    Very low acceleration during printing
    • MihaiDesignsundefined
      MihaiDesigns
      I'm running a speed test and trying 15K acceleration for infill print moves. X, Y, and E axes all have acceleration limit set to 15K, and print moves are set to 15K acceleration. The interface reports the correct settings. Printing speed is close to 300mm/s. It looks right in the slicer preview (PrusaSlicer). There's no minimum layer time set.
      However, during printing it looks more like under 2000 acceleration. I can't figure out why.
      droftartsundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @MihaiDesigns
        @MihaiDesigns check that acceleration is not limited by any M204 setting (slicers have a bad habit of putting these in, reducing all your accelerations) - send M204 to see how it is currently set.
        MihaiDesignsundefined 2 Replies Last reply Reply Quote 0
        • deckingmanundefined
          deckingman @MihaiDesigns
          @MihaiDesigns It's likely as @droftarts has said but also check jerk - especially extruder jerk. You can set extruder jerk to silly high numbers and it won't have any adverse effect, but low extruder jerk will, especially if you use pressure advance.
            MihaiDesigns @droftarts
            @droftarts yes, I did check M204 and the firmware reports it correctly. X, Y, and E are all set to 15K acceleration.
              @droftarts indeed it was the E jerk. I had it set to 4. I assumed a high E acceleration would take care of it, but it seems not.
              Edit: For clarification, I meant 4mm/s, which is 240mm/min.
                E jerk can be set very high for most extruders. Try 3000 to 6000 mm/min.
                • oliofundefined oliof referenced this topic
