    Combining printhead wires !
    • Simon 4undefined
      Simon 4
      I want to save some wires to the printhead, and to save some time for try and error I asking into the forum.
      My specs are
      Extruder with 5V 3 wire fan
      BL touch
      5015 12V part cooling fan with 4 wires
      and x and y endstop switches
      I already know that I can save one gnd at the bl touch and one for the endstops.
      also I am using the 5 V+ from the BL-touch and the 5v extruder fan
      GND bl touch + GND 4 pin fan + GND Endstops are one wire
      what else can I combine? Is it possible to connect the heater to GND
      I think the 5V fan GND could not be connected to the other ones ?
      • deckingmanundefined
        deckingman @Simon 4
        @Simon-4 If you can live without the tacho signal you could simply run two wires for each fan which will save 3 conductors. If you change the 5V fan to a 12 V fan (or vice versa) you could use a common V+ which would save another conductor. If you can find the money and somewhere to mount it, you could use a tool board which only requires power and data so 4 conductors in total.
        Simon 4undefined 1 Reply Last reply Reply Quote 0
        • Simon 4undefined
          Simon 4 @deckingman
          @deckingman
          CAN-board and changing the setup is not possible.
            deckingman @Simon 4
            @Simon-4 Now that you've edited you first post, I'm not sure how Duet controls 4 wire fans but I suspect it's the same as heaters and the like whereby the Mosfets switch the gnd rather than the positive. In which case, combining the fan or heater gnd with other gnds isn't going to work.
              jay_s_uk @deckingman
              @deckingman 4 wire fans have an always on power connection and rely on a PWM signal on a separate cable for the control
