    Giop Pin Raspberry Pi
    • Zsevenundefined
      Zseven
      Hello , is it possible to control a giop pin of the raspberry via Duet ? I can't find anything in the documentation.
      • oliofundefined
        oliof @Zseven
        @Zseven if you use Duet with SBC mode you can use the ExecOnMCode plugin to run arbitrary commands in on the pi which should allow you to enable/disable gpio pins https://plugins.duet3d.com/plugins/DSF_ExecOnMcode_Plugin.html
