    1LC - extruder randomly stopping/reversing - ≤3.5.0-rc1
    Beta Firmware
    9
    147
    8.7k
      dc42 administrators @Exerqtor
      @Exerqtor is the reversal random, or at the same point each time in a given print?
      Exerqtorundefined 3 Replies Last reply Reply Quote 0
      • Exerqtorundefined
        Exerqtor @dc42
        @dc42 Seemingly random, definetly not on the same point/layer each time.
        The first time it happened (where i thought it was a clog or something) it happened between layer 59-61 (based on messsuring the height of the failed print), so after making sure there was no clog etc. and restarting the print it began reversing at layer 4-5. And on the third try it started reversing on layer 2.
        • Exerqtorundefined
          Exerqtor @dc42
          @dc42 said in 1LC stepper intermittently running backwards - 3.5.0-r1+:
          I just saw this thread and your reply to it. And it got me to remember that i did some IS tuning and changes between it working and these issues came back. May these be connected to each other?
          The only changes i did was to alter the frequency and try a couple different shapers to see what changes it did to the readings.
          • Exerqtorundefined
            Exerqtor @dc42
            @dc42 So I just grabbed the 3.5.0rc2 binaries and tried them on the machine, and it's still reversing the the print.
            This time I kept a finger on the filament where it enters the reversed bowden while looking at the Z-height and it stopped extruding somewhere along Z 0.65.
            Here is a couple fresh reports grabbed while it's acting up during a print:
            M122
            RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.2 (2023-12-15 13:33:26) running on Duet 3 Mini5plus WiFi (standalone mode)
            Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
            Used output buffers: 3 of 40 (40 max)
            Static ram: 102812
            Dynamic ram: 128208 of which 0 recycled
            Never used RAM 5756, free system stack 120 words
            Tasks: NETWORK(2,nWait,21.9%,181) HEAT(3,nWait,0.0%,328) Move(4,nWait,0.5%,243) CanReceiv(6,nWait,0.1%,776) CanSender(5,nWait,0.0%,329) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,80) MAIN(1,running,71.5%,603) IDLE(0,ready,4.5%,29) AIN(4,delaying,0.8%,264), total 100.0%
            Owned mutexes:
            Last reset 00:36:34 ago, cause: software
            Last software reset at 2023-12-15 17:21, reason: User, Gcodes spinning, available RAM 12348, slot 2
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
            Error status: 0x04
            Aux0 errors 0,0,0
            MCU revision 3, ADC conversions started 2195019, completed 2195017, timed out 0, errs 0
            MCU temperature: min 35.9, current 46.2, max 46.7
            Supply voltage: min 7.5, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
            Heap OK, handles allocated/used 198/28, heap memory allocated/used/recyclable 2048/1524/1120, gc cycles 4001
            Events: 0 queued, 0 completed
            Driver 0: ok, SG min 0, read errors 0, write errors 1, ifcnt 149, reads 49926, writes 32, timeouts 0, DMA errors 0, CC errors 0
            Driver 1: ok, SG min 0, read errors 0, write errors 1, ifcnt 149, reads 49926, writes 32, timeouts 0, DMA errors 0, CC errors 0
            Driver 2: ok, SG min 0, read errors 0, write errors 1, ifcnt 115, reads 49937, writes 21, timeouts 0, DMA errors 0, CC errors 0
            Driver 3: ok, SG min 0, read errors 0, write errors 1, ifcnt 116, reads 49936, writes 21, timeouts 0, DMA errors 0, CC errors 0
            Driver 4: ok, SG min 0, read errors 0, write errors 1, ifcnt 115, reads 49937, writes 21, timeouts 0, DMA errors 0, CC errors 0
            Driver 5: not present
            Driver 6: not present
            Date/time: 2023-12-15 17:57:46
            Cache data hit count 3773989065
            Slowest loop: 224.53ms; fastest: 0.09ms
            === Storage ===
            Free file entries: 16
            SD card longest read time 11.1ms, write time 4.5ms, max retries 0
            DMs created 83, segments created 41, maxWait 1602827ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00
            next step interrupt due in 795 ticks, enabled
            Moves shaped first try 499, on retry 404, too short 194, wrong shape 4852, maybepossible 141
            === DDARing 0 ===
            Scheduled moves 8101, completed 8061, hiccups 0, stepErrors 0, LaErrors 10, Underruns [0, 0, 0], CDDA state 3
            === DDARing 1 ===
            Heater 0 is on, I-accum = 0.4
            Heater 1 is on, I-accum = 0.0
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is doing "G1 X170.827 Y153.319 E.00731" in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is idle in state(s) 0 0, running macro
            Aux2 is idle in state(s) 0
            File2 is idle in state(s) 0, sync state 1
            Queue2 is idle in state(s) 0
            Q0 segments left 0, axes/extruders owned 0x0000807
            Code queue 0 is empty
            Code queue 1 is empty
            === Filament sensors ===
            check 0 clear 0
            Extruder 0 sensor: no filament
            === CAN ===
            Messages queued 26867, received 45197, lost 0, errs 1, boc 0
            Longest wait 2ms for reply type 6031, peak Tx sync delay 403, free buffers 26 (min 25), ts 10975/10974/0
            Tx timeouts 0,0,0,0,0,0
            === Network ===
            Slowest loop: 89.37ms; fastest: 0.00ms
            Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
            HTTP sessions: 3 of 8
            === WiFi ===
            Interface state: active
            Firmware version 2.1beta6
            MAC address c4:5b:be:ce:91:93
            Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 41512
            WiFi IP address 192.168.10.x
            Signal strength -50dBm, channel 6, mode 802.11n, reconnections 0
            Clock register 00002001
            M122 B121
            Diagnostics for board 121:
            Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.2 (2023-12-15 13:41:02)
            Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10)
            All averaging filters OK
            Never used RAM 2708, free system stack 91 words
            Tasks: Move(3,nWait,0.1%,73) HEAT(2,nWait,0.4%,97) CanAsync(5,nWait,0.0%,55) CanRecv(3,nWait,0.0%,77) CanClock(5,nWait,0.0%,69) ACCEL(3,nWait,0.0%,53) TMC(2,delaying,3.0%,57) MAIN(1,running,91.8%,318) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.7%,114), total 100.0%
            Last reset 00:36:54 ago, cause: software
            Last software reset data not available
            Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 1, ifcnt 97, reads 57835, writes 22, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 440142
            Moves scheduled 3003, completed 3003, in progress 0, hiccups 4, segs 40, step errors 0, maxLate 1 maxPrep 887, maxOverdue 322, maxInc 322, mcErrs 0, gcmErrs 0, ebfmin -1.00 max inf
            Peak sync jitter -2/10, peak Rx sync delay 217, resyncs 0/0, no timer interrupt scheduled
            VIN voltage: min 7.7, current 24.1, max 24.5
            MCU temperature: min 39.1C, current 68.7C, max 68.7C
            Last sensors broadcast 0x00000012 found 2 11 ticks ago, 0 ordering errs, loop time 0
            CAN messages queued 45614, send timeouts 0, received 27424, lost 0, errs 1173, boc 0, free buffers 18, min 18, error reg 110000
            dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 346, adv 35766/74655
            Accelerometer: LIS3DH, status: 00
            Inductive sensor: not found
            I2C bus errors 0, naks 6, contentions 0, other errors 0
            Interrupt 5726621 to 0us, poll 4 to 1409us
            And the sliced file for good measure.
            Exerqtorundefined 1 Reply Last reply Reply Quote 0
            • Exerqtorundefined
              Exerqtor @Exerqtor
              I just adjusted my belt tention and retuned input shaping after moving to 3.5.0-rc2, to see if applying new shaper settings would remedy anything.
              Started a print, and now it stops extruding earlier than ever, now it only does a tiny bit of my purge line before it stops.
              So i thought fuck it and removed the extrusion reset commands from my layer change g-code, sliced the model again and did another try. The exact same behaviour.
              Here is another set of M122 reports from while the problem is happening:
              M122
              Used output buffers: 13 of 40 (40 max)
              Static ram: 102812
              Dynamic ram: 128544 of which 0 recycled
              Never used RAM 5420, free system stack 120 words
              Tasks: NETWORK(1,ready,83.7%,181) HEAT(3,nWait,1.0%,328) Move(4,nWait,0.3%,243) CanReceiv(6,nWait,1.7%,776) CanSender(5,nWait,0.0%,328) CanClock(7,delaying,0.3%,350) TMC(4,delaying,24.0%,74) MAIN(1,running,106.6%,584) IDLE(0,ready,179.1%,29) AIN(4,delaying,27.9%,264), total 424.7%
              Owned mutexes: WiFi(NETWORK)
              Last reset 17:00:25 ago, cause: software
              Error status: 0x04
              Aux0 errors 0,0,0
              MCU revision 3, ADC conversions started 61224767, completed 61224767, timed out 0, errs 0
              MCU temperature: min 34.8, current 46.4, max 46.4
              Supply voltage: min 23.4, current 23.9, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
              Heap OK, handles allocated/used 198/28, heap memory allocated/used/recyclable 2048/612/192, gc cycles 119204
              Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 247, reads 26512, writes 98, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x71
              Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 247, reads 26513, writes 98, timeouts 0, DMA errors 0, CC errors 0
              Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 152, reads 26571, writes 37, timeouts 2, DMA errors 0, CC errors 0, failedOp 0x41
              Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 154, reads 26572, writes 38, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6c
              Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 152, reads 26572, writes 37, timeouts 2, DMA errors 0, CC errors 0, failedOp 0x6f
              Date/time: 2023-12-16 10:21:36
              Slowest loop: 408.12ms; fastest: 0.09ms
              === Storage ===
              SD card longest read time 8.7ms, write time 8.1ms, max retries 0
              DMs created 83, segments created 41, maxWait 53449812ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00
              next step interrupt due in 55 ticks, enabled
              Moves shaped first try 196, on retry 110, too short 86, wrong shape 1517, maybepossible 32
              === DDARing 0 ===
              Scheduled moves 432, completed 422, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 49], CDDA state 3
              === DDARing 1 ===
              File is idle in state(s) 3
              Q0 segments left 1, axes/extruders owned 0x0000807
              check 0 clear 0
              === CAN ===
              Messages queued 533567, received 1211128, lost 0, errs 0, boc 0
              Longest wait 6ms for reply type 6024, peak Tx sync delay 277, free buffers 26 (min 24), ts 295151/295151/0
              === Network ===
              Slowest loop: 211.17ms; fastest: 0.00ms
              HTTP sessions: 1 of 8
              === WiFi ===
              Module reset reason: Power up, Vcc 3.37, flash size 2097152, free heap 41168
              Signal strength -49dBm, channel 6, mode 802.11n, reconnections 0
              M122 B121
              Tasks: Move(3,nWait,0.1%,73) HEAT(2,nWait,11.4%,97) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.4%,77) CanClock(5,nWait,0.6%,69) ACCEL(3,nWait,0.0%,17) TMC(2,delaying,101.1%,57) MAIN(1,running,154.7%,318) IDLE(0,ready,0.0%,27) AIN(2,delaying,159.0%,114), total 427.3%
              Last reset 17:00:30 ago, cause: software
              Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 101, reads 16617, writes 4, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x71, steps req 0 done 91906
              Moves scheduled 3087, completed 3087, in progress 0, hiccups 3, segs 40, step errors 0, maxLate 0 maxPrep 853, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
              Peak sync jitter -3/10, peak Rx sync delay 219, resyncs 0/0, no timer interrupt scheduled
              VIN voltage: min 23.3, current 24.1, max 24.6
              MCU temperature: min 38.6C, current 63.8C, max 69.2C
              Last sensors broadcast 0x00000012 found 2 24 ticks ago, 0 ordering errs, loop time 0
              CAN messages queued 1210805, send timeouts 0, received 533070, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
              dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 334, adv 35725/74654
              I2C bus errors 0, naks 0, contentions 0, other errors 0
              Interrupt 5726621 to 0us, poll 5 to 1436us
              Driver 0: ok
              And here is the relevant config files & sliced job.
              (All these files are grabbed from the printer, so it's 100% the config I'm currently running)
                droftarts administrators @Exerqtor
                @Exerqtor have we already ascertained if the problem goes away when input shaping and/or pressure advance are disabled? What size nozzle are you using?
                Exerqtorundefined 1 Reply Last reply Reply Quote 1
                • Exerqtorundefined
                  Exerqtor @droftarts
                  @droftarts said in 1LC - stepper randomly reversing - ≤3.5.0-r1+:
                  No I haven't tried that out yet, been waiting on feedback as to where/what to start with to be honest.
                  I can try disabling Input Shaping first and see if that yield different results on the same job that I supplied in my last post.
                  I can confirm that it still happens with IS disabled:
                  M593
                  Input shaping is disabled
                  M122
                  Used output buffers: 25 of 40 (40 max)
                  Static ram: 102812
                  Tasks: NETWORK(2,nWait,23.7%,179) HEAT(3,nWait,0.0%,328) Move(4,nWait,2.4%,243) CanReceiv(6,nWait,0.1%,776) CanSender(5,nWait,0.0%,328) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.8%,74) MAIN(1,running,66.8%,584) IDLE(0,ready,5.3%,29) AIN(4,delaying,0.9%,264), total 100.0%
                  Last reset 18:04:31 ago, cause: software
                  Error status: 0x04
                  Aux0 errors 0,0,0
                  MCU revision 3, ADC conversions started 65070749, completed 65070749, timed out 0, errs 0
                  MCU temperature: min 46.0, current 46.4, max 46.7
                  Supply voltage: min 23.8, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                  Heap OK, handles allocated/used 198/28, heap memory allocated/used/recyclable 2048/1836/1416, gc cycles 126614
                  Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 10, reads 1329, writes 0, timeouts 0, DMA errors 0, CC errors 0
                  Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 10, reads 1329, writes 0, timeouts 0, DMA errors 0, CC errors 0
                  Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 160, reads 1329, writes 0, timeouts 0, DMA errors 0, CC errors 0
                  Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 162, reads 1329, writes 0, timeouts 0, DMA errors 0, CC errors 0
                  Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 159, reads 1329, writes 0, timeouts 0, DMA errors 0, CC errors 0
                  Date/time: 2023-12-16 11:25:42
                  Slowest loop: 9.56ms; fastest: 0.11ms
                  === Storage ===
                  SD card longest read time 6.0ms, write time 1.0ms, max retries 0
                  DMs created 83, segments created 41, maxWait 842ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00
                  next step interrupt due in 107 ticks, enabled
                  Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
                  === DDARing 0 ===
                  Scheduled moves 1066, completed 1044, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                  === DDARing 1 ===
                  File is doing "G1 X226.271 Y197.626 E.02799" in state(s) 0
                  Daemon is doing "G4 P10" in state(s) 0 0, running macro
                  check 0 clear 0
                  === CAN ===
                  Messages queued 509, received 517, lost 0, errs 0, boc 0
                  Longest wait 0ms for reply type 0, peak Tx sync delay 9, free buffers 26 (min 25), ts 126/126/0
                  === Network ===
                  Slowest loop: 20.63ms; fastest: 0.06ms
                  === WiFi ===
                  Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42988
                  M122 B121
                  Tasks: Move(3,nWait,0.0%,73) HEAT(2,nWait,0.3%,97) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.0%,77) CanClock(5,nWait,0.0%,69) ACCEL(3,nWait,0.0%,17) TMC(2,delaying,3.0%,57) MAIN(1,running,91.9%,318) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.7%,114), total 100.0%
                  Last reset 18:04:47 ago, cause: software
                  Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 103, reads 28066, writes 2, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 38048
                  Moves scheduled 3098, completed 3098, in progress 0, hiccups 1, segs 40, step errors 0, maxLate 0 maxPrep 334, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
                  Peak sync jitter -2/11, peak Rx sync delay 215, resyncs 0/0, no timer interrupt scheduled
                  VIN voltage: min 23.3, current 24.1, max 24.5
                  MCU temperature: min 38.6C, current 57.8C, max 69.2C
                  Last sensors broadcast 0x00000012 found 2 103 ticks ago, 0 ordering errs, loop time 0
                  CAN messages queued 79268, send timeouts 0, received 35985, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                  dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 323, adv 35708/74652
                  Interrupt 5726621 to 0us, poll 5 to 1432us
                  Driver 0: ok
                  • Exerqtorundefined
                    Exerqtor @Exerqtor
                    @droftarts And the exact same with both Input Shaping and Pressure Advance disabled:
                    M593
                    M572 D0
                    Extruder pressure advance: 0.000
                    M122
                    Static ram: 102812
                    Tasks: NETWORK(2,nWait,22.2%,179) HEAT(3,nWait,0.0%,328) Move(4,nWait,0.5%,243) CanReceiv(6,nWait,0.1%,776) CanSender(5,nWait,0.0%,328) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,74) MAIN(1,running,70.6%,584) IDLE(0,ready,5.0%,29) AIN(4,delaying,0.9%,264), total 100.0%
                    Last reset 18:14:11 ago, cause: software
                    Error status: 0x04
                    Aux0 errors 0,0,0
                    MCU revision 3, ADC conversions started 65650769, completed 65650768, timed out 0, errs 0
                    MCU temperature: min 42.2, current 46.2, max 46.8
                    Supply voltage: min 23.4, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                    Heap OK, handles allocated/used 198/28, heap memory allocated/used/recyclable 2048/716/296, gc cycles 127712
                    Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 29, reads 30499, writes 19, timeouts 0, DMA errors 0, CC errors 0
                    Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 29, reads 30499, writes 19, timeouts 0, DMA errors 0, CC errors 0
                    Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 168, reads 30510, writes 8, timeouts 0, DMA errors 0, CC errors 0
                    Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 169, reads 30512, writes 7, timeouts 0, DMA errors 0, CC errors 0
                    Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 167, reads 30510, writes 8, timeouts 0, DMA errors 0, CC errors 0
                    Date/time: 2023-12-16 11:35:22
                    Slowest loop: 216.18ms; fastest: 0.09ms
                    === Storage ===
                    SD card longest read time 6.6ms, write time 5.2ms, max retries 0
                    DMs created 83, segments created 41, maxWait 322812ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00
                    next step interrupt due in 50 ticks, enabled
                    === DDARing 0 ===
                    Scheduled moves 842, completed 836, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state 3
                    === DDARing 1 ===
                    Heater 0 is on, I-accum = 0.5
                    check 0 clear 0
                    === CAN ===
                    Messages queued 6599, received 12089, lost 0, errs 0, boc 0
                    Longest wait 6ms for reply type 6013, peak Tx sync delay 262, free buffers 26 (min 25), ts 2900/2900/0
                    === Network ===
                    Slowest loop: 209.17ms; fastest: 0.06ms
                    === WiFi ===
                    Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39732
                    Signal strength -48dBm, channel 6, mode 802.11n, reconnections 0
                    M122 B121
                    Tasks: Move(3,nWait,0.0%,73) HEAT(2,nWait,0.4%,97) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.0%,77) CanClock(5,nWait,0.0%,69) ACCEL(3,nWait,0.0%,17) TMC(2,delaying,3.0%,57) MAIN(1,running,91.8%,318) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.7%,114), total 100.0%
                    Last reset 18:14:15 ago, cause: software
                    Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 105, reads 21809, writes 2, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 38048
                    Moves scheduled 3109, completed 3109, in progress 0, hiccups 2, segs 40, step errors 0, maxLate 0 maxPrep 261, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
                    Peak sync jitter -1/10, peak Rx sync delay 213, resyncs 0/0, no timer interrupt scheduled
                    VIN voltage: min 23.4, current 24.1, max 24.5
                    MCU temperature: min 38.6C, current 61.1C, max 69.2C
                    Last sensors broadcast 0x00000012 found 2 168 ticks ago, 0 ordering errs, loop time 0
                    CAN messages queued 11838, send timeouts 0, received 6345, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 324, adv 35827/74649
                    Interrupt 5726621 to 0us, poll 5 to 1488us
                    Driver 0: ok
                    • Exerqtorundefined
                      Exerqtor @Exerqtor
                      I just removed all the "extra stuff "that was put in daemon.g to see if that mad a difference but it still starts reversing. Same if i "disable" daemon.g or run it completely empty.
                      Now it's on the first line of my 3-line purge/prime code each time "no matter" what i do.
                      Is it any apparent issue from the M122 reports i've been posting, or is that just a complete waste of time to post those?
                      Feel like i'm pulling straws out of my ass at this point, but could formating the sd-card and reinstalling all the firmware be worth a try?
                      I mean, i've been installing so many different builds the last 3-4months maybe something got messed up?
                      Or is that just nonsense?
                      • A Former User?
                        A Former User @Exerqtor
                        @Exerqtor If it makes you feel better I figured out the problem I have been having for the last week is the extruder occasionally stopping. Using a Duet 3 mini 5+ with a RRF-36 toolboard. 3.5.0-R1 on the board and 3.5.0.r1+101 on the toolboard.
                        I thought it was cooling related since it is a new Dragonfly BMO hotend and EVA34 setup thanks to a fan failure earlier. But nothing is wrong, the heatbreak is clear, the nozzle is not clogged Went through the wiring too to make sure no momentaries were happening.
                        Not seeing an error and no desire to try it again and waste more expensive carbon fiber PC filament. Plus I am going to be tied up for the next couple weeks, So I'll park that printer and revisit it early next year.
                        I did kill daemon.g to see if it was related since that and the new hotend assembly were the changes recently done and it did not help. Not seeing any crashes but I am running a different setup than you. Win 10 with Cura slicing the files and firefox running DWC. And the 2 reprints also failed. They sure mess up a print when they happen.
                        • Exerqtorundefined
                          Exerqtor @A Former User
                          @KenW
                          Sucks to hear you also have problems, but it really does make me feel better to hear that it's not another "one off" issue, and it's something happening to others as well 😮‍💨
                          I've got alot of projects I hoped to get done by/in the comming holidays, but it's looking increasingly less and less likely 💩
                          It's luckily some bog standard ABS i've had to throw in the fuckit-bucket, but it's still annoying af.
                          • A Former User?
                            @Exerqtor That is the only printer running the beta firmware. It has to run it to use the RRF-36 toolboard. I had noticed your post but was ignoring them since I thought it was filament getting stuck in the heatbreak or possibly carbon fiber jamming the nozzle. I can take down and reassemble the EVA in minutes now with all the practice I have been getting.
                            Since mine is not acting up exactly like yours unless your extruder just stops for a bit then restarts with no error maybe it's another issue.
                            After I get back home in a few weeks I'll play around more with it,. Gave up today on the print I was trying to take with me.
                            • Exerqtorundefined
                              @KenW I also thought i had gotten a clog or something when it started happening again so i get your logic lol. It will be interesting seeing how it plays out when you get some time to look at it again.
                              I just reverted to 3.5.0b4 on the mobo & toolboard to see what happens at least, too be continued.
                              EDIT:
                              After reverting too 3.5.0b4 I was finally able to complete the print without issues.
                              I'm gonna try doing some more prints after work tomorrow to see if the "solution" holds, but it sure looks like the problem lies in 3.5.0-rc1/2.
                              • Exerqtorundefined Exerqtor referenced this topic
                              • Exerqtorundefined
                                Exerqtor @Exerqtor
                                @dc42 I've ran over ballpark 24hr of prints on 2.5.0b4 now without any issues.
                                Weird that noone else reports about this.
                                • A Former User?
                                  @Exerqtor Not home to look at anything but it might depend on the setup. I had another printer earlier that I also had a duet 3 mini 5+ with 3.5.0 r.1 and a RRF-36 mounted with 3.5.0 r1 firmware. That was an ender 3 pro, a simple bed slinger. I did multiple test prints on it before it was wrapped up as a gift and hauled up here. In 5 days it gets to live again and hopefully will still be problem free.
                                  The printer giving me problems is a CoreXY with 3 Z steppers and a klicky so a bit more complex and different motion system. Also a Duet 3 mini 5_ with the other RRF-36 and the same firmware as the ender.
                                  • Exerqtorundefined
                                    @dc42 I tried installing 3.5.0-rc2 again, with a freshly formated SD card etc. to see if that might help (downloaded the binaries again also just in case) and it still shits the bed:
                                    M122
                                    RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.2 (2023-12-14 10:30:57) running on Duet 3 Mini5plus WiFi (standalone mode)
                                    Used output buffers: 4 of 40 (40 max)
                                    Static ram: 102812
                                    Dynamic ram: 128720 of which 0 recycled
                                    Never used RAM 5196, free system stack 118 words
                                    Tasks: NETWORK(1,ready,119.4%,195) HEAT(3,nWait,0.7%,328) Move(4,nWait,14.5%,239) CanReceiv(6,nWait,1.2%,774) CanSender(5,nWait,0.3%,327) CanClock(7,delaying,0.2%,350) TMC(4,nWait,17.4%,74) MAIN(1,running,53.1%,580) IDLE(0,ready,19.8%,29) AIN(4,delaying,20.2%,264), total 246.8%
                                    Last reset 24:56:40 ago, cause: software
                                    Last software reset at 2023-12-21 16:42, reason: User, Gcodes spinning, available RAM 12348, slot 0
                                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00446000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                    Error status: 0x04
                                    Aux0 errors 0,0,0
                                    MCU revision 3, ADC conversions started 89801376, completed 89801376, timed out 0, errs 0
                                    MCU temperature: min 34.4, current 46.8, max 47.3
                                    Supply voltage: min 8.0, current 23.9, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                                    Heap OK, handles allocated/used 198/28, heap memory allocated/used/recyclable 2048/532/136, gc cycles 15646
                                    Events: 1 queued, 1 completed
                                    Driver 0: ok, SG min 0, read errors 0, write errors 1, ifcnt 33, reads 7119, writes 123, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x72
                                    Driver 1: ok, SG min 0, read errors 0, write errors 1, ifcnt 33, reads 7120, writes 123, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 2: ok, SG min 0, read errors 0, write errors 1, ifcnt 149, reads 7187, writes 56, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 3: ok, SG min 0, read errors 0, write errors 1, ifcnt 145, reads 7185, writes 57, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 4: ok, SG min 0, read errors 0, write errors 1, ifcnt 144, reads 7187, writes 55, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x01
                                    Date/time: 2023-12-22 17:38:55
                                    Slowest loop: 226.03ms; fastest: 0.09ms
                                    === Storage ===
                                    SD card longest read time 11.0ms, write time 62.9ms, max retries 0
                                    DMs created 83, segments created 43, maxWait 59621605ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00
                                    next step interrupt due in 37 ticks, enabled
                                    Moves shaped first try 52954, on retry 20590, too short 71476, wrong shape 255081, maybepossible 11645
                                    === DDARing 0 ===
                                    Scheduled moves 2684, completed 2644, hiccups 1184, stepErrors 0, LaErrors 1095, Underruns [0, 0, 4], CDDA state 3
                                    === DDARing 1 ===
                                    Heater 0 is on, I-accum = 0.3
                                    File is doing "G1 X131.338 Y134.213 E.09057" in state(s) 0
                                    Daemon is doing "G4 P250" in state(s) 0 0, running macro
                                    check 0 clear 0
                                    === CAN ===
                                    Messages queued 1264763, received 1844452, lost 0, errs 1, boc 0
                                    Longest wait 6ms for reply type 6013, peak Tx sync delay 276, free buffers 26 (min 24), ts 449002/449001/0
                                    === Network ===
                                    Slowest loop: 211.13ms; fastest: 0.00ms
                                    === WiFi ===
                                    Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 36292
                                    Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0
                                    M122 B121
                                    Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.2 (2023-12-14 08:58:51)
                                    Never used RAM 2580, free system stack 89 words
                                    Tasks: Move(3,nWait,2.9%,71) HEAT(2,nWait,7.9%,91) CanAsync(5,nWait,0.0%,55) CanRecv(3,nWait,1.0%,77) CanClock(5,nWait,0.4%,67) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,70.2%,57) MAIN(1,running,53.1%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,111.1%,114), total 246.6%
                                    Last reset 24:56:46 ago, cause: software
                                    Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 5, write errors 1, ifcnt 112, reads 29381, writes 30, timeouts 10, DMA errors 0, CC errors 0, failedOp 0x01, steps req 0 done 54758132
                                    Moves scheduled 451072, completed 451072, in progress 0, hiccups 6856, segs 42, step errors 0, maxLate 2 maxPrep 759, maxOverdue 7315, maxInc 2784, mcErrs 0, gcmErrs 0, ebfmin -1.00 max inf
                                    Peak sync jitter -2/12, peak Rx sync delay 280, resyncs 0/0, no timer interrupt scheduled
                                    VIN voltage: min 8.3, current 24.1, max 24.6
                                    MCU temperature: min 39.4C, current 73.3C, max 79.5C
                                    Last sensors broadcast 0x00000012 found 2 138 ticks ago, 0 ordering errs, loop time 0
                                    CAN messages queued 1844535, send timeouts 0, received 1264877, lost 0, errs 1230, boc 0, free buffers 18, min 17, error reg 110000
                                    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 390, adv 34547/74657
                                    Interrupt 5726621 to 0us, poll 4 to 2681us
                                    And it's still happening at random points.
                                    droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                      @Exerqtor I can’t remember if you have posted your config.g recently, but if not, could you post it again, please? If it calls macros, maybe a zip of you sys folder might be easier, to include them all. It’s just the Mini 5+ and a 1LC? What revision of each board? And what extruder type and motor? Does it still do it if you run a ‘dry’ job with no filament? Finally, can you post a Gcode file that provokes the retractions? Though I suspect it isn’t related to the Gcode itself.
                                      • Exerqtorundefined
                                        Exerqtor @droftarts
                                        @droftarts I'm not by the printer now so I'll post everything later.
                                        Yup it's just the Mini (1.02 WiFi) and 1LC (1.2) connected directly to eachother.
                                        The extruder is a Bondtech LGX-lite with the stock motor they come with (running the Bondtech adviced current).. Uuhm I haven't tried a "dry" job, but since the stepper reverses the filament rather than extrude it when it happens i doubt it's load related, if thats what you were thinking of 😅
                                        Regarding a Gcode file it's posted several through the thread here, but I've made a cloud folder with most of the config files and a job file in this post you can have a look at.
                                        Doubt it's anything else than a firmware bug tbh. since 3.5.0-b4 don't act up like this at all. The symptoms and behaviour i'm experiencing is exactly the same ones that plagued 3.5.0-b3.
                                          @Exerqtor okay thanks. I don’t have an LGX, but I’ve probably got a motor similar enough. I might get enough time between Xmas and New Year to setup a bench test. I’ve also got a stepper motor analyser, which might be helpful.
                                          • Exerqtorundefined
                                            Exerqtor @droftarts
                                            @droftarts Np, don't burn your xmas on this lol.
                                            I just reverted to 3.5.0-b4 again so i'm good over the holidays ✌️
                                            Wouldn't stepper specific issues have caused it to stall out rather than reverse btw (if that's what you're think about)? And again, since it don't happen on 3.5.0-b4 with the exact same config🤔
