AM M122 B21 Diagnostics for board 21: Duet TOOL1LC rev 1.1 or later firmware version 3.4.2 (2022-09-13 15:06:56) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) All averaging filters OK Never used RAM 2864, free system stack 88 words Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.1%,115) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,3.0%,57) MAIN(running,92.0%,441) IDLE(ready,0.0%,26) AIN(delaying,4.9%,142), total 100.0% Last reset 00:03:04 ago, cause: power up Last software reset data not available Driver 0: pos 0, 80.0 steps/mm,standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 9545, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter -3/6, peak Rx sync delay 189, resyncs 0/0, no step interrupt scheduled VIN voltage: min 24.3, current 24.3, max 24.3 MCU temperature: min 34.8C, current 34.9C, max 36.0C Last sensors broadcast 0x00000000 found 0 39 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 182, send timeouts 0, received 331, lost 0, free buffers 37, min 37, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 0, other errors 0 10/3/2023, 7:05:32 AM M122 B20 Diagnostics for board 20: Duet TOOL1LC rev 1.1 or later firmware version 3.4.2 (2022-09-13 15:06:56) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) All averaging filters OK Never used RAM 2272, free system stack 31 words Tasks: Move(notifyWait,15.9%,99) HEAT(notifyWait,80.7%,75) CanAsync(notifyWait,0.0%,59) CanRecv(notifyWait,8.5%,74) CanClock(notifyWait,3.3%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,521.5%,57) MAIN(running,343.3%,349) IDLE(ready,0.0%,26) AIN(delaying,277.9%,142), total 1251.2% Last reset 47:59:53 ago, cause: software Last software reset data not available Driver 0: pos 7001169, 690.0 steps/mm,standstill, SG min 0, read errors 11, write errors 1, ifcnt 71, reads 14565, writes 25, timeouts 12, DMA errors 0, CC errors 0, failedOp 0x6a, steps req 13174689 done 13174689 Moves scheduled 300963, completed 300963, in progress 0, hiccups 0, step errors 0, maxPrep 905, maxOverdue 4, maxInc 1, mcErrs 0, gcmErrs 0 Peak sync jitter -5/14, peak Rx sync delay 228, resyncs 0/0, no step interrupt scheduled VIN voltage: min 23.4, current 24.1, max 24.2 MCU temperature: min 30.5C, current 31.1C, max 54.2C Last sensors broadcast 0x00000312 found 4 136 ticks ago, 0 ordering errs, loop time 1 CAN messages queued 3456488, send timeouts 0, received 2890902, lost 0, free buffers 37, min 35, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 1166, adv 35486/74643 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 3, other errors 0 10/3/2023, 7:05:02 AM M122 B1 Diagnostics for board 1: Duet EXP3HC rev 1.02 or later firmware version 3.4.2 (2022-09-13 15:05:23) Bootloader ID: SAME5x bootloader version 2.4 (2021-12-10) All averaging filters OK Never used RAM 158256, free system stack 178 words Tasks: Move(notifyWait,0.1%,160) HEAT(notifyWait,4.9%,88) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,2.8%,80) CanClock(notifyWait,1.4%,71) TMC(notifyWait,169.8%,99) MAIN(running,272.4%,407) IDLE(ready,0.0%,40) AIN(delaying,243.9%,263), total 695.3% Last reset 47:59:20 ago, cause: software Last software reset data not available Driver 0: pos 0, 690.0 steps/mm,standstill, SG min 0, mspos 8, reads 7758, writes 17 timeouts 0, steps req 0 done 0 Driver 1: pos 0, 690.0 steps/mm,standstill, SG min 0, mspos 8, reads 7759, writes 17 timeouts 0, steps req 0 done 0 Driver 2: pos 0, 80.0 steps/mm,standstill, SG min 0, mspos 8, reads 7765, writes 12 timeouts 0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter -10/13, peak Rx sync delay 183, resyncs 0/0, no step interrupt scheduled VIN voltage: min 23.6, current 24.2, max 24.3 V12 voltage: min 12.3, current 12.3, max 12.3 MCU temperature: min 29.2C, current 30.3C, max 38.2C Last sensors broadcast 0x00003000 found 2 62 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 2764197, send timeouts 0, received 2589022, lost 0, free buffers 37, min 37, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 10/3/2023, 7:04:56 AM M122 B0 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.4.2 (2022-09-13 15:14:33) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: J6RFD-NR6KL-K65J0-409NN-LK02Z-7M5YU Used output buffers: 1 of 40 (40 max) === RTOS === Static ram: 103684 Dynamic ram: 115484 of which 28 recycled Never used RAM 18844, free system stack 98 words Tasks: NETWORK(ready,286.2%,185) HEAT(notifyWait,11.4%,336) Move(notifyWait,28.1%,256) CanReceiv(notifyWait,18.0%,772) CanSender(notifyWait,0.8%,325) CanClock(delaying,1.4%,339) TMC(notifyWait,221.4%,72) MAIN(running,583.9%,417) IDLE(ready,588.7%,30) AIN(delaying,157.7%,263), total 1897.7% Owned mutexes: HTTP(MAIN) === Platform === Last reset 47:59:14 ago, cause: software Last software reset at 2023-10-01 07:05, reason: User, GCodes spinning, available RAM 19684, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 172754287, completed 172754287, timed out 0, errs 0 Step timer max interval 1488 MCU temperature: min 41.9, current 43.0, max 51.1 Supply voltage: min 23.2, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/228/196, gc cycles 224663 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 85, reads 41730, writes 33, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 85, reads 41729, writes 33, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 85, reads 41729, writes 33, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 77, reads 41732, writes 29, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6c Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 95, reads 41727, writes 35, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x01 Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 97, reads 41727, writes 35, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 97, reads 41726, writes 35, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x71 Date/time: 2023-10-03 07:04:56 Cache data hit count 4294967295 Slowest loop: 387.01ms; fastest: 0.07ms === Storage === Free file entries: 9 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 37.2ms, write time 33.2ms, max retries 0 === Move === DMs created 83, segments created 34, maxWait 66015530ms, bed compensation in use: mesh, comp offset -0.019 === MainDDARing === Scheduled moves 87832, completed 87832, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 17], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.4 Heater 1 is on, I-accum = 0.0 Heater 2 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is ready with "M122 B0" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 1856432, received 8632788, lost 0, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 390, free buffers 18 (min 10), ts 863771/863770/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 293.56ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 = WiFi = Network state is active WiFi module is providing access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 2.1beta3 WiFi MAC address ea:68:e7:e5:63:f4 WiFi Vcc 3.39, reset reason Power up WiFi flash size 2097152, free heap 40160 WiFi IP address 192.168.1.10 Connected clients 1 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0 -
@RogerPodacter please show how you have connected the switch to io0 on the tool board.
@dc42 see attached picture. Switch connects to IO0 below the extruder driver port. if i reverse the switch wiring, there is no response from clicking. no shorts, but not registering in Duet (object model, sensors, gpIn, sensor 0)
@RogerPodacter why do you have 3 wires connected? you should only have 2
@jay_s_uk i dont think that was intentional to use 3 wires. i must have set it up in the beginning and it worked ever since. i just need normally open so i'll have to remove one wire figure out which one.
@RogerPodacter normally closed is usually the preferred option. reduces noise etc
@jay_s_uk is there a way to diagnose if the IO0 port is damaged in some way?
@RogerPodacter i would redo your wiring and go from there
@jay_s_uk thanks, i removed the 3rd wire and checked each wire re-mapping them. the switch is now working normally. i have no idea what happened or how i've been running for months and why it changed. my endstops are all connected with the 3 wires interestingly.
all is good now. thanks all.
