    Reboots/crashes - RRF ≤3.5.0-rc1
    Beta Firmware
    13
    137
    9.5k
      dc42 administrators @Exerqtor
      @Exerqtor have you ever seen this issue when running DuetWiFiServer 1.27? If you haven't, or you are not sure, please try it.
      Exerqtorundefined 1 Reply Last reply Reply Quote 1
      • Exerqtorundefined
        Exerqtor @dc42
        @dc42 Not sure, but i'm pretty sure it came after moving from 1.27. I'll revert to it now, shouldn't be an issue to run 1.27 with 3.5x on everything else?
        • T3P3Tonyundefined
          T3P3Tony administrators @Exerqtor
          @Exerqtor you can use 1.27 with 3.5x
          www.duet3d.com
          Exerqtorundefined 2 Replies Last reply Reply Quote 1
          • Exerqtorundefined
            Exerqtor @T3P3Tony
            Ok, with that it's now on WiFiServer 1.27, and i'm back to having two tabs with chrome and one Orca Slicer instance (since that seem to be what made it crash most often). #waitinggame
            • Exerqtorundefined
              Exerqtor @T3P3Tony
              @T3P3Tony & @dc42 Just had a crash on WiFiServer 1. 27 as well:
              M122
              RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1++wdb (2023-12-11 09:30:48) running on Duet 3 Mini5plus WiFi (standalone mode)
              Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
              Used output buffers: 1 of 40 (40 max)
              Static ram: 102844
              Dynamic ram: 123224 of which 0 recycled
              Never used RAM 12492, free system stack 182 words
              Tasks: NETWORK(1,ready,23.6%,219) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,69.2%,670) IDLE(0,ready,5.6%,29) AIN(4,delaying,0.8%,264), total 100.0%
              Owned mutexes: WiFi(NETWORK)
              Last reset 00:28:00 ago, cause: software
              Last software reset at 2023-12-13 19:25, reason: AssertionFailed, Gcodes spinning, available RAM 10924, slot 2
              Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
              Stack: 00000919 000af3d0 0002de6f 2002bed4 2002be01 000001af 2002c100 20030c40 2002c118 2001e888 a5a5a5a5 0d0a0d36 0d312e30 00000000 00000000 00000000 20030c4c 00000800 20035970 2002c100 20018678 2002bf9d 20018678 2001e888 0003010f 00000000 00000000
              Error status: 0x04
              Aux0 errors 0,0,0
              MCU revision 3, ADC conversions started 1680921, completed 1680920, timed out 0, errs 0
              MCU temperature: min 35.5, current 36.2, max 39.1
              Supply voltage: min 11.5, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
              Heap OK, handles allocated/used 99/27, heap memory allocated/used/recyclable 2048/404/52, gc cycles 3230
              Events: 0 queued, 0 completed
              Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 97, reads 22904, writes 13, timeouts 0, DMA errors 0, CC errors 0
              Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 95, reads 22904, writes 13, timeouts 0, DMA errors 0, CC errors 0
              Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 200, reads 22904, writes 13, timeouts 0, DMA errors 0, CC errors 0
              Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 203, reads 22903, writes 13, timeouts 0, DMA errors 0, CC errors 0
              Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 197, reads 22904, writes 13, timeouts 0, DMA errors 0, CC errors 0
              Driver 5: not present
              Driver 6: not present
              Date/time: 2023-12-13 19:53:05
              Cache data hit count 2936262464
              Slowest loop: 10.26ms; fastest: 0.13ms
              === Storage ===
              Free file entries: 18
              SD card longest read time 7.6ms, write time 4.6ms, max retries 0
              DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, ebfmin 0.00, ebfmax 0.00
              no step interrupt scheduled
              Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
              === DDARing 0 ===
              === DDARing 1 ===
              Heater 1 is on, I-accum = 0.0
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is doing "G4 P10" in state(s) 0 0, running macro
              Aux2 is idle in state(s) 0
              File2 is idle in state(s) 0
              Queue2 is idle in state(s) 0
              Q0 segments left 0, axes/extruders owned 0x0000803
              Code queue 0 is empty
              Code queue 1 is empty
              === Filament sensors ===
              in 0 notIn 0
              Extruder 0 sensor: no filament
              === CAN ===
              Messages queued 15138, received 34498, lost 0, errs 0, boc 0
              Longest wait 3ms for reply type 6053, peak Tx sync delay 265, free buffers 26 (min 25), ts 8405/8404/0
              Tx timeouts 0,0,0,0,0,0
              === Network ===
              Slowest loop: 13.65ms; fastest: 0.00ms
              Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              HTTP sessions: 4 of 8
              === WiFi ===
              Interface state: active
              Firmware version 1.27
              MAC address c4:5b:be:ce:91:93
              Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 25464
              WiFi IP address 192.168.10.x
              Signal strength -55dBm, channel 0, mode 802.11n, reconnections 0
              Clock register 00002002
              • NeoDueundefined
                NeoDue @Exerqtor
                @Exerqtor thanks! Let me add my observations in detail, maybe they do help someone here - I honestly don't know what happens in detail when the browser is open on a "sleeping" computer:
                1. Desktop PC running MX Linux or Linux Mint with Vivaldi open and no kind of powersaving except turning the monitor off active: dwc tabs do not crash, Duet does not crash.
                2. Notebook (in my case an old MacBook Air) running Windows 10 x64 with the same Vivaldi version active, hibernation turned off, but higher sleep modes active: tabs with DWC frequently do not recover if the computer is woken from sleep. Duet crashes occur (on a Duet 3 6HC running RRF 3.5.0 beta 4 or 3.5.0rc1), but not every time the browser tab crashes. Several browser tab crashes seem to increase the risk for the Duet itself crashing however, as far as I remember.
                I still have my old printer here which runs on a Duet 2 Wifi with RRF 3.3 or an early 3.4 version. If it helps anyone, I could try to recreate those crashes in the new board and then check if the old one might be affected as well.
                Exerqtorundefined T3P3Tonyundefined dc42undefined 3 Replies Last reply Reply Quote 0
                • Exerqtorundefined
                  Exerqtor @NeoDue
                  @NeoDue Interested in seeing if you're also able to recreate this on your setup with the same results!
                  Otherwise it's another crash over the night, same test criteria as the last report:
                  M122
                  Used output buffers: 8 of 40 (40 max)
                  Static ram: 102844
                  Dynamic ram: 122040 of which 0 recycled
                  Never used RAM 13676, free system stack 182 words
                  Tasks: NETWORK(2,nWait,410.5%,236) HEAT(3,nWait,0.4%,327) Move(4,nWait,0.0%,356) CanReceiv(6,nWait,0.9%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.1%,350) TMC(4,nWait,12.4%,108) MAIN(1,running,1216.0%,670) IDLE(0,ready,97.1%,29) AIN(4,delaying,14.7%,264), total 1752.3%
                  Owned mutexes:
                  Last reset 01:41:13 ago, cause: software
                  Last software reset at 2023-12-14 04:08, reason: AssertionFailed, Gcodes spinning, available RAM 12492, slot 1
                  Stack: 00000919 000af3d0 0002de6f 2002bed4 2002be01 000001ae 2002c100 20030c58 2002c118 2001e888 a5a5a5a5 a5a5a5a5 0a0d312e 00000000 00000000 00000000 20030c64 00000800 20035988 2002c100 20018678 2002bf9d 20018678 2001e888 0003010f 00000000 00000000
                  Error status: 0x04
                  Aux0 errors 0,0,0
                  MCU revision 3, ADC conversions started 6073286, completed 6073286, timed out 0, errs 0
                  MCU temperature: min 34.7, current 35.3, max 38.4
                  Supply voltage: min 21.7, current 24.0, max 27.4, under voltage events: 0, over voltage events: 0, power good: yes
                  Heap OK, handles allocated/used 99/23, heap memory allocated/used/recyclable 2048/1496/1184, gc cycles 11249
                  Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 135, reads 57475, writes 13, timeouts 0, DMA errors 0, CC errors 0
                  Driver 1: standstill, SG min 208, read errors 0, write errors 1, ifcnt 133, reads 57475, writes 13, timeouts 0, DMA errors 0, CC errors 0
                  Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 233, reads 57475, writes 13, timeouts 0, DMA errors 0, CC errors 0
                  Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 235, reads 57474, writes 13, timeouts 0, DMA errors 0, CC errors 0
                  Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 229, reads 57475, writes 13, timeouts 0, DMA errors 0, CC errors 0
                  Date/time: 2023-12-14 05:49:51
                  Slowest loop: 14.59ms; fastest: 0.13ms
                  === Storage ===
                  SD card longest read time 7.7ms, write time 4.4ms, max retries 0
                  === DDARing 0 ===
                  === DDARing 1 ===
                  Daemon is idle in state(s) 0 0, running macro
                  in 0 notIn 0
                  === CAN ===
                  Messages queued 54669, received 124545, lost 0, errs 1, boc 0
                  Longest wait 2ms for reply type 6031, peak Tx sync delay 271, free buffers 26 (min 25), ts 30367/30366/0
                  === Network ===
                  Slowest loop: 12.60ms; fastest: 0.00ms
                  === WiFi ===
                  Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 22544
                  Signal strength -56dBm, channel 0, mode 802.11n, reconnections 0
                  • T3P3Tonyundefined
                    T3P3Tony administrators @NeoDue
                    @NeoDue thanks for this information. We need the M122 report(s) for when the Duet crashes. The DWC not recovering from sleep modes etc may be related but may also be a different issue so lets leave that aside for now and focus on what happens when RRF crashes.
                    www.duet3d.com
                    NeoDueundefined 1 Reply Last reply Reply Quote 1
                    • NeoDueundefined
                      NeoDue @T3P3Tony
                      @T3P3Tony @Exerqtor okay. Just to be sure: This means I let the Duet crash and get an M122 afterwards. Anything I need to set on the Duet in advance?
                      • T3P3Tonyundefined
                        @NeoDue It does not hurt to grab a M122 before you start but nothing specifically in advance.
                        www.duet3d.com
                        Exerqtorundefined NeoDueundefined 2 Replies Last reply Reply Quote 0
                        • Exerqtorundefined
                          Exerqtor @T3P3Tony
                          Just got back home from work, to another crash on 1.27.
                          Besides crashing (seemingly just as often as the 2.4 betas), DWC loads sooooo damned slow with 1.27!
                          Anywho, another report:
                          M122
                          Used output buffers: 14 of 40 (40 max)
                          Static ram: 102844
                          Dynamic ram: 122016 of which 0 recycled
                          Never used RAM 13700, free system stack 182 words
                          Tasks: NETWORK(2,nWait,23.4%,211) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,69.4%,670) IDLE(0,ready,5.6%,29) AIN(4,delaying,0.8%,264), total 100.0%
                          Last reset 00:18:49 ago, cause: software
                          Last software reset at 2023-12-14 15:39, reason: AssertionFailed, Gcodes spinning, available RAM 13676, slot 1
                          Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00489000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                          Stack: 00000919 000af3d0 0002de6f 2002bed4 2002be01 000001af 2002c168 20031ca0 2002c180 2001e888 a5a5a5a5 0d0a0d36 0d312e30 00000000 00000000 00000000 20031cac 00000800 200359a0 2002c168 20018678 2002bf9d 20018678 2001e888 0003010f 00000000 00000000
                          Error status: 0x04
                          Aux0 errors 0,0,0
                          MCU revision 3, ADC conversions started 1129622, completed 1129621, timed out 0, errs 0
                          MCU temperature: min 34.8, current 35.3, max 38.2
                          Supply voltage: min 21.7, current 24.1, max 27.4, under voltage events: 0, over voltage events: 0, power good: yes
                          Heap OK, handles allocated/used 99/22, heap memory allocated/used/recyclable 2048/1604/1304, gc cycles 2081
                          Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 177, reads 59429, writes 13, timeouts 0, DMA errors 0, CC errors 0
                          Driver 1: standstill, SG min 208, read errors 0, write errors 1, ifcnt 175, reads 59429, writes 13, timeouts 0, DMA errors 0, CC errors 0
                          Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 19, reads 59429, writes 13, timeouts 0, DMA errors 0, CC errors 0
                          Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 21, reads 59428, writes 13, timeouts 0, DMA errors 0, CC errors 0
                          Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 15, reads 59429, writes 13, timeouts 0, DMA errors 0, CC errors 0
                          Date/time: 2023-12-14 15:57:58
                          Cache data hit count 1957951974
                          Slowest loop: 13.50ms; fastest: 0.13ms
                          === Storage ===
                          SD card longest read time 7.8ms, write time 4.0ms, max retries 0
                          === DDARing 0 ===
                          === DDARing 1 ===
                          in 0 notIn 0
                          === CAN ===
                          Messages queued 10177, received 23198, lost 0, errs 1, boc 0
                          Longest wait 2ms for reply type 6031, peak Tx sync delay 261, free buffers 26 (min 25), ts 5649/5648/0
                          === Network ===
                          Slowest loop: 12.58ms; fastest: 0.00ms
                          === WiFi ===
                          Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 25624
                          Signal strength -54dBm, channel 0, mode 802.11n, reconnections 0
                          • timschneiderundefined
                            timschneider
                            I was looking at the code and found your ocmment about the failed assert.
                            // Look at the response
                            #if SAME5x	//TEMP DEBUG
                            	CheckStackValue(9, ra);			//***** This is the check that occasionally fails ******
                            #endif
                            looking backwards from here it will reset the spi and disable the dma channel. There is a comment about the disabling of the dma channel on SAME5x.
                            // Disable a channel. Also clears its status and disables its interrupts.
                            // On the SAME5x it is sometimes impossible to disable a channel. So we now return true if disabling it succeeded, false it it is still enabled.
                            bool DmacManager::DisableChannel(const uint8_t channel) noexcept
                            but the return value is not checked in the function:
                            static inline void spi_rx_dma_disable() noexcept
                            From here I've looked in the datasheet of the chip to check the dma function and found the following:
                            So it is possible that a DMA transfer is already scheduled but not processed and this will block/prevent the gracefull disable from taking place.
                            • Exerqtorundefined
                              Exerqtor @timschneider
                              @timschneider said in Reboots/crashes - RRF 3.5.0-rc1:
                              #endif
                              Woah, great catch! Hope you're on to something there! 😁😁
                              And some more data points:
                              M122
                              Static ram: 102844
                              Never used RAM 13700, free system stack 186 words
                              Tasks: NETWORK(1,ready,23.2%,217) HEAT(3,nWait,0.0%,335) Move(4,nWait,0.0%,344) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,delaying,0.7%,108) MAIN(1,running,69.6%,670) IDLE(0,ready,5.5%,29) AIN(4,delaying,0.8%,264), total 100.0%
                              Owned mutexes:
                              Last reset 00:25:42 ago, cause: software
                              Last software reset at 2023-12-14 20:16, reason: AssertionFailed, Expansion spinning, available RAM 13676, slot 2
                              Software reset code 0x4132 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                              Stack: 00000919 000af3d0 0002de6f 2002bed4 2002be01 000001af 2002c100 20031458 2002c118 2001e888 a5a5a5a5 a5a5a5a5 0d312e30 00000000 00000000 00000000 20031464 00000800 20035970 2002c100 20018678 2002bf9d 20018678 2001e888 0003010f 00000000 00000000
                              Error status: 0x04
                              Aux0 errors 0,0,0
                              MCU revision 3, ADC conversions started 1542150, completed 1542150, timed out 0, errs 0
                              MCU temperature: min 35.3, current 35.9, max 38.6
                              Supply voltage: min 21.9, current 24.1, max 27.2, under voltage events: 0, over voltage events: 0, power good: yes
                              Heap OK, handles allocated/used 99/23, heap memory allocated/used/recyclable 2048/2048/1736, gc cycles 2851
                              Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 191, reads 15599, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Driver 1: standstill, SG min 208, read errors 0, write errors 1, ifcnt 189, reads 15599, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 33, reads 15598, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 35, reads 15598, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 29, reads 15599, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Date/time: 2023-12-14 20:42:33
                              Cache data hit count 2670623150
                              Slowest loop: 11.30ms; fastest: 0.13ms
                              === Storage ===
                              SD card longest read time 8.4ms, write time 3.6ms, max retries 0
                              === DDARing 0 ===
                              === DDARing 1 ===
                              Heater 0 is on, I-accum = 0.0
                              in 0 notIn 0
                              === CAN ===
                              Messages queued 13889, received 31654, lost 0, errs 1, boc 0
                              Longest wait 2ms for reply type 6031, peak Tx sync delay 300, free buffers 26 (min 25), ts 7711/7710/0
                              === Network ===
                              Slowest loop: 13.57ms; fastest: 0.00ms
                              === WiFi ===
                              Signal strength -53dBm, channel 0, mode 802.11n, reconnections 0
                              • NeoDueundefined
                                NeoDue @T3P3Tony
                                @T3P3Tony thanks! Test is running now. One thing I found due to the browser updating itself soon after start: when the browser was closed for update with Duet tabs open, there is a brief "incomplete transfer" message on the PanelDue - and then the Duet resets the wifi connection (3.5.0rc1 with wifi module firmware 2.1b6 - at least reconnection seems reliable now with that firmware version). After that, one of the Duet tabs was dead. The only thing that differed in the log was the amount of reconnections.
                                I will ignore that for now as you suggested and wait for a crash to happen. The printer is set to write an m122 log into a file afer every reboot - let's see what I find tomorrow.
                                • Exerqtorundefined
                                  Exerqtor @NeoDue
                                  @NeoDue
                                  Looking forrward to seeing how this turns out for you, and if we have the same root cause for the crashes!
                                  Other than that i'm moving over to WiFiServer 2.1b4 again, 1.27 is pretty much useless at this point. It flip out on reboot/crash and won't connect to the LAN with the only means i've found to connect it when that happens is to power toggle the printer til it manages to connect. And once it's finally able to connect, connecting to the printer/DWC is a total shitstorm, 90% of the times it just yields a white/blank screen. And once you're finally able to get a connection it's soooooo slow.
                                  Here is the last crash report from 1.27 and a snipet from the debug log so you can see how it behaves when not being able to connect to the LAN (attached as a mega.nz file since it's a shit ton of data).
                                  M122
                                  Static ram: 102844
                                  Dynamic ram: 122100 of which 0 recycled
                                  Never used RAM 13616, free system stack 186 words
                                  Tasks: NETWORK(1,ready,23.6%,203) HEAT(3,nWait,0.0%,354) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,341) TMC(4,nWait,0.7%,114) MAIN(1,running,69.1%,670) IDLE(0,ready,5.7%,29) AIN(4,delaying,0.8%,264), total 100.0%
                                  Last reset 00:07:20 ago, cause: power up
                                  Last software reset at 2023-12-14 23:02, reason: AssertionFailed, none spinning, available RAM 13700, slot 0
                                  Software reset code 0x4133 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                                  Stack: 00000919 000af3d0 0002de6f 2002bed4 2002be01 000001af 2002c100 20031488 2002c118 2001e888 a5a5a5a5 a5a5a5a5 0d312e30 00000000 00000000 00000000 20031494 00000800 200359a0 2002c100 20018678 2002bf9d 20018678 2001e888 0003010f 00000000 00000000
                                  Error status: 0x04
                                  Aux0 errors 0,0,0
                                  MCU revision 3, ADC conversions started 440375, completed 440375, timed out 0, errs 0
                                  MCU temperature: min 34.0, current 35.3, max 37.1
                                  Supply voltage: min 0.9, current 24.0, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                  Heap OK, handles allocated/used 99/23, heap memory allocated/used/recyclable 2048/1516/1204, gc cycles 801
                                  Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 23148, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 23148, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 23148, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 23147, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 23148, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Date/time: 2023-12-15 07:56:22
                                  Cache data hit count 764831191
                                  Slowest loop: 10.98ms; fastest: 0.13ms
                                  === Storage ===
                                  SD card longest read time 7.8ms, write time 4.4ms, max retries 0
                                  === DDARing 0 ===
                                  === DDARing 1 ===
                                  in 0 notIn 0
                                  === CAN ===
                                  Messages queued 3974, received 9009, lost 0, errs 1638, boc 0
                                  Longest wait 2ms for reply type 6053, peak Tx sync delay 11121, free buffers 26 (min 25), ts 2202/2200/0
                                  Tx timeouts 0,0,1,0,0,0 last cancelled message type 30 dest 127
                                  === Network ===
                                  Slowest loop: 14.24ms; fastest: 0.00ms
                                  HTTP sessions: 3 of 8
                                  === WiFi ===
                                  Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 25536
                                  The debug log file.
                                  NeoDueundefined 1 Reply Last reply Reply Quote 0
                                  • NeoDueundefined
                                    NeoDue @Exerqtor
                                    @Exerqtor so far no crashes here. They happened less often than they seemed to do at your place, so I will leave the test running.
                                    I would however suggest you try to switch to Wifi firmware 2.1b6 instead of b4 - apart from debugging my config and macro files, that was the only thing I did with my printer since RC1 came out, and at least for me, that one solved some issues (albeit seemingly unrelated ones, but who knows...)
                                    Exerqtorundefined 1 Reply Last reply Reply Quote 0
                                    • Exerqtorundefined
                                      Exerqtor @NeoDue
                                      @NeoDue said in Reboots/crashes - RRF 3.5.0-rc1:
                                      That's good to hear, on your behalf i mean 😄
                                      Oh is there a 2.1b6? And where is that bugger hiding out?
                                      Otherwise it's been two crashes while on 2.1b4, and here is a report:
                                      M122
                                      Static ram: 102844
                                      Never used RAM 13700, free system stack 180 words
                                      Tasks: NETWORK(1,ready,57.1%,228) HEAT(3,nWait,0.1%,335) Move(4,nWait,0.0%,344) CanReceiv(6,nWait,0.1%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,1.8%,108) MAIN(1,running,25.2%,670) IDLE(0,ready,13.5%,29) AIN(4,delaying,2.1%,264), total 100.0%
                                      Last reset 02:37:51 ago, cause: software
                                      Last software reset at 2023-12-15 11:37, reason: AssertionFailed, none spinning, available RAM 12492, slot 2
                                      Stack: 00000919 000af3d0 0002de6f 2002bed4 2002be01 000001b0 2002c100 20031c88 2002c118 2001e888 a5a5a5a5 a5a5a5a5 312e303d 00000000 00000000 00000000 20031c94 00000800 20035988 2002c100 20018678 2002bf9d 20018678 2001e888 0003010f 00000000 00000000
                                      Error status: 0x04
                                      Aux0 errors 0,0,0
                                      MCU revision 3, ADC conversions started 9471453, completed 9471453, timed out 0, errs 0
                                      MCU temperature: min 34.7, current 35.3, max 37.8
                                      Supply voltage: min 22.5, current 24.1, max 26.5, under voltage events: 0, over voltage events: 0, power good: yes
                                      Heap OK, handles allocated/used 99/22, heap memory allocated/used/recyclable 2048/1376/1076, gc cycles 17933
                                      Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 58, reads 39703, writes 13, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x72
                                      Driver 1: standstill, SG min 16, read errors 0, write errors 1, ifcnt 58, reads 39704, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 46, reads 39704, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 47, reads 39703, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 46, reads 39704, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                      Date/time: 2023-12-15 14:15:14
                                      Slowest loop: 13.44ms; fastest: 0.13ms
                                      === Storage ===
                                      === DDARing 0 ===
                                      === DDARing 1 ===
                                      in 0 notIn 0
                                      === CAN ===
                                      Messages queued 85250, received 194199, lost 0, errs 1, boc 0
                                      Longest wait 2ms for reply type 6053, peak Tx sync delay 273, free buffers 26 (min 25), ts 47356/47355/0
                                      === Network ===
                                      Slowest loop: 7.31ms; fastest: 0.00ms
                                      === WiFi ===
                                      Firmware version 2.1beta4
                                      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42948
                                      Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0
                                      Clock register 00002001
                                        dc42 administrators @NeoDue
                                        Is this when using the optional WiFi module for the 6HC, or using Ethernet? Do you have any M122 reports from the 6HC taken after the Duet has reset?
                                        • NeoDueundefined
                                          NeoDue @dc42
                                          @dc42 That was all with the optional Wifi module active, I used that one from the very start with the 3 6HC.
                                          Sorry, but I did not keep any M122 logs of that since I did not make the connection you and Exerqtor dug out here and simply thought: "random crashs... well, still beta - the Duet team will surely work an that already - and until you can find some trigger, there is no use in reporting anything".
                                          @Exerqtor beta 6 is in the corresponding Github archive from the Duet team: https://github.com/Duet3D/WiFiSocketServerRTOS/releases
                                          Exerqtorundefined dc42undefined 2 Replies Last reply Reply Quote 1
                                          • Exerqtorundefined
                                            Exerqtor @NeoDue
                                            Well there you go, thx! Installed it now, so lets see if that makes an difference 🤷‍♂️
                                            And one last "M122" from 2.1b4:
                                            M122
                                            15.12.2023, 16:57:34	=== Diagnostics ===
                                            Static ram: 102844
                                            Never used RAM 13700, free system stack 184 words
                                            Tasks: NETWORK(1,ready,24.6%,227) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,67.6%,670) IDLE(0,ready,6.1%,29) AIN(4,delaying,0.8%,264), total 100.0%
                                            Owned mutexes:
                                            Last reset 00:24:30 ago, cause: software
                                            Last software reset at 2023-12-15 16:33, reason: HardFault bfarValid precise, Platform spinning, available RAM 13676, slot 0
                                            Software reset code 0x4060 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x312e303d SP 0x20011f60 Task NETW Freestk 472 ok
                                            Stack: 312e303d 20032cad 00000047 312e303c 20032e6c 0002dd7f 00004434 210f0000 0002dd27 2002bed4 2002be01 000001c0 2002c138 20031c70 2002c150 2001e888 a5a5a5a5 a5a5a5a5 0002ff75 00000000 00000000 00000000 312e303d 00000800 20034fa0 2002c138 20018678
                                            Error status: 0x04
                                            Aux0 errors 0,0,0
                                            MCU revision 3, ADC conversions started 1470513, completed 1470512, timed out 0, errs 0
                                            MCU temperature: min 35.9, current 36.2, max 36.3
                                            Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                            Heap OK, handles allocated/used 99/23, heap memory allocated/used/recyclable 2048/1496/1184, gc cycles 2757
                                            Driver 0: standstill, SG min 16, read errors 0, write errors 0, ifcnt 72, reads 314, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 1: standstill, SG min 16, read errors 0, write errors 0, ifcnt 72, reads 315, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 60, reads 315, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 61, reads 315, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 60, reads 314, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                            Date/time: 2023-12-15 16:57:46
                                            Cache data hit count 2535039282
                                            Slowest loop: 6.44ms; fastest: 0.15ms
                                            === Storage ===
                                            SD card longest read time 4.0ms, write time 1.0ms, max retries 0
                                            === DDARing 0 ===
                                            === DDARing 1 ===
                                            in 0 notIn 0
                                            === CAN ===
                                            Messages queued 54, received 123, lost 0, errs 0, boc 0
                                            Longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 26 (min 26), ts 30/30/0
                                            === Network ===
                                            Slowest loop: 20.27ms; fastest: 0.07ms
                                            === WiFi ===
                                            Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 41348
                                            WiFi IP address 192.168.10.50
                                            Signal strength -46dBm, channel 6, mode 802.11n, reconnections 0
                                            15.12.2023, 16:57:33	M122
                                            Static ram: 102844
                                            Owned mutexes:
                                            Error status: 0x04
                                            Aux0 errors 0,0,0
                                            === Storage ===
                                            === DDARing 0 ===
                                            === DDARing 1 ===
                                            in 0 notIn 0
                                            === CAN ===
                                            === Network ===
                                            === WiFi ===
