Y Axis Not Homing But Movable - Modix
Hey All,
I have been having a few issues with the Duet2 board on our Modix Big Meter. Firstly wifi issues which we hope to have resolved with a board change where the upload speed slows down until it stops mid upload.
The new issue is where the Y axis (dual extruder setup) wont home but if you allow unhomed moves, then the Y axis can be moved through a touchscreen without issue. This doesnt happen with the U axis. Any thoughts as to what could be going on?
@Simojo check the Y endstop wiring.
@Simojo What do you mean by "won't home"?
It doesn't move or doesn't stop at the endstop?
It would help to share your config.g and homing files as well as the results of M122 and M98 P"config.g"
@Phaedrux Here's the github with the config files and such.
https://github.com/Modix3D/Modix-V3-configuration-and-Macro-files
Have you been in touch with Modix support to help rule out anything electrical or mechanical?
