    cannot connect to duet 2 Wi-Fi or board
    5.5k
      droftarts administrators @Blunt2007
      @Blunt2007 try setting up the WiFi using runonce.g, before going the erase firmware route.
      Use Windows Notepad. The files have .g endings for gcode, but they are just text documents. Just make sure the files you create are 'runonce.g' not 'runonce.g.txt', and that they are plain text files.
      Blunt2007undefined 4 Replies Last reply Reply Quote 0
      • Blunt2007undefined
        Blunt2007 @droftarts
        @droftarts okay I'm going to use notepad I'll get back to you in a little while probably tomorrow
          @droftarts awesome I got the board to connect to Wi-Fi by using the code you gave me thank you very much for your help much appreciative I got one more question I'm getting notification that it keeps on losing Wi-Fi and has to reconnect to it if I increase bandwidth will that help to keep connected to the board once again I thank you so much I was wrong this board is working now and it connects to Yat. I am getting a green light now and it connects to Wi-Fi
            @droftarts a crud I disconnected from the Wi-Fi unplug the board and then plugged it back in and now it will not connect to Wi-Fi and it will not show a green light in yat. It worked last night but this morning when I connected it it will not connect to the Wi-Fi
              @droftarts when I go into the browser to click on the link that was left there from last night it's coming up with a 404 page not found and in device manager it is showing up on com4 same as last night
                @Blunt2007
                For YAT:
                • Try starting Windows in Safe Mode, which should stop any other application from taking over the COM port. See https://support.microsoft.com/en-us/windows/find-safe-mode-and-other-startup-settings-in-windows-10-7551aac3-21b5-c646-06ee-31e0e6a5e4dc
                • Is the USB cable pushed fully in to the Duet? It may not be making a good connections. Be careful when inserting the cable though, as it is possible to rip the USB port off the Duet, especially if you don't push the cable straight into the port.
                • If you think the USB port is damaged, take close up picture of the back of the port, where the soldered connections are, and post it here so we can see.
                • Is the Duet powered only by USB? It can cause problems if you connect the mains power and USB at the same time, and the mains power is poorly earthed. See https://docs.duet3d.com/en/User_manual/Overview/USB_ground_loops
                For WiFi:
                • If the green light next to the WiFi module is on solidly, it has connected to WiFi.
                • Did you use an IP address, or duettest.local to connect to it?
                • Does your Duet 2 WiFi have an external aerial, and have you connected it?
                • For general WiFi troubleshooting, see https://docs.duet3d.com/en/User_manual/Troubleshooting/WiFi_troubleshooting
                • If you can connect via YAT, send M122 for a system report. The last section shows WiFi details. Copy and paste that into your reply.
                  Phaedrux Moderator @Blunt2007
                  @Blunt2007 said in cannot connect to duet 2 Wi-Fi or board:
                  Your config.g file will require M552 S1 in it to reconnect to the wifi at startup.
                  Blunt2007undefined 1 Reply Last reply Reply Quote 0
                    Blunt2007 @Phaedrux
                    @Phaedrux I am still at the point of trying to get connected to the board USB is only power going to the board. I pulled the SD card out and put it in my computer and reload it "runonce.g"onto the SD card under config g and it booted up and I was able to connect to Wi-Fi again. I shut it down letting it sit overnight and then I'm going to plug it in again to see if it reestablishes Wi-Fi again I will give you an update tomorrow if it works or or if it doesn't work. If it doesn't work I will reboot the computer in safe mode and try it then
                    Phaedruxundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                      It won't automatically connect to wifi unless M552 S1 is present in config.g
                        @Blunt2007 as @Phaedrux said, on the SD card, in the /sys folder, config.g should have M552 S1 in it. If it does, and the WiFi still does not start when the Duet is powered up, copy the config.g file off the SD card on your computer, and post it here.
                        Because the runonce.g file worked, and you could connect to DWC, I don’t think the problem is with the SD card or SD card socket, but possibly a corrupt config.g is causing problems.
                        Another thing to try is to remove the SD card, then power the Duet, and try connecting via YAT.
                        Lastly, if you do connect, either by YAT or WiFi, send M122 and post the result here. In DWC (the WiFi interface) click on ‘Console’ and enter M122 there. See https://docs.duet3d.com/en/User_manual/Reference/Duet_Web_Control_Manual#console for a guide.
                        Blunt2007undefined 3 Replies Last reply Reply Quote 0
                          @droftarts okay here we go again. I connected the board using USB it connected to Wi-Fi .I unplugged the USB .hooked up my power supply turned on power supply it connected to Wi-Fi and I was able to select different options then it lost signal and would not reconnect I tried shutting off power supply and returned it on and Will not connect Wi-Fi under power supply unplugged power supply .plugged USB back in with power supply off it comes up in device manager and now will not connect Wi-Fi
                            @droftarts hear the post M122.
                            12/15/2023, 6:03:46 PM M122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
                            Board ID: 0JD0M-9P6B2-NJ4S8-6JTD4-3SN6K-9U4LK
                            Used output buffers: 3 of 24 (11 max)
                            Static ram: 23876
                            Dynamic ram: 75072 of which 24 recycled
                            Never used RAM 15444, free system stack 184 words
                            Tasks: NETWORK(ready,12.4%,244) HEAT(delaying,0.0%,346) Move(notifyWait,0.1%,364) MAIN(running,84.7%,443) IDLE(ready,2.7%,29), total 100.0%
                            Owned mutexes: WiFi(NETWORK)
                            Last reset 00:00:34 ago, cause: power up
                            Last software reset details not available
                            Error status: 0x00
                            Aux0 errors 0,0,570
                            Step timer max interval 0
                            MCU temperature: min 38.5, current 41.4, max 41.7
                            Supply voltage: min 24.2, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                            Driver 0: position 0, standstill, SG min/max not available
                            Driver 1: position 0, standstill, SG min/max not available
                            Driver 2: position 0, standstill, SG min/max not available
                            Driver 5: position 0
                            Driver 6: position 0
                            Driver 7: position 0
                            Driver 8: position 0
                            Driver 9: position 0
                            Driver 10: position 0
                            Driver 11: position 0
                            Date/time: 2023-12-15 18:03:46
                            Cache data hit count 1246170868
                            Slowest loop: 2.04ms; fastest: 0.17ms
                            === Storage ===
                            Free file entries: 10
                            SD card longest read time 9.5ms, write time 0.0ms, max retries 0
                            === MainDDARing ===
                            === AuxDDARing ===
                            Segments left: 0
                            Movement lock held by null
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is idle in state(s) 0
                            USB is idle in state(s) 0
                            Aux is assembling a command in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            LCD is idle in state(s) 0
                            Daemon is idle in state(s) 0
                            Code queue is empty.
                            === Network ===
                            Slowest loop: 15.96ms; fastest: 0.00ms
                            Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                            HTTP sessions: 1 of 8
                            • WiFi -
                              Network state is active
                              WiFi firmware version 1.26
                              WiFi MAC address c8:c9:a3:40:90:59
                              WiFi Vcc 3.38, reset reason Power up
                              WiFi flash size 2097152, free heap 25560
                              WiFi IP address 192.168.1.21
                              WiFi signal strength -19dBm, mode 802.11n, reconnections 0, sleep mode modem
                              Clock register 00002002
                              12/15/2023, 6:03:32 PM Connected to 192.168.1.21
                              @droftarts to get the board working again I had to reload "runonce.g"
                                @Blunt2007 you shouldn’t have to keep on running runonce.g. Your WiFi name and password is stored already. The problem with the WiFi is that it is not being started with config.g. Put the sd card in your computer, copy off the /sys/config.g file, and post it here.
                                The M122 shows a solid WiFi connection, and that the sd card is working correctly. It doesn’t report on the USB port. You are running older firmware but that’s okay for now.
                                  @droftarts do you want the config file now while it's still running or wait until it stops running and then copy the config file
                                    @Blunt2007 if you can connect via WiFi, go to the System menu, which should list the files in /sys. Right click on config.g, and select Edit. Then copy and paste the contents to your reply. Extra points if you can put it in code tags </> on the formatting menu, so
                                    It looks like this!
                                    Blunt2007undefined 2 Replies Last reply Reply Quote 0
                                      @droftarts <Configuration file for Duet WiFi (firmware version 3.3)
                                      ; generated by RepRapFirmware Configuration Tool v3.3.16 on Wed Dec 13 2023 17:00:01 GMT-0600 (Central Standard Time)
                                      M550 P"1 ENDER 5 PLUS" ; set printer name
                                      M669 K1 ; select CoreXY mode
                                      M552 S1 ; enable network
                                      M586 P0 S1 ; enable HTTP
                                      M586 P1 S0 ; disable FTP
                                      M586 P2 S0 ; disable Telnet
                                      M569 P3 S0 ; physical drive 3 goes backwards
                                      M92 X80.00 Y80.00 Z400.00 E98.00 ; set steps per mm
                                      M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                                      M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
                                      M201 X3000.00 Y3000.00 Z100.00 E1000.00 ; set accelerations (mm/s^2)
                                      M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
                                      M84 S30 ; Set idle timeout
                                      M208 X350 Y350 Z400 S0 ; set axis maxima
                                      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                                      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                                      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                                      M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                                      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                                      M557 X15:215 Y15:195 S20 ; define mesh grid
                                      M143 H1 S350 ; set temperature limit for heater 1 to 350C
                                      M563 P1 D0 H1 F0 ; define tool 1
                                      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
                                      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
                                      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss>
                                        @droftarts I am able to log on to Wi-Fi and it is getting connected now The only thing that is not working is connecting to yat be a USB but it is connecting to Wi-Fi it's been 2 days now and it's still working via Wi-Fi
                                          @Blunt2007 That's good to hear. Your config.g looks generally sensible, and has M552 S1 which enables WiFi, in it.
                                          One point: your machine name is 'Ender 5 plus'. Unless you have modified your printer, these machines are cartesian printers, not CoreXY, which you have set with M669 K1. Is that correct?
                                          For the USB, have you tried connecting since the config.g has been updated, and you can reliably connect via WiFi? It may have been continually rebooting before, if there was a configuration problem, which may have caused USB not to connect.
                                          If that still doesn't work, can you post a picture of the back of the USB port, where the pins are? I want to check all the pins are soldered correctly. If they are not, we can exchange it under warranty.
                                            @droftarts Yes it is an ender 5 plus from what I found on the internet that is what I selected of course I'm fairly new at this so I can be completely wrong I could use your help if you know of anybody that has a ender 5 plus with the files already made up I can really appreciate it and the list and documentation so I can read up on G-Code. I did boot the computer up into safe mode and it said that the comports are not available and safe mode so I'll send you a picture of the USB connection thanks for your help17029166918305320779331229999773.jpg
