    Error for fan not found running 3.4.6
    316
    • GeneRisiundefined
      GeneRisi
      I am getting a strange error, "Fan 4 not found". I would like to trace it. What gcodes besides M106 and M107 might generate that error message? Also, is there a way to see which line number caused the last error?
      It is occurring in the main body of my print.
      • fcwiltundefined
        fcwilt @GeneRisi
        @GeneRisi
        Then it is very likely M106 or M107.
        Have you scanned the file you are trying to print for those commands?
        GeneRisiundefined 1 Reply Last reply Reply Quote 0
        • GeneRisiundefined
          GeneRisi @fcwilt
          @fcwilt Yes, I have. I am starting to suspect that running 3.5.x on Paneldue and 3.4.6 on Duet2 might have caused the problem. I have reinstalled the 3.4 version of Paneldue and am running the same code file to see if it still puts out the warning message.
          • fcwiltundefined
            fcwilt @GeneRisi
            @GeneRisi
            Do you have any macros that are called by the print code that might be trying to control fan 4?
            • GeneRisiundefined
              GeneRisi @fcwilt
              @fcwilt I have macros but nothing appears to be calling for Fan 4, in fact, Fan 4 is not even assigned in config.g.
              The model code has only 3 instances of M106 and no instances of M107.
              fcwiltundefined droftartsundefined 2 Replies Last reply Reply Quote 0
              • fcwiltundefined
                fcwilt @GeneRisi
                @GeneRisi
                Just as a test try to control fan 4 (which doesn't exist) with M106/M107 to see if you get the same error message.
                  droftarts administrators @GeneRisi
                  @GeneRisi Could you have assigned a non-existing fan 4 to a tool or in a tool change macro, and it is trying to set it on a tool change? It may help to post your config.g, otherwise we have very little to go on.
                  • GeneRisiundefined
                    GeneRisi @droftarts
                    @droftarts Thanks, Ian. I started a trace because I am even more suspicious that it has to do with running 3.5.x on my 5 inch Paneldue.
                    Here’s my config.g:
                    ; Configuration file for Duet WiFi / Ethernet
                    ; *** General preferences ***
                    M111 S0 						; Debugging off
                    M550 P"ToolChanger" 			; Set machine name
                    G21 							; Work in millimetres
                    G90 							; Send absolute coordinates...
                    M83 							; ...but relative extruder moves
                    M555 P2 						; Set firmware compatibility to look like Marlin
                    ; *** Network ***
                    M552 S1							; Enable Networking
                    M586 P0 S1 						; Enable HTTP
                    M586 P1 S1 						; Enable FTP
                    M586 P2 S0 						; Disable Telnet
                    ; *** Kinematics ***
                    M667 S1 					; Select CoreXY mode
                    ; *** Endstops ***
                    M574 X1 P"xstop" S1              					; Set X endstop as active high switch
                    M574 Y1 P"ystop" S1                  				; Set Y endstop as active high switch
                    M574 Z1 S2 											; Set Z endstop probe
                    ;	note that M574 not used here for A or C
                    M915 C S5 F0 H200									; Coupler end stop is stall
                    M915 A S10 F0 H200									; Wiper "A" end stop is stall
                    ;M915 B S10 F0 H200									; Wiper "B" end stop is stall
                    M558 P8 C"zstop" X0 Y0 Z2 H3 F360:180 I0 T20000 	; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
                    G31 P200 X0 Y0 Z0	 								; Set Z probe trigger value, offset and trigger height
                    ; *** Bed Leveling ***
                    M557 X10:290 Y20:180 S40 			; Define mesh grid
                    M376 H15							; bed compensation taper
                    if !exists(global.freshMesh)
                    	global freshMesh = false
                    else
                    	set global.freshMesh = false
                    G29 Q2								; turn off bed mesh compensation (shouldn't be on, but ...)
                    ; *** Drive direction ***
                    M569 P0 S0 					; Drive 0 X
                    M569 P1 S0 					; Drive 1 Y
                    M569 P2 S1 					; Drive 2 Z
                    M569 P3 S1 					; Drive 3 E0 - something strange here
                    M569 P4 S1 					; Drive 4 E1
                    M569 P5 S1 					; Drive 5 E2
                    M569 P6 S1 					; Drive 6 E3
                    M569 P7 S0 					; Drive 7 COUPLER
                    M569 P8 S1 					; Drive 8 Wiper "A"
                    ;M569 P9 S1 					; Drive 9 Wiper "B"
                    ; *** Drive Mapping ***
                    M584 X0 Y1 Z2 A8 C7 E3:4:5:6 		; Apply custom drive mapping
                    ;M584 B9							; Apply custom drive mapping
                    ; *** AXES min and max ***
                    M208 X-27:330 Y-49:243 Z0:300 A-43:0 C0:500 S0 	; Set axis maxima & minima
                    ; M208 B0:43
                    ; *** Stepping ***
                    M92 X100 Y100 Z1600					; Set steps per mm at default 1/16 microstepping
                    M350 X16 Y16 Z16 I1					; Configure microstepping with interpolation
                    M350 E16:16:8:16 A16 C8 I1 			; Configure microstepping without interpolation except for Extruder 3
                    ;M350 B16
                    M92 C100 A400 E690:690:417:409		; Set steps per mm at just defined microstepping
                    ;M92 B400
                    ; *** Motion Settings ***
                    M566 X400 Y400 Z8 A8 C2 E300:300:300:300					; Set maximum instantaneous speed changes (mm/min)
                    ;M566 B8
                    M203 X35000 Y35000 Z1200 A1200 C5000 E7200:7200:3600:3600	; Set maximum speeds (mm/min)
                    ;M203 B1200
                    M201 X6000 Y6000 Z400 A400 C400 E7000:7000:600:3000			; Set accelerations (mm/s^2)
                    ;M201 B400
                    ;M593 F48													; cancel ringing at 50Hz (https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/)
                    ; *** Drive Currents ***
                    ; motor currents (mA) maxes
                    M906 X1400 Y1400 I30
                    M906 E1200:1200:500:1380 I10
                    M906 A700 I40
                    ;M906 B700 I40
                    M906 C600 I50
                    M906 Z1250 I70
                    M84 S120 												; Set idle timeout
                    ; *** PanelDue 5i ***
                    M575 P1 S1  B57600										; set baud rate to PanelDue 5
                    ; *** fine Z offset - only adjust if probe has changed trigger point ***
                    var z_trigger_offset = -0.01
                    ; *** Define Tools ***
                    if !exists(global.toolA)
                    	global toolA = 0
                    if !exists(global.toolB)
                    	global toolB = 1
                    if !exists(global.toolC)
                    	global toolC = 2
                    if !exists(global.toolD)
                    	global toolD = 3
                    ; *** *** > Bed <
                    M308 S0 P"bedtemp" Y"thermistor" A"bed" T100000 B4138 C0	; Thermistor
                    M950 H0 C"bedheat" T0										; Heater
                    M140 H0														; define the bed heater
                    M143 H0 S225 												; Set temperature limit to 225C (bed)
                    M307 H0 R1.001 C428.841:428.841 D10.89 S1.00 V24.4 B0 I0	; set PID parameters
                    ; *** *** > Tool 0 <
                    M308 S1 P"spi.cs1" Y"rtd-max31865" A"T0" F60 				; PT100
                    M950 H1 C"e0heat" T1										; Heater
                    M143 H1 S390												; Set temperature limit to 390C
                    M307 H1 R1.631 C239.974:239.974 D4.07 S1.00 V24.3 B0 I0		; set PID parameters
                    M950 F8 C"fan1"												; HE fan
                    M106 P8 S255 H1 T70
                    M950 F0 C"fan2"												; PCF fan 0
                    M106 P0 S0
                    M569 P3 S1 													; Extruder Stepper
                    M563 P0 D0 H1 F2 											; Define tool
                    M568 P0 R0 S0 												; Reset initial tool active and standby temperatures to 0C
                    G10 P0 X-9.0 Y39.0 Z{-5.02 + var.z_trigger_offset}			; Define Tool Offset; homed and leveled hot,  bed mesh on, measured at bed=85c, nozzle=240c
                    ;M572 D0 S0.025												; pressure advance for Orbiter
                    if !exists(global.T0_Park_X)
                    	global T0_Park_X = -4.2
                    	global T0_Park_Y = 240.0
                    ; *** *** > Tool 1 <
                    M308 S2 P"spi.cs2" Y"rtd-max31865" A"T1" F60				; PT100
                    M950 H2 C"e1heat" T2										; Heater
                    M143 H2 S390 												; Set temperature limit to 390C
                    M307 H2 R1.940 C222.050:222.050 D5.17 S1.00 V24.3 B0 I0		; set PID parameters
                    M950 F9 C"duex.fan3"										; HE fan
                    M106 P9 S255 H2 T70
                    M950 F1 C"duex.fan4"										; PCF fan 1
                    M106 P1 S0
                    M569 P4 S1 													; Extruder Stepper
                    M563 P1 D1 H2 F4 							    			; Define tool
                    M568 P1 R0 S0 												; Reset initial tool active and standby temperatures to 0C
                    G10 P1 X-8.65 Y39.15 Z{-5.06 + var.z_trigger_offset}		; Define tool offset - was x-9.1
                    ;M572 D1 S0.025												; pressure advance for Orbiter
                    M207 P1 S1.5 F7200 T3000 Z0.075								; for hardware based retraction
                    if !exists(global.T1_Park_X)
                    	global T1_Park_X = 86.0  ; strange change here
                    	global T1_Park_Y = 240.5
                    ; *** *** > Tool 2 (unpopulated) <
                    ;M308 S3 P"spi.cs3" Y"rtd-max31865" A"T2" F60				; PT100
                    ;M950 H3 C"duex.e2heat" T3									; Heater
                    ;M143 H3 S390												; Set temperature limit to 390C
                    ;M950 F5 C"duex.fan5"										; HE fan
                    ;M106 P5 S255 H3 T70
                    ;M950 F6 C"duex.fan6"										; PCF fan
                    ;M106 P6 S0
                    ;M569 P5 S1 												; Extruder Stepper
                    ;M563 P2 D2 H3 F6 											; Define tool
                    ;G10 P2 X0 Y0 Z0 											; Reset tool axis offsets
                    ;G10 P2 R0 S0 												; Reset initial tool active and standby temperatures to 0C
                    ;G10 P2 X-9 Y39 Z-5											; Define Tool Offset
                    ; *** *** > Tool 3 (Hemera) <
                    M308 S4 P"spi.cs4" Y"rtd-max31865" A"T3" F60				; PT100
                    M950 H4 C"duex.e3heat" T4									; Heater
                    M143 H4 S390 												; Set temperature limit to 390C
                    ;M307 H4 ...												; Set PID values
                    M950 F11 C"duex.fan7"										; HE fan
                    M106 P11 S255 H4 T70
                    M950 F3 C"duex.fan8"										; PCF fan 3
                    M106 P3 S0
                    M569 P6 S1 													; Extruder Stepper
                    M563 P3 D3 H4 F8 											; Define tool
                    M568 P3 R0 S0 												; Reset initial tool active and standby temperatures to 0C
                    G10 P3 X19.77 Y43.50 Z{-5.71 + var.z_trigger_offset}			; z was -6.06, then 6.00, y43.65
                    ;M572 D3 S0.07												; ? Pressure advance ???
                    if !exists(global.T3_Park_X)
                    	global T3_Park_X = 308
                    	global T3_Park_Y = 225.25
                    ; *** Accelerometer ***
                    M955 P0 C"duex.cs5+duex.cs6"
                    ; *** Define Servos ***
                    ;  > Wiper A <
                    M950 P0 C"duex.pwm4" Q50
                    ;  > Wiper B <
                    M950 P1 C"duex.pwm5" Q50
                    ; *** Stepper noise tuning
                    ;M569 P0 F1 Y10:00
                    ;M569 P1 F12 Y10:00
                    ;M569 P2 F6 Y05:03
                    ; M501
                    ; *** Actions ***
                    T-1									;de-select all tools
                    ; finis
                    And this is my “nozzle cleaning” macro:
                    ; for tools T0 and T1
                    echo "begin pblwiper_A"
                    var extlen=15
                    ;if exists(param.L)
                    ;   set var.extlen=param.L
                    var fanspd=0.0
                    if exists(param.F)
                      set var.fanspd = param.F / 100
                    var cooltime=1500
                    if exists(param.C)
                      set var.cooltime=param.C
                    var scrubOnly=false
                    if exists(param.S)
                      set var.scrubOnly=true
                    var a0_to_wiper=-5.25
                    var a0_to_brush=-8.50
                    ;;;;;;; g-code below
                    G91
                    G1 Z1 F500                 ; Drop Z 1mm for Safety
                    G90
                    G1 E-1.00 F1800				; retract
                    G1 Y175 F2000				; move tool to standby position
                    G1 X-20	F2000
                    M98 p"/macros/set_A_min.g"	; set A wiper to use bottom endstop
                    G1 A-33 F500					; move A wiper out of the way
                    M280 P0 S170				; move wiper arm to ready position
                    G4 P1000
                    ; Set Up for Pebble Purge
                    G1 X-25.7 Y147.9 F24000		; move to brad location - here to make testing easier - only for tools 0 and 1
                    M98 p"/macros/set_A_max.g"	; set A wiper to use top endstop - determine nozzle tip location
                    G1 A{var.a0_to_wiper} E0.75 F500		; move wiper to tip of std v6 nozzle
                    if !var.scrubOnly
                    	G4 P0
                    	M280 P0 S18					; cut off any hanging string from the nozzle
                    	G4 P1000					;
                    	G1 A-2 F500					; move brass brad closer
                    	G4 P0						;
                    	G1 E1 F120					; trying to avoid strange extrusion speed that happens here
                    	G1 P500
                    	echo  "...Extruding"
                    	G1 E{var.extlen} F300		; Pebble Purge
                    	G4 P0						;
                    	G1 A-6 F500					; move away from nozzle tip
                    	M106 S1.00					; Cooling On
                    	M106 S0.93					;
                    	G1 E-0.6 F300				; Retract
                    	G4 P{var.cooltime}			; Dwell for cooltime
                    	;M280 P0 S170				; Servo Wipe 1 - toss pebble
                    	G4 P500						;
                    	;M280 P0 S18					;
                    	G4 P1000					;
                    	M280 P0 S170
                    	G4 P1000
                    	G1 A{var.a0_to_wiper} F500				; go back to nozzle tip
                    	M280 P0 S18					;
                    	G4 P500						;
                    	M280 P0 S170
                    	G4 P1000
                    else
                    	G1 E1.0 F1800				; restore retracted plastic
                    	echo "...Wiping"
                    M42 P0 S0					; Turn Servo off
                    ; Move Nozzle Across Nylon Brush
                    G1 A{var.a0_to_brush} F500				; move brush down
                    G91
                    G1 X+0 Y-50  F6000
                    G1 X+5 Y+50
                    G1 X+5 Y-50
                    G1 Z-1 F500					; restore Z height
                    G90							; locations now absolute
                    G92 E0						; Reset Extrusion - extruding ?
                    echo "M106 S", {var.fanspd}
                    M106 S{var.fanspd}			; restore fan speed
                    G4 P0
                    echo "End of pblwiper_a"
                    ;finis
                      jay_s_uk @GeneRisi
                      @GeneRisi said in Error for fan not found running 3.4.6:
                      M563 P1 D1 H2 F4
                      check your config again...
                      • GeneRisiundefined
                        GeneRisi @jay_s_uk
                        @jay_s_uk Thank you so much for pointing that out! There are a few things that are wrong; I really appreciate your help!
                        This is closed. Thanks for the help!
                        Gene
