    5bar scara Problem configuring z probe using fsr switch
    4.7k
    • gnmrc_undefined
      gnmrc_ @fcwilt
      @fcwilt
      So I’m using RRF3.
      I’m going to re-test it but when I use the S2 command it gives me a warning message saying obsolete command, but still moves as the old s2 command so ignoring homing not completed.
      Gianmarco
      • fcwiltundefined
        fcwilt @gnmrc_
        @gnmrc_ said in Problem configuring z probe using fsr switch:
        @fcwilt
        So I’m using RRF3.
        Gianmarco
        Good to know. Often commands and command options, like S2, are deprecated but not yet gone.
        But it still leaves the question of why the two H1 moves aren't marking the axes as homed.
        I notice that you specify the movement distance as X200 and Y200.
        Be aware that if the endstop swtiches are not activated by the time the distance has been moved the axis is not marked as homed.
        Is 200 long enough to insure the endstop switches are reached?
        Thanks.
        gnmrc_undefined 1 Reply Last reply Reply Quote 0
        • gnmrc_undefined
          gnmrc_ @fcwilt
          @fcwilt Yes endstop are reached with no problems from any arm position.
          Maybe the movement does not work because it needs to home every axis not only x and y for some reason, this would explain the problem with the movement and why the arm works correctly after a partial homing routine(homing only the arm) and then using g92 to home z and after that everything works as expected.
          Let me know what you think.
          Thanks,
          Gianmarco
          • fcwiltundefined
            fcwilt @gnmrc_
            @gnmrc_
            Here are the last three lines from the most recent homing code:
            G90
            G1 X0 Y0 F300 S2 ;move hotend to the center
            G30
            As I recall you said the S2 (which should be H2 according to the docs) is needed.
            But if the previous two G1 H1 commands worked the X and Y axis should be homed and the S2 (H2) should not be needed.
            Now the G30 is the probing command and it is not going to work since it needs the Z axis to be homed.
            And there is nothing in your homing file that tries to home the Z axis.
            To help clarify something try this, please:
            • remove the S2 from the last G1 command
            • remove the G30 command
            • test homing now
            Yes, I know that Z axis will not be homed but I am not worried about that.
            What worries me is the need for the S2.
            Thanks.
            • gnmrc_undefined
              gnmrc_ @fcwilt
              @fcwilt I’ve done as you said, this is the error I get:
              G0/G1: insufficient axes homed
              • gnmrc_undefined
                gnmrc_ @Phaedrux
                @Phaedrux this is what I get from m122:
                m122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later
                Board ID: 0JD0M-9P6M2-NWNS0-7JKDD-3SN6S-1U0BJ
                Used output buffers: 1 of 26 (11 max)
                Static ram: 23836
                Dynamic ram: 74172 of which 68 recycled
                Never used RAM 14004, free system stack 184 words
                Tasks: NETWORK(ready,13.4%,242) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) MAIN(running,84.1%,446) IDLE(ready,2.5%,30), total 100.0%
                Owned mutexes:
                Last reset 00:00:37 ago, cause: power up
                Last software reset at 2023-10-19 21:58, reason: User, GCodes spinning, available RAM 13692, slot 2
                Error status: 0x00
                Step timer max interval 0
                MCU temperature: min 29.8, current 33.2, max 33.4
                Supply voltage: min 12.5, current 12.5, max 12.6, under voltage events: 0, over voltage events: 0, power good: yes
                Events: 0 queued, 0 completed
                Driver 0: standstill, SG min n/a
                Driver 1: standstill, SG min n/a
                Driver 2: standstill, SG min n/a
                Driver 3: standstill, SG min n/a
                Driver 4: standstill, SG min n/a
                Driver 5:
                Driver 6:
                Driver 7:
                Driver 8:
                Driver 9:
                Driver 10:
                Driver 11:
                Date/time: 2023-10-24 17:39:02
                Cache data hit count 1374063136
                Slowest loop: 6.81ms; fastest: 0.18ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 2.4ms, write time 0.0ms, max retries 0
                DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                === MainDDARing ===
                === AuxDDARing ===
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                Daemon is idle in state(s) 0
                Code queue is empty
                === Network ===
                Slowest loop: 15.77ms; fastest: 0.00ms
                Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                HTTP sessions: 1 of 8
                = WiFi =
                Network state is active
                WiFi firmware version 1.23
                WiFi MAC address 98💿ac:20:cb:ca
                WiFi Vcc 3.37, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 25824
                WiFi IP address 192.168.178.109
                WiFi signal strength -54dBm, mode none, reconnections 0, sleep mode modem
                Clock register ffffffff
                • fcwiltundefined
                  fcwilt @gnmrc_
                  I should have asked - exactly what are you/it doing when this message appears - during the homing file execution?
                  Thanks.
                  • gnmrc_undefined
                    gnmrc_ @fcwilt
                    @fcwilt It’does nothing the arm stays in his homed position
                    Gianmarco
                    • fcwiltundefined
                      fcwilt @gnmrc_
                      @fcwilt It’does nothing it stops the movement.
                      When does that happen?
                      When trying to execute the homing file?
                      After that?
                        I assume you're working from this?
                        https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_five_bar_parallel_scara
                        gnmrc_undefined 1 Reply Last reply Reply Quote 1
                        • gnmrc_undefined
                          gnmrc_ @fcwilt
                          @fcwilt, no the arm homes itself, then when it should do the x0 y0 move it stops
                          • gnmrc_undefined
                            gnmrc_ @Phaedrux
                            @Phaedrux yes, I’m using that and I used some other forum post from 2019 I think.
                            • fcwiltundefined
                              fcwilt @gnmrc_
                              Try to be more precise - I am not there seeing what you are seeing - need to help fill in the gaps of my knowledge. Thanks.
                              Are you referring to the move to X=0 Y=0 at the end of the homing file?
                              That is when you get the error message about un-homed axes?
                              Correct?
                              IF that is what is happening then the G1 H1 moves are NOT homing the axes. If they were being homed the move to X=0 Y=0 would work.
                              When a homing move fails, that is it reaches the end of the specified travel (in your case 200) without activating the endstop switch, there is no error message - it just stops moving and the axis is still not homed.
                              So remove the move to X=0 Y=0 (if it is still there), re-boot the machine and click on the HomeAll button in the DWC Dashboard.
                              Once the movement in both axes stops. check if the X and Y home buttons have changed to indicate they are homed.
                              Thanks.
                              • gnmrc_undefined
                                gnmrc_ @fcwilt
                                @fcwilt yes exactly, the machine stops before the x=0 y=0 move in the homing file, but I see from the board’s leds that my endstop gets triggered,I even tested with m119 ,and the arms stops when touching their relative endstops so I do not think this is the case.
                                Also if I only do the G1 H1 X and G1 H1 Y moves in the homing file when it ends my x and y axis results as homed.
                                Gianmarco
                                  What are all the files in your system folder? It's not executing a different file than you expect is it?
                                  • gnmrc_undefined
                                    gnmrc_ @Phaedrux
                                    @Phaedrux no I checked, there is only 1 home5barscara.g
                                    • fcwiltundefined
                                      fcwilt @gnmrc_
                                      @gnmrc_ said in 5bar scara Problem configuring z probe using fsr switch:
                                      Gianmarco
                                      Great, good to know. Thank you.
                                      However I am still at a loss as to why the you cannot so a simple G90 followed by a plain G1 X0 Y0 unless...
                                      OK, let's try this:
                                      • create a HomeX.g file and put just the G91 G1 H1 X200 F300 commands in it
                                      • create a HomeY.g file and put just the G91 G1 H1 Y200 F300 command sin it
                                      • re-boot the machine
                                      • click the Home X button and see if all goes well
                                      • click the Home Y button and see if all goes well
                                      • from the Console of the DWC execute an M208 and report back
                                      Thanks very much.
                                      • gnmrc_undefined
                                        gnmrc_ @fcwilt
                                        @fcwilt Yeah it’s really a frustrating situation….
                                        Ok I will try this solution and report back, but if I remember correctly it’s not possible to do an home X file and an home Y file, because reprap for a 5bar scara configuration during homing procedure will search and execute only a home5barscara.g, if this actually happens, I will create 2 macros home left and home right than put them in the homing file and see what happens.
                                        Thanks for the help,
                                        Gianmarco
                                          This thread is a bit long now. Can you create a summary post of the issue as it is currently and I can pass it along to DC42 to see if he has any suggestions.
                                          gnmrc_undefined 2 Replies Last reply Reply Quote 0
                                          • fcwiltundefined
                                            fcwilt @gnmrc_
                                            Gianmarco
                                            Well if that is the case that you have to have the special file then I have no idea what might be going on.
                                            So just edit that one homing file and after the two G1 H1 commands add a M208.
                                            I want to know what the M208 "thinks" at that point.
                                            Thanks.
