    Macro file unable to call during print
    513
    • SANJRundefined
      SANJR
      Greetings,
      I have created a macro file name 5_TORCH ON.g & 6_TORCH OFF.g. I tried to call these macro files using the M98 G Code in my print job file, but the macro is not responding to the M98 command however when tried with the M42 P3 S0 & M42 P3 S1, the torch responds. Print file is as follows,
      G1 X305 Y403 Z125
      M98 P"macros/5_WELD TORCH ON.g"
      G1 X350.0 F480
      M98 P"macros/6_WELD TORCH OFF.g"
      G1 Z135
      What could be the reason for this behaviour? Is there any error in the code above or additional commands to be input? Plz let me know
        jay_s_uk @SANJR
        @SANJR try adding 0:/ to the macro name. e.g. M98 P"0:/macros/5_WELD TORCH ON.g"
        SANJRundefined 1 Reply Last reply Reply Quote 0
        • SANJRundefined
          SANJR @jay_s_uk
          @jay_s_uk
          I tried applying the M98 P"0:/macros/5_WELD TORCH ON.g" command, but it is not responding. Not sure for this non-responsiveness.
          Can the M98 command be used in the print file?
          jay_s_ukundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @SANJR
            @SANJR yes, M98 can be used in a print file.
            if you're going to use that mid move it may be better to use an unused G/M code.
            So as an example on my pen plotted, when i was to lift the pen, i used M5000 and then to drop the pen i use M5001 and these are placed throughout the gcode.
            i then have a file for each one in the sys folder called M5000.g and M5001.g.
            The firmware will automatically run those files whenever M5000 or M5001 are used, whether its part of a gcode file or from the console
            Then, you just format/post process your gcode accordingly
            • deckingmanundefined
              deckingman @SANJR
              @SANJR Does the macro run "stand alone" if you just send the M98 from the console? It might be an idea if you post the macro code here.
              • SANJRundefined
                SANJR @deckingman
                @deckingman
                Yes the macro runs in standalone. The G-Code for the macro file is as follows,
                Weld Torch ON.g file
                ; Weld Torch ON
                M42 P3 S1
                Weld Torch OFF.g file
                ; Weld Torch OFF
                M42 P3 S0
                  droftarts administrators @SANJR
                  @SANJR Note that:
                  Case sensitivity
                  The original NIST GCode standard requires GCode interpreters to be case-insensitive, except for characters in comments. However, not all 3D printer firmwares conform to this and some recognise uppercase command letters and parameters only.
                  RepRapFirmware version 1.19 and later is case-insensitive, except for characters within quoted strings. RepRapFirmware version 1.18 and earlier accept only uppercase letters for command and parameter letters.
                  https://docs.duet3d.com/en/User_manual/Reference/Gcodes#case-sensitivity
                  Is the macro "5_WELD TORCH ON.g" or "Weld Torch ON.g"?
                  • SANJRundefined
                    SANJR @droftarts
                    @droftarts
                    The file name is WELD TORCH ON. To appear as a fifth file in the macro folder, i numbered it to be 5_WELD TORCH ON. I have tried it the following ways as of now
                    1. M98 P¨WELD TORCH ON.g¨
                    2. M98 P¨WELD TORCH ON¨
                    3. M98 P¨macros/WELD TORCH ON.g¨
                    4. M98 P¨macros/WELD TORCH ON¨
                    5. M98 P¨0:/macros/WELD TORCH ON.g¨
                    jay_s_ukundefined SANJRundefined droftartsundefined 3 Replies Last reply Reply Quote 0
                      jay_s_uk @SANJR
                      @SANJR you need the 5_ in the M98 call as well then
                      • SANJRundefined
                        SANJR @SANJR
                        @SANJR
                        And also tried one combinations
                        M98 P¨5_macros/WELD TORCH ON.g¨
                          @SANJR Please send M20 S2 P"/macros" and post the response.
                          Edit: It won't be a case-sensitive issue, because FAT32 is not case sensitive! But it is case-preserving.
                          • SANJRundefined
                            SANJR @SANJR
                            @SANJR said in Macro file unable to call during print:
                            @SANJR
                            M98 P¨5_WELD TORCH ON.g¨
                            • SANJRundefined
                              SANJR @droftarts
                              @droftarts
                              Here is the response from the console
                              M20 S2 P"/macros"
                              "dir": "/macros",
                              "first": 0,
                              "files": [
                              "6_WELD TORCH OFF",
                              "3_MOTOR 1 OFF",
                              "4_MOTOR 2 OFF",
                              "1_MOTOR 1 ON AND SPEED CONTROL",
                              "2_ MOTOR 2 ON AND SPEED CONTROL",
                              "5_WELD TORCH ON"
                              "next": 0,
                              "err": 0
                                jay_s_uk @SANJR
                                @SANJR so torch on is
                                M98 P"0:/macros/5_WELD TORCH ON"
                                SANJRundefined 1 Reply Last reply Reply Quote 1
                                • SANJRundefined
                                  SANJR @jay_s_uk
                                  @jay_s_uk Thanks
                                  The macro files works. It seems the format of M98 command during the print needs to mention the location of the file i.e., in the directory where we placed it. And finally the extension of file .g is not required.
                                  So the syntax to which my machine responds is M98 P"0:/macros/5_WELD TORCH ON" instead of M98 P"5_WELD TORCH ON"
                                  It would be nice if notes are updated in the documentation which would be helpful to other users.
                                  • fcwiltundefined
                                    fcwilt @SANJR
                                    @SANJR
                                    It seems I organize my system code and my "macros" code differently from most.
                                    In my setup the items in the macros folder are only there to provide access, from the DWC interface, to items in the system folder.
                                    If other words items in the macros folder invoke, via M98, items in the system folder but no items in the system folder invoke items in the macros folder.
                                    There are some items in the macros folder that have a line or two of code but nothing that I ever would need to invoke from the system folder.
                                    Just FYI.
