    Can't print with daemon.g with 1sec loop
    237
    • zaptaundefined
      zapta
      When I add a daemon.g with a 1 sec infinite loop (as recommended for 1sec events), I can't print anymore.
      while true
        G4 P1000   ; Wait 1sec
        echo {"Loop " ^ iterations}
      I do see the console messages every sec, upload from Prusa Slicer goes normal, the printer enters the Printing state, but nothing happens and the bed heater does start heating as it should. If I remove daemon.g, everything works well.
      Any suggestions?
      I am using this version
      EDIT: The system config and macros, and a sample gcode file I try to print, are here https://github.com/zapta/temp_public/tree/main/bug_report_files
      • zaptaundefined
        zapta
        One more observation, when I upload the file and the printer enter Printing mode, I see in the console messages as if a new daemon.g loop started in parallel to the existing one.
        • zaptaundefined zapta marked this topic as a question
          Does it behave the same with G4 S1 instead of P1000?
          Does it behave the same with 3.5 RC1? Or RC2?
          zaptaundefined 2 Replies Last reply Reply Quote 0
          • zaptaundefined
            zapta @Phaedrux
            @Phaedrux, same with the daemon.g below. I will try the RC and will report here.
            while true
              G4 S1 ; Wait 1sec
            • zaptaundefined
              zapta @Phaedrux
              @Phaedrux, to upgrade to 3.5.0 RC1 (this is the latest I find on github), do I just need to upload Duet3Firmware_Mini5plus.uf2 via the web interface?
              1 Reply Last reply Reply Quote -1
                Yes, and you'll also have to update DWC.
                • zaptaundefined
                  zapta @Phaedrux
                  What file is it and how do I install it?
                  (I am using a standalone Duet Mini, no Raspberry Pi)
                  • zaptaundefined
                    zapta @Phaedrux
                    @Phaedrux, found the problem. 100% my fault. My Prusa slicer startup code injects the snippet below to the files I send to the printer. That's a result of lazy programming. Thanks for your help.
                    ; This forces an immediate update of the neopixels color
                    M98 P"/sys/daemon.g"
                    • zaptaundefined zapta has marked this topic as solved
